2002 Ram 1500 4x4 Oil Pan Removal Problem - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 3 Old 02-22-2011, 01:49 PM Thread Starter
acpfpd
What is the easiest way to remove the pam? Lift the engine or another idea?
acpfpd is offline
post #2 of 3 Old 02-22-2011, 01:51 PM Thread Starter
acpfpd
Help with 2002 Ram oil pan, need help.
acpfpd is offline
post #3 of 3 Old 02-23-2011, 08:08 AM
ghosted mermaid
This is from the 2004 service manual with a hemi. The other engines have a similar procedure.
OIL PAN
REMOVAL
(1) Disconnect the negative battery cable.
(2) Install engine support fixture special tool #
8534. Do not raise engine at this time.
(3) Loosen both left and right side engine mount
through bolts. Do not remove bolts.
(4) Remove the structural dust cover, if equipped.
(5) Drain engine oil.
(6) Remove the front crossmember(Refer to 13 -
FRAME & BUMPERS/FRAME/FRONT CROSSMEMBER
- REMOVAL).
CAUTION: Only raise the engine enough to provide
clearance for oil pan removal. Check for proper
clearance at fan shroud to fan and cowl to intake
manifold.
(7) Raise engine using special tool # 8534 to provide
clearance to remove oil pan.
NOTE: Do not pry on oil pan or oil pan gasket. Gasket
is integral to engine windage tray and does not
come out with oil pan.
(8) Remove the oil pan mounting bolts and oil pan.
NOTE: The double ended oil pan studs must be
installed in the same location that they were
removed from.
(9) Unbolt oil pump pickup tube and remove tube.
(10) Inspect the integral windage tray and gasket
and replace as needed.
INSTALLATION
(1) Clean the oil pan gasket mating surface of the
block and oil pan.
(2) Inspect the integral windage tray and gasket
(3) Reinstall the oil pump pickup tube with new
o-ring. Tighten tube to pump fasteners to 28 Nm
(250 in. lbs.).
removed from.
(4) Position the oil pan and install the mounting
bolts and studs.. Tighten the mounting bolts to 12
Nm (105 in.lbs.).
(5) Lower the engine into mounts using special
tool # 8534.
(6) Install both the left and right side engine
mount through bolts. Tighten the nuts to 68 Nm (50
ft. lbs.).
(7) Remove special tool # 8534.
(8) Install structural dust cover, if equipped.
(9) Install the front crossmember(Refer to 13 -
- INSTALLATION).
(10) Fill engine oil.
(11) Reconnect the negative battery cable.
(12) Start engine and check for leaks.
FRONT CROSSMEMBER
REMOVAL
(1) Raise and support the vehicle. (Refer to
LUBRICATION & MAINTENANCE/HOISTING -
STANDARD PROCEDURE)
(2) Remove the front skid plate, if equipped. (Refer
to 13 - FRAME & BUMPERS/FRAME/FRONT SKID
PLATE - REMOVAL)
(3) Remove the bolts and remove the crossmember.
(Fig. 28) or (Fig. 29)
INSTALLATION
(1) Install the crossmember.
(2) Install the bolts;
On light duty 2WD vehicles, tighten the bolts to
61 Nm (45 ft. lbs.).
On light duty 4WD vehicles, tighten the bolts to
102 Nm (75 ft. lbs.).
On heavy duty 2WD vehicles, tighten the bolts
to 75 Nm (55 ft. lbs.).
(3) Install the front skid plate, if equipped. (Refer
PLATE INSTALLATION)
2004, 1500, 4X4, ST trim level,
RC/SB , 5.7 liter HEMI, 118,200 miles
light almond metalic clear coat...tan
5 speed auto, manual transfer case,
protection group, trailer tow group,
value group, factory bedliner,
4 wheel ABS, sliding window,
bone stock except for K&N drop-in,
toolbox (full of stuff), Valentine One
Prodigy P2 brake controller
ghosted mermaid is offline
    Problem With 2002 Ram 1500 360 Cu. Cold/cool Start secrt007agt 3G Dodge RAM - General Talk 4 12-19-2009 09:53 PM
    Oil Pan Removal on a 2002 1500 Quad 4 x 4 ilimarap 3G Dodge RAM - Drivetrain Talk 0 02-10-2008 09:58 PM
    2002 Ram 1500 problem.... JeffCountyVol 3G Dodge RAM - General Talk 4 09-28-2004 05:34 PM
    2002 QC 1500 4X4 5.9L Problem skizm 3G Dodge RAM - General Talk 2 07-04-2004 06:41 AM
    2002 Ram 1500 - Intermittent Wiper Problem larry0357 3G Dodge RAM - General Talk 8 03-14-2004 11:44 PM
