tranny problem, wont shift past second - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 8 Old 02-20-2011, 06:42 PM Thread Starter
superspec
Quoted: 1 Post(s)
of course the search here sucks soooo. 06 with ats stage 6 tranny wont shift past 2nd and no more than around 20mph. the stock cluster is saying trans temp to high but the tranny will be completely cold. the smarty shows no codes, reset it back to stock. ive got no idea what the problem is!
as thee manual says when you get the trans temp light let it idle and itll go away and sure enough it does. this all happened with normal driving and no load. all fluids are fine.
<---- stumped!
ATS twin turbo setup, ATS stage 5 tranny, TST/Smarty stack, Banks upper intake elbow, Banks intercooler, Banks monstor exhaust...All go, no show!
superspec is offline
post #2 of 8 Old 02-20-2011, 09:05 PM Thread Starter
superspec
Quoted: 1 Post(s)
ok, so after 3 hours of searching google and a few other dodge forums it seems as though the gov. sol. or the temp/pressure sensor may be bad but they recommend changing both at the same time.
can anybody back this up?
post #3 of 8 Old 02-20-2011, 11:57 PM
jaydiesel
I just had the same problem. It was the governor pressure transducer and governor solenoid. It was a long ride home at 20 mph. Note... I did not have the temp light come on and there were no codes.
jaydiesel is offline
post #4 of 8 Old 02-21-2011, 05:07 PM Thread Starter
superspec
Quoted: 1 Post(s)
advice on where to buy the sensors other than the stealership?
post #5 of 8 Old 02-21-2011, 05:17 PM
CDP6.7
CDP6.7's Avatar
Is your transmission still under warranty?
New Truck
2008 GMC Sierra 2500 Duramax, EFI Live, 4" exhaust, 20x9 Moto Metal 962's, Nitto 420's, 3" Belltech drop shackles, more planned
Old Truck
2008 2500 6.7L CTD QCSB 4x4
12.05 @ 111.89 mph, 8800 DA 7/25/12 Fuel only
EFI Live, ATS Twin CP3's, 250hp nozzles, Full billet ATS 47RE w/standalone, Aurora 6000 75/83/1.10 AR, T4 two piece manifold, H-11's, 5.9 intercooler, AFE Stage 2, 5" turbo back no muffler, AirDog 150 X 2, DiPricol gauges, plugged fuel valve, 20x10 black Eagle Alloys on 305/50/R20 Nitto 420's
CDP6.7 is offline
post #6 of 8 Old 02-21-2011, 05:30 PM Thread Starter
superspec
Quoted: 1 Post(s)
its an ATS and it is more than likely out of warranty but even if not those guys are complete a55holes when it comes to customer service. id rather just buy the parts and fix it myself but i would rather not buy from the dealership if i can help it.
post #7 of 8 Old 02-22-2011, 10:29 PM
jaydiesel
I found them online, but I dropped it off at a local tranny shop. It was not a cheap fix. $800+.
post #8 of 8 Old 02-23-2011, 04:58 PM
machman
machman's Avatar
Try http://www.transtar1.com/ They carry the BW solenoid and sensor. Should be around $90-$100 shipped. Part numbers through Transtar are below:
-12432A BW Selenoid
-12415C Governor Pressure Sensor (Transducer)
2006 Ram 3500 Mega Cab
machman is offline
    Tranny wont shift out of Park Ilovemytruck 3G Dodge RAM - Drivetrain Talk 4 11-08-2009 07:33 PM
    tranny wont shift out of 1st HELPPP!!!! y-townxj 2G Dodge RAM - Drivetrain Talk 1 02-07-2008 01:30 PM
    tranny wont shift jdevoe 2G Dodge Stratus - General Talk 2 06-13-2007 01:59 PM
    tranny wont shift out of park ken42 1G Dodge Durango - Drivetrain Talk 3 01-21-2007 01:09 PM
    Tranny wont shift v10sport 2G Dodge RAM - Drivetrain Talk 4 12-30-2004 11:41 PM
