power inverter switch - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 9 Old 03-19-2011, 05:45 PM Thread Starter
kelowna1500
kelowna1500's Avatar
i'm putting an inverter in my truck and want to make it look as stock as possible. i have the plug from a 2011 ram (gunna put it below the passenger side vent where the air bag shut off switch would be on a regular cab), but i was wondering if anyone knows the part # for the switch to turn the inverter on and off. also, does the switch wire directly to the plug, or does it wire up to the computer first? just hoping i can make this work.
kelowna1500 is offline
post #2 of 9 Old 03-19-2011, 08:27 PM
wixthedog
That guy
wixthedog's Avatar
Quoted: 36 Post(s)
I would be interested to see how this works out, keep us posted please.
Sorry I cant help answer any of your questions, I have not looked into it.
Mike AKA: WixTheDog
2015 Dodge 1500 Crew Cab Laramie - 4x4- Deep Cherry Red
Stock...
2014 Dodge Durango R/T - 2WD - Redline2
Stock soccer mom car
2014 Mega 2500 = 2014 Crew Cab 3500 = 2013 Crew Cab 3500 = 2007 Quad Cab 2500 = 2003 Quad Cab 1500
wixthedog is offline
post #3 of 9 Old 03-20-2011, 12:58 AM
TwinStick
There should be an on/off switch on the inverter itself. Your choice, your truck, but I would not hide it away somewhere that it cant dissapate the heat well. They get friggin HOT, when used or left on all the time. Combine that with no airflow or hot airflow & it will have a short life. Mine has 3 fans (2 input & 1 output) & it still gets HOT. I'm just sayin. Also, use bigger wire than you think you need to, that helps keep the wire cooler when use is heavy.
08' PowerWagon w/6-speed manual G-56. 05' 30' toyhauler camper.(10,500lbs)
Hellwig LoadPro 35 bolt on 4 leaf helper springs.
No honey, I'm NOT done buying shit for the truck yet !!!
PurpleCrainium Diff Guards
K&N air filter --- WeatherGuard 20" black bed toolbox.
winch TPC bypass
Dual battery set up w/2 Sears DieHard Platinums-Gp 65 under hood-Gp 31 Marine deep cycle in bed toolbox w/plug-n-play set up. Custom 2000/4000w inverter set up w/quick connect. Triple bike mounts above the bed- custom made by me.
Crapload of recovery gear-always subject to adding more.
Fab Four rear bumper. Soon to be- a BuckStop Baja front bumper.--Temporarily on hold, see reason below.
Installed: Borgeson #000951 steering shaft. PSC steering brace(notched for PW by Rusty-thanks bud). Carli HD CroMo adjustable track bar. Carli CroMo control arms. Carli HD upper & lower balljoints x 2 sets (replaced under warrenty) & triple sealed u-joints in front axle shafts & rear driveshaft. Moog HD tierod ends x 4. Running total is now $4800. Yup, now i'm broke !!!
What, you ask, is the difference between a Dodge Ram and a PowerWagon ?? PW frame part # 55398868AC---Reg 2500 #55398813AC
About 2" taller, 12,000lb winch w/mounting brace between framerails,electronic disconnecting swaybar(for awsome articulation),electronic locking axles front & rear(for true 4-wheel drive),tow pkg, fully skidplated,forged one piece Alcoa rims w/internal beadlock lips,larger diameter(one ton) axleshaft in rear,160 amp alt,HD battery,4.56 gears,low range electronic recalibration of gas pedal sensitivity,more but thinner leafs in rear spring pack(for better articulation), 33" BFG All-Terrain tires. 78.016:1 crawl ratio. All for $6100.00 more! Oh yeah, almost forgot-Bilstein shocks. Gear ratios: 1st 6.29:1 2nd 3.48:1 3rd 2.10:1 4th 1.38:1 5th 1.0:1 6th .79:1.. Rev 5.74:1.
TwinStick is offline
post #4 of 9 Old 03-20-2011, 04:28 PM Thread Starter
kelowna1500
i'm planning on putting the inverter under the passenger seat, just wanna have the convenience (and cool factor, lol) of having the plug and switch in the dash.
post #5 of 9 Old 03-21-2011, 02:40 AM
TwinStick
Thats cool, whatever works for you. For me, it is more convienient not to have any wires/cords going to dash (would interfere with my manual shift) & be able to move the inverter around as needed. When my kids are in the backseat, I have a smaller 400w inverter for them to charge thier phones & MP3 players/computer. Works great. I use my 2000/4000w inverter for HD jobs that require powertools or charging my camper batteries in campgrounds that do not allow ANY generators at all, even the super quiet Honda's.
winch TPC bypass
post #6 of 9 Old 03-21-2011, 08:15 AM
weedahoe
Tricked out Ram
weedahoe's Avatar
Quoted: 21 Post(s)
I also have a power inverter although mine is only a 200 watt. It does everything I need which is to power my Xbox 360 or laptop or cell chargers. It is under my drivers seat but will be in my custom console soon. With that being said, I will also be putting it on a switch but I have a custom switch panel for it and everything else
2004 2wd Dodge Ram QC w/a 5.7 with Royal Purple 5w-20 in the motor, RP Max ATF in the trans, 80-90w in the 4.56 Auburn LSD rolling on American Racing Dale Earnhart "Tank" 24s wrapped in Pirelli 325/45/24s (36" tires)
| Debadged | SRT-10 hood | Custom CAI | Fumoto oil valve | 12" of lift | Power Wire | 9007 Bi-Xenon 6k | 9006 Single Beam 6K | 2nd battery tray (2K CCA total) | Big 3 upgrade w/1ga wire | Altezza clear tails w/LEDs | Clear LED 3rd light | 26gal to 35gal fuel tank swap | Viair 380c air compressor | train horns | Ceramic pads (F&R) | Westin Nerfs | Chrome door/tailgate handles | Custom switch panel | Custom center console | B&M QuickSilver floor shifer | Xbox 360 | Audiobahn A8000V (1600w sub amp) | Audiobahn 2002V (400w mid/high amp) | 2 12" Kicker DVC CVRs in a FoxBox | 4 Kicker DS650s (front & rears) | 2 Kicker KS350s (dash) | 2 8" LCD screens in the sunvisors | 2 6" LCD screens in the headrest | Clifford 50.7x alarm | 20/15% tint | Diablo Trinity - custom and 93 tuned | Mopar 6.1 ignition conversion | Start ignition push button | KRC 210 cam | 6.1 springs & pushrods | 6.1 half covers | 180* T-stat | Taurus E-fan | Pacesetter ceramic LTs | dual DMH cutouts | (2) 4x14" round magnaflows | 4x24" tips | X pipe | Jimmy Jammers | Ported (85mm) TB | Innovate LC-1 wideband | Sonnax transmission pressure booster | Mopar slush mats | RBP grill | powder coated calipers | custom rim/grill lights |
Next projects:
- Custom center console
- B&M Quicksilver Floor shifter
- Custom CAI
weedahoe is offline
post #7 of 9 Old 03-21-2011, 10:36 AM
MonsoonMike
Site Administrator
MonsoonMike's Avatar
Quoted: 228 Post(s)
Craig will have to post pictures. I don't have them handy while I am here at work.
Craig pretty much mounted his under the driver seat. What he did then was took the cover off and cut the switch out. Wired it up to a switch in the dash. That way he can turn on/off the convertor without having to reach under the seat.
BTW.. my wife is from Nanimo BC and parents live in Kelowona. They will be in Arizona in a few days to spend some time out here in the real weather they say.. haha
::2014 Ram 2500 CTD Crew Cab Granite Crystal Metallic::
My Vehicle Build =
MonsoonMike is offline
post #8 of 9 Old 03-21-2011, 03:09 PM
angusdevil
They call me Radio
angusdevil's Avatar
No clue how the stock inverter is designed or wired but I wouldn't put that in the truck to begin with. Just take the factory plug and wire it into the whatever OTHER inverter you want. Depending on what style of inverter and size, it will either be a constant on or have a switch. If it's a switch, you can extend the wires to where you want or have a relay trigger them. If it's constant power, set up a relay to turn it on as depending on the wattage, you may not want 10+ amps running through a switching, getting hot, melting and possibly catching fire.
You're not going to be a able to do factory style wiring job so just bypass all the OEM stuff and start from scratch (minus the actual receptacle)
1973 RCLB Stroker SB
REBUILD BLOG - radio1973dodge.blogspot.com
- Longtravel suspension still being built, Grabber 35" MT's, Method Wheels, 4.10's.
- Custom dash/gauge cluster, Corbeau seats, dual electric fans, most of the wiring replaced, 7" HID's, lots of other flashy and bright lights
- Fuel cell, aluminum rad, rear tranny cooler, front and rear tube bumpers, cut rear rockers and cage work ready to get started on.
angusdevil is offline
post #9 of 9 Old 03-21-2011, 08:57 PM Thread Starter
kelowna1500
hey mike, that's what i was thinking. i'm hoping to use the factory dodge switch in the dash, just don't have a part #, and i don't know if it's wired through the computer or not. nanaimo's a nice place, but yeah i wouldn't mind some arizona weather right now.
    Power Inverter Locations DodgeFan01 3G Dodge RAM - Interior/Exterior Talk 15 03-31-2010 03:28 PM
    Power inverter install Cam02ram 3G Dodge RAM - Interior/Exterior Talk 17 05-12-2006 09:53 PM
    Installing a power inverter Cam02ram 3G Dodge RAM - General Talk 11 05-04-2006 04:50 PM
    Power inverter FreakshowWilly Mobile Audio & Electronics Talk 2 11-23-2005 11:19 PM
    Have to have key in the ignition to use my power inverter. HELP zytariuk Dodge Caravan General Talk 3 11-07-2005 07:54 AM
