Thread Tools |
red lightning bolt
- Posted: 02-04-2011, 02:59 AM
Post #1
ive been getting a lightning bolt every once in a while. my truck runs when i get it. but when i step on it, it chokes. if i dont pull over and restart it. th truck stops responding. whats wrong with my truck? i heard it got sumthing to do with my throttle body. is this sumthing i could fix? or do i have to take the truck to get looked at by a mechanic.
| Sponsored Links | |
Advertisement |
Posted: 02-04-2011, 05:53 AM
Post #2
Year, make, model and engine? Basically there's an issue with the wireless accelerator pedal not sending signals or the PCM/throttle body not getting signals.
2006 Dodge Ram SLT Quad Cab 1500 4x2 w/Hemi (MDS)2010 Dodge Journey SXT 3.5L V6
Posted: 02-05-2011, 12:18 AM
Post #3
2004 quad SLT 5.7 hemi
Posted: 02-05-2011, 02:03 AM
Post #4
One DT member had a run-away Power Wagon and the problem was in the fly-by-wire TB. Get the truck to the dealer and have it checked before some happens.
Sent via a Texas RoadRunner Varmint ... God Squad July 1972-To Infinity and Beyond-#40 Little Rammie Ridin' Shotgun Club287 Club Member #81 ~ Broken C Clip Club Member ~ Two-Tone Truck Club Member #13 ~ 4.56 R&P Club Member #8 Mighty Cracked Dash Enthusiast Club #11~Mother Earth Raping Big Truck Club Member #25~Truck and Gun Club Member #97 2002 Ram 1500 SLT 4x4 QC - (Nov.01) 4.7L with 89K/3***hrs, 2002 Ram 45RFE Jeep GC TCM Upgrade to 5-45RFE, Knolton Thunder Cylinder Heads & HO Cams by Sawcut, 4.56 R&P/DTT, SRT-10 Pod w/Dynojet Wideband Commander, 2-speed manual transfer case, Clifford Security System w/Auto Start/Auto Windows, RB1 CD/DVD/NAV Infinity Sound System w/30GB iPod, Offroad Package, 33" BFG T/A KO E's, Mopar Rear Wheel Liners, EBC Greenstuff Roadsport Brake Pads, K&N w/Airaid Jr Modular Intake Tube, BBK 70mm Throttle Body, Sonnax Line Pressure Booster, AIR_RAM Jet Stream Scoop, PML Diff Cover, ASP Underdrive Crank Pulley, MSD 1.65 Alt Pulley, Lincoln E-Fan, DCC 2-Speed E-Fan Controller, 180 Jet T-Stat, Denso 160-amp Alternator, Flowmaster SI/DO Exhaust, Accele 3.5" LCD Backup System, Line of Fire LED Light Bar, Sylvania Ultra Silverstars, Hella 500 Black Magic-100W, Nokya Hyper Yellow Fog Lights, $1600 Oil Pick-up Tube thanks Dodge Texas 1845: We the People of the Republic of Texas, acknowledging, with gratitude, the grace and beneficence of God. “Firearms stand next in importance to the constitution itself. They are the American people’s liberty teeth and keystone under independence … from the hour the Pilgrims landed to the present day, events, occurrences and tendencies prove that to ensure peace security and happiness, the rifle and pistol are equally indispensable … the very atmosphere of firearms anywhere restrains evil interference — they deserve a place of honor with all that’s good.” - George Washington
Official DodgeTalk Facebook Page |
Posted: 02-05-2011, 07:53 PM
Post #5
its a simple fix if you know about the wiring
Black 2003 QC SB SLT 4x4 Offroad 5.7L HEMI, Original Owner 3.92 LSD, SRT CAM, 6.1 Rods/Springs, Home Ported/Polished Heads, Psc1, 04 Map sensor and Fuel pump assembly, Oil pressure guage, Amsoil, Champs, MSD 8.5MM Full length Wires, Transgo HD w/out resistor, Superchip, 180 T-Stat, K/N 77 Series, Ceramic Flowtech headers with Y-Pipe, Stage 8 locks, Ditched the cat, O2 sensor mod, Jack Rabbit bed cover, Sprayed bed liner, Big Mouth Grill-Black, Blackend Headlights/Tails, Silverstars, Ditched all chrome, Custom 10's sub enclosure, Upgraded 160 amp alt, Window tint, Relocated purge valve, Energy suspension bushings, Rear spring clamps, Passport 8500 Radar Detector, Ditched the baby seat- kid wasnt mine, Cigarette burn in the seat mod, Debadged, Custom Rewired/Properly Grounded. ![]()
Posted: 02-06-2011, 01:48 PM
Post #6
has nothing to do with wiring, one of three components in the system is malfunctioning and it needs to be put on scanner and checked out
Posted: 02-10-2011, 07:49 AM
Post #7
Mine came on this morning, turned truck off and restarted.. It was then gone and the truck ran fine.
I wonder if it has anything with the negative temps weve had? Is there anything I can check before I goto the dealer, mastertech? Thank you.
2005 Ram 1500 LT 4X4 HEMI REG.CAB |
Posted: 02-10-2011, 10:22 AM
Post #8
Battery &/or alternator should be checked. That is the most common things anyways.
08' PowerWagon w/6-speed manual G-56. 05' 30' toyhauler camper.(10,500lbs) Hellwig LoadPro 35 bolt on 4 leaf helper springs. No honey, I'm NOT done buying shit for the truck yet !!! PurpleCrainium Diff Guards K&N air filter --- WeatherGuard 20" black bed toolbox. winch TPC bypass Dual battery set up w/2 Sears DieHard Platinums-Gp 65 under hood-Gp 31 Marine deep cycle in bed toolbox w/plug-n-play set up. Custom 2000/4000w inverter set up w/quick connect. Triple bike mounts above the bed- custom made by me. Crapload of recovery gear-always subject to adding more. Fab Four rear bumper. Soon to be- a BuckStop Baja front bumper.--Temporarily on hold, see reason below. Installed: Borgeson #000951 steering shaft. PSC steering brace(notched for PW by Rusty-thanks bud). Carli HD CroMo adjustable track bar. Carli CroMo control arms. Carli HD upper & lower balljoints x 2 sets (replaced under warrenty) & triple sealed u-joints in front axle shafts & rear driveshaft. Moog HD tierod ends x 4. Running total is now $4800. Yup, now i'm broke !!! What, you ask, is the difference between a Dodge Ram and a PowerWagon ?? PW frame part # 55398868AC---Reg 2500 #55398813AC About 2" taller, 12,000lb winch w/mounting brace between framerails,electronic disconnecting swaybar(for awsome articulation),electronic locking axles front & rear(for true 4-wheel drive),tow pkg, fully skidplated,forged one piece Alcoa rims w/internal beadlock lips,larger diameter(one ton) axleshaft in rear,160 amp alt,HD battery,4.56 gears,low range electronic recalibration of gas pedal sensitivity,more but thinner leafs in rear spring pack(for better articulation), 33" BFG All-Terrain tires. 78.016:1 crawl ratio. All for $6100.00 more! Oh yeah, almost forgot-Bilstein shocks. Gear ratios: 1st 6.29:1 2nd 3.48:1 3rd 2.10:1 4th 1.38:1 5th 1.0:1 6th .79:1.. Rev 5.74:1. |
Posted: 02-12-2011, 11:49 PM
Post #9
Take your throttle body off the truck and clean it really good. Put it back on. Problem solved. Also check your air filter and make sure its not really dirty.
Posted: 02-15-2011, 03:36 PM
Post #10
Cleaning the TB on my 03 Hemi did the trick too.
In times of sorrow and in times of joy remind thyself, this too shall pass. |
| Thread Tools | |
| Red lightning bolt??? | Pokoki | 3G Dodge RAM - Interior/Exterior Talk | 4 | 02-05-2011 08:04 PM |
| lightning bolt | patriotblueram | 3G Dodge Ram Performance Talk | 31 | 07-21-2010 04:25 PM |
| lightning bolt symbol on dash? | jasonsdakota | 3G Dodge RAM - General Talk | 6 | 01-04-2008 02:30 PM |
| Lightning bolt | 04str8pipe | 2G Dodge Durango General Talk | 8 | 08-31-2007 09:02 PM |
| Flashing lightning bolt in cluster. | ThirdGenNut | 3G Dodge RAM - General Talk | 16 | 01-31-2007 04:06 PM |
Privacy Statement | |
