Heater Selector Switch Partially Working? - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 15 Old 02-26-2011, 11:45 AM Thread Starter
thelaibon
2001 Dodge Ram Van 1500 here...
Air is not coming out of my dash vents anymore. It comes out of the floor and defroster vents just fine, but not the front dash vents. I took the dash apart and now have access to the directional switch (is that the proper name for this switch?). I can feel the vacuum sucking in air from one of the tubes, so I know that it's sucking in air (plus the defrost and floor vents work anyway) but this doesn't absolve the switch itself. I'm thinking about replacing the switch -- but want to diagnose this properly first. Additionally, is there an aftermarket switch available?
BTW, when this problem first surfaced a week ago, air was NOT going to the floor when I selected floor, or floor/dash mix. I'm assuming that in the process of taking it apart and using WD40 on everything, I somehow managed to jar it and now the floor vents are working properly, but alas the front dash vents are still victim.
Perhaps the switch is the culprit?
thelaibon is offline
post #2 of 15 Old 02-26-2011, 11:56 AM
sovablunt
Certified Mopar Maniac
sovablunt's Avatar
I would check the lines to see if something is plugging them. Maybe trace them back to the blower and check both ends.
*DodgeTalk.com 318 Enthusiast Member #136
1986 B250 daily driver
2000 Grand Caravan Sport wife's daily
1977 D100 Adventurer needs work
sovablunt is offline
post #3 of 15 Old 02-26-2011, 12:06 PM Thread Starter
thelaibon
Thanks for the reply, sova. Any chance u know where I can find a schematic of the vac lines? Not sure where the blower is located. I know the blower resistor is behind the glove box.
Also what's the name of the switch itself in the event that I need to replace it?
post #4 of 15 Old 02-26-2011, 12:50 PM
landyacht318
Off the Grid
landyacht318's Avatar
I hope you did not get WD 40 on any rubber vacuum lines.
Anything with petroleum distillates is detrimental to rubber.
'89 b250 318 TBI
landyacht318 is offline
post #5 of 15 Old 02-26-2011, 12:57 PM Thread Starter
thelaibon
I did... well AFAIK the lines themselves are not rubber but the gaskets/seals appear to be. So this might wear them away in the long term? Hope I didn't shoot myself in the foot in the near future.
post #6 of 15 Old 02-26-2011, 01:42 PM
landyacht318
Off the Grid
Well it's not like it instantly dissolves rubber. Most tire shine products are loaded with petroleum distillates which just accelerate the deterioration of the rubber.
In the future, silicone spray cleans and lubes nicley without being detrimental to rubber. Some contain petroleum distillates only as the propellant and it quickly evaporates.
Before replacing windshield wipers, try cleaning them with rubbing alcohol.
'89 b250 318 TBI
post #7 of 15 Old 02-26-2011, 02:42 PM
alloro
Elder User
Quoted: 19 Post(s)
The blower motor is under the hood. The resistor is also under the hood. The part you're looking at behind the glove box is the blend door motor.
alloro is offline
post #8 of 15 Old 02-26-2011, 02:46 PM Thread Starter
thelaibon
Alright, I've confirmed that the NAME of the switch that I'm looking for is the "mode control."
Update -- now the floor vents are no longer opening/working. Sometimes they work, sometimes they don't. The dash vents are not working at all. It's gotta be the switch.
Thanks to everyone replying so far
post #9 of 15 Old 02-26-2011, 10:10 PM
sovablunt
sovablunt's Avatar
I was wondering, didnt know what the proper name was for it. I think someone on here has posted the diagram before.
post #10 of 15 Old 02-27-2011, 08:15 AM
mylestone
Mylestone
mylestone's Avatar
Quoted: 34 Post(s)
Hi
Go with Alloro he's got the answer,I know, I reconnected 8 vacuum likes and one way valves plus the fan speed resistor under the hood on the fan housing And finally got reliable heat, def,vent,cruse control and 3 fan speeds.Take your time and look for unplugged,cracked vacuum lines!Its a JOB!
Myles
mylestone is offline
post #11 of 15 Old 02-28-2011, 12:00 PM Thread Starter
thelaibon
Update:
Dodge does not sell the mode control separately -- I'd have to buy the entire panel for $168, which includes the blower speed control, temp control, and mode control. No junkyards around have this van either.
Problem is I don't know if the switch is bad or if a vacuum line is bad. Since the dash vents don't work and the floor vents SOMETIMES do, I'm inferring that the more likely culprit is the mode control and not 2 separate vacuum lines (unless of course the dash vents and floor vents share the same line, which I don't know without a diagram).
I'm going to scour for a vac line diagram. If anyone happens to see one let me know!
post #12 of 15 Old 03-02-2011, 11:43 PM
no_common_sense
Quoted: 12 Post(s)
In my experience with the vans, you'll want to look at the plastic vacuum lines coming out of the firewall under the hood. You'll want to look for a rubber grommet with three lines coming out of them and they should be not too far from center but favoring the driver's side. Those plastic lines coming out will all travel to the passenger side toward the heater box and heater control valve(s). These plastic lines always get brittle and crack or break. Because all three of these lines were so prone to breakage, I always used to replace all of them at once. I found replacement plastic tubing but I would only use an inch or an inch and a half worth of the plastic to plug into the grommet. I would then use rubber hose the rest of the length toward the heater box or valves. You can salvage part of the plastic line coming from the heater box as long as the rubber hose gets over in the neighborhood of said heater box where the engine heat is much less prone to brittle the plastic line.
It's been quite a while since I worked on them so I may have some details wrong but this should be reasonably close. My fleet always had front and rear heaters so the configurations might have minor differences on your van anyway. Good luck with your repair.
no_common_sense is offline
post #13 of 15 Old 03-03-2011, 12:40 PM
alloro
Elder User
Quoted: 19 Post(s)
Here is the vacuum pinout and color codes from a 2000, which should be the same as your 2001.
alloro is offline
post #14 of 15 Old 04-06-2011, 12:19 AM
tony4jc
tony4jc's Avatar
Check under the " dog house " on the passenger side of the engine for broken vac lines. I had the same issue with my 99 B3500MW and that fixed it
2005 Town & Country
1999 B3500 Maxiwagon
1998 Grand Caravan base 3.3
1993 Plymouth Grand Voyager LE
1990 Dakota CC
1989 W300 Dump
Previously; 1993 Grand Caravan SE "Sport"
1988 W250 Pick-up
1984 W250 Pick-up
1985 Caravan LE 2.6
1981 B250 225/6
1978 Ramcharger
1975 B300 Maxivan
tony4jc is offline
post #15 of 15 Old 04-06-2011, 01:05 PM
DannyDT
DannyDT's Avatar
I have a control somewhere, i parted out an 01.. I have the same problem with my 98,
swapped out the control, and it' s still in default defrost mode.. so I've got to track mine down too. I'm really glad this thread exist so i know where to start checking for cracked lines. I'd bet yours is the same.
05 Durango 4x4 Hemi - LOVE IT
98 Dodge B2500 wagon - comes in handy!
90 Dodge Ram Van 3500 - sold
94 Dodge Ram van B250 - 8 passenger - Natural Gas 20k miles - sold
*DodgeTalk.com Ram Van/Wagon Member# 74*
DannyDT is offline
    2WD/4WD Selector Switch Light MonsoonMike 3G Dodge RAM - Interior/Exterior Talk 5 08-13-2010 02:54 PM
    Can't Change Vent Selector Switch birdmfc 3G Dodge RAM - General Talk 2 01-12-2010 06:58 PM
    a/c heater selector vacuum hose connections akbmotorsports 1972-1987 Dodge Ram Trucks (D, W-series) 8 12-18-2009 12:50 PM
    Heater/AC selector switch Jack3789 2G Dodge RAM - General Talk 6 07-23-2003 04:05 AM
    Vent Selector Switch Stuck in Defrost! kickhams 2G Dodge Stratus - General Talk 0 05-28-2003 01:15 PM
