Do i "really" need to buy Mopar coolant? - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 25 Old 04-11-2011, 07:54 PM Thread Starter
Rocco1005
Just wanting to know if i really have to buy Mopar coolant. I was changing out my thermostat and had to put in about 1.5 gallons of coolant so i bought some Prestone 50/50 mix that says "use in all years of all makes and models of vehicles/light trucks" and also you can use it with any color coolant/antifreeze. So if these types of coolants exist then why should i buy Mopar coolant if this Prestone is basically universal coolant? Just wondering because im sure the dealership will be waaaay to high than i want to spend.
Rocco1005 is offline
post #2 of 25 Old 04-11-2011, 08:08 PM
jmgak47
\m/(-_-)\m/
jmgak47's Avatar
Quoted: 24 Post(s)
I sure hope you didn't put that yellow crap in your radiator? It must be HOAT rated antifreeze.
2014 RAM 1500 Express QC 2wd Hemi
Best N/A 1/4: 12.18 @ 110.15
Best N/A 1/8: 7.74 @ 89.06
2000 GMC Sierra 1500 RCSB 2wd - 454 LSX powered drag truck...
SOLD - 2007 Dodge Ram 1500 QC 2wd - Heavily modded stock block Hemi...
Best N/A 1/4: 12.63 @ 104.92
Best N/A 1/8: 7.98 @ 84.83
jmgak47 is offline
post #3 of 25 Old 04-11-2011, 08:11 PM Thread Starter
Rocco1005
lol, yea i did, but thats why im asking, whats the reason i have to put HOAT rated antifreeze in there?
post #4 of 25 Old 04-11-2011, 08:19 PM
jmgak47
\m/(-_-)\m/
jmgak47's Avatar
Quoted: 24 Post(s)
IAT do in no way meet the requirements for our motors, big no no and you will lose your corrosion protection. Even OAT or Dexcool has been know to gunk up the motor over time. Also never mix antifreeze as it can coagulate giving major issues.
HOAT only unless you want trouble!
jmgak47 is offline
post #5 of 25 Old 04-11-2011, 08:25 PM
orvtenn
+ Hemi Addict +
orvtenn's Avatar
Quoted: 9 Post(s)
If you're going aftermarket, Zerex G-05 is the only way to go
2004 1500 SLT RC/SB 4x4 Hemi 5.7
2001 Jeep Cherokee Sport 4.0HO
orvtenn is offline
post #6 of 25 Old 04-11-2011, 08:25 PM
SilsHemi
Dodge Fanatic!
What he said. ^^^
Zerex G-05 is compatible. http://www.valvoline.com/products/br.../antifreeze/42
Utilizes hybrid organic acid technology to minimize inhibitor depletion
HOAT
Sil
SilsHemi is offline
post #7 of 25 Old 04-11-2011, 08:25 PM
xtremewlr
I'd rather be riding...
xtremewlr's Avatar
Quoted: 8 Post(s)
Get some Zerex G05 coolant. It's HOAT and works good in these trucks.
HAH! We all posted the same thing at the same time
~2004 Ram 1500 SLT Quad Cab Hemi - work horse
Performance: DIY Power Wire, K&N drop in filter, Taylor "long" wires, MagnaFlow Y pipe, Magnaflow 12589 to 3" mandrel bent pipe, Sonnax Line Pressure Booster
Handling: Bilstien HD shocks, BellTech rear sway bar, McGaughy's 2" drop shackles, Toyo Proxes ST2 305/50/20
xtremewlr is offline
post #8 of 25 Old 04-11-2011, 08:26 PM Thread Starter
Rocco1005
ok good enough reasons for me to go to HOAT lol. So let me ask you, will i be fine to drive it until this weekend so i can change it? Also, how many gallons will i need if i do a full drain, whats the best way to drain it, and how do i mix this stuff up correctly with water?
post #9 of 25 Old 04-11-2011, 08:28 PM
xtremewlr
xtremewlr's Avatar
Quoted: 8 Post(s)
G-05 is premixed, no water needed. Says so on the bottle even.
post #10 of 25 Old 04-11-2011, 08:29 PM
SilsHemi
Dodge Fanatic!
There's a 50/50 premixed bottle and one that's 100% coolant.
Sil
SilsHemi is offline
post #11 of 25 Old 04-11-2011, 08:31 PM
orvtenn
+ Hemi Addict +
orvtenn's Avatar
Quoted: 9 Post(s)
If you mixed IAT/OAT/Dexcool with the factory fill you will need to do a full cooling system flush before refilling and buy the 50/50 premix that way you don't have to worry about mixing and you don't have to deal with all the problems with using plain tap water (electrolysis, corrosion, scaling, etc).
orvtenn is offline
post #12 of 25 Old 04-11-2011, 08:32 PM Thread Starter
Rocco1005
ok thanks guys, ill get the pre-mix stuff, how many gallons will fill it back up when i drain this pig?
post #13 of 25 Old 04-11-2011, 08:33 PM Thread Starter
Rocco1005
ahh crap, so ill have to have a oil change shop flush it and then give them the bottles of zerex to fill it back up with?
post #14 of 25 Old 04-11-2011, 08:38 PM
orvtenn
+ Hemi Addict +
orvtenn's Avatar
Quoted: 9 Post(s)
Prestone Flush & Fill Kit
http://www.prestone.com/products/print/461?popup=1
orvtenn is offline
post #15 of 25 Old 04-11-2011, 08:44 PM Thread Starter
Rocco1005
niiiiiiice, ill have to find that, then figure out how to use it, seems easy enough.
post #16 of 25 Old 04-11-2011, 08:57 PM
JFM-jr
JFM-jr's Avatar
I ran Dexcool (GM) in my Camaro (LS series aluminum block and heads) for ten+ years with no problems. The issue with the Dexcool and the HOAT comes into play when you mix different types with them. They can gel up and block the system up as stated. As long as you use 100% of the same type coolant it should be fine. I'd be willing to bet if a full flush was done Dexcool would work just fine in these trucks. I never emptied my system so I topped off with HOAT when I did my radiator replacement.
09 Hemi powered Ram QC 2500 Sport
Fuel Boost rims 17x9 +20MM
Nitto Terra Grapplers 305/70/17
OEM 4.56 gears
SuperChips Cortex 3950 (1449666)
JFM-jr is offline
post #17 of 25 Old 04-11-2011, 09:38 PM Thread Starter
Rocco1005
can i do it this way instead?
Drain radiator. Drain big hose that goes into thermostat? fill radiator with water from hose then drain, do this maybe twice. then fill radiator back up with new 50/50 zerex?
post #18 of 25 Old 04-11-2011, 11:54 PM
dmcelhannon
Admin - David Mack
dmcelhannon's Avatar
Quoted: 245 Post(s)
dmcelhannon is offline
post #19 of 25 Old 04-12-2011, 12:31 AM
MeenGreen5.2
i'm blue :D
MeenGreen5.2's Avatar
Quoted: 1 Post(s)
i put in that prestone stuff in my dads 3rd gen when i changed the rad. no problems. it's been 5 years since then.
2010 dodge ram 5.7 sport
deep water blue pearl
BLUE
24"verde rims
stock
BLUE TRUCK CLUB MEMBER #249
Trucks and Guns member #164
MeenGreen5.2 is offline
post #20 of 25 Old 04-12-2011, 05:48 AM
NHHEMI
NHHEMI's Avatar
You used this stuff right?
You should be fine. As long as the coolant said it was safe for all vehicles you are good. I have used "all vehicle" formulas in both HOAT( Chrysler ) and Dexcool(GM ) cooling systems and been fine. I haven't used the Prestone one like shown above, in a HOAT system specifically, but it is the same basic concept as universal tranny fluids. IF the mfg says it will work you are fine( or should be ).
Just note that the 50/50 pre mixed stuff is for topping off like you did and not meant to be used for a complete coolant system change over. How you used it is correct and you are good to go IMO. I would not do a flush just because you used the all vehicle formula. That is the whole poiint of it being made now. Just too many different formulas and demands to offer them all individually( you would have a whole isle for just AF ). Better for one that will handle them all.
The new Prestone® All Makes All Models Extended Life Antifreeze/Coolant is a patented Organic Acid Technology formula that offers up to five years or 150,000 miles of protection when it is added to any extended life antifreeze/coolant. When added to a vehicle’s current formula, it is designed to provide the properties and change over intervals of that formula, be it one that offers 30,000-miles of protection, 100,000-miles of protection or 150,000-miles of protection.
The new formula has been tested with antifreeze/coolant formulations that are factory installed by major auto and light-duty truck makers. It may be added to the antifreeze/coolant of any make or model automobile or light duty truck on the road, foreign or domestic
The new Prestone® 50/50 Prediluted All Makes All Models Extended Life Antifreeze/Coolant formula should only be used to top off the cooling system. For a flush and fill, motorists should use the full concentrate formula offered by the brand to ensure the right mix of water and antifreeze concentrate.
2011 Jeep Patriot
"Latitude"
4WD 2.4L
Royal Purple #1
NHHEMI is offline
    "coolant pipe" dodger64 Dodge Caravan General Talk 5 06-15-2010 02:31 PM
    nasta stainless 3" OR Mopar OEM 4" oval chrome nerf bars? titanconvert 3G Dodge RAM - Interior/Exterior Talk 8 04-07-2006 05:28 AM
    p0118 "Coolant Voltage High" Durango4Wheeler 1G Dodge Durango Performance Talk 0 07-23-2005 11:24 AM
    Coolant Leak - Just "venting" rkfsm 2G Dodge Stratus - General Talk 6 07-05-2005 06:57 AM
