"burning wire" smell when I turn on my vents? - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 14 Old 01-24-2011, 10:15 AM Thread Starter
jason57gizmo
jason57gizmo's Avatar
Over the last 2 weeks or so, ive noticed that when I turn on my air vents (doesnt matter if a/c is on or off; inside or outside air), there is a faint smell of what I would call burning wire, almost as if there was a wire melting through its casing. I have "sniffed" everywhere while the truck is off, and dont detect anything. As soon as I turn the truck vents on, its somewhat strong, then fading completely away within a few mins. Happens all the time. Ive pulled my dash and radio out to see if anything looked fishy back there, but nothing.
What do you guys feel it might be? I dont have any blown fuses, and everything looks tight. Possible the blower motor or something is giving?
'05 Ram 1500 Quad Cab 5.7 HEMI 4x4 (ThunderRoad)
Sun/moon roof, Leather interior, 20" Rims, t-bars cranked and leveled, Pirelli scorpions 325/60/R20, Yukon 4.56 in front and rear, Detroit Trutrac LSD out back, Aluminium Billet grille (upper and lower)
Alpine CDA-9831, Rockford T15004, JL 1000/1, MB Quart QSD 216's in front (mid range replaced with Dynaudio MW 172) and in rear,2 JL 13W6V2, Audiocontrol EQS, Optima yellow top Battery, DC Power 180 amp alternator (120 amps at idle)
jason57gizmo is offline
post #2 of 14 Old 01-24-2011, 11:58 AM
angusdevil
They call me Radio
angusdevil's Avatar
Have you been using the heater any more recently?
1973 RCLB Stroker SB
REBUILD BLOG - radio1973dodge.blogspot.com
- Longtravel suspension still being built, Grabber 35" MT's, Method Wheels, 4.10's.
- Custom dash/gauge cluster, Corbeau seats, dual electric fans, most of the wiring replaced, 7" HID's, lots of other flashy and bright lights
- Fuel cell, aluminum rad, rear tranny cooler, front and rear tube bumpers, cut rear rockers and cage work ready to get started on.
angusdevil is offline
post #3 of 14 Old 01-24-2011, 12:09 PM Thread Starter
jason57gizmo
No, I don't use it much at all
post #4 of 14 Old 01-24-2011, 12:16 PM
HEMISith
HEMISith's Avatar
"Dust in the wind..." Oh wait, sorry that's a Kansas song....maybe burning dust?
2004 Dodge Ram 1500 4X4 QC 5.7L 345 HEMI
GONE!
HEMISith is offline
post #5 of 14 Old 01-24-2011, 12:17 PM
angusdevil
They call me Radio
angusdevil's Avatar
That's kinda what I figured. If you don't use your heater much and then all the sudden use it, it can have a similar smell for quite a while even if you don't use it again. Happens ever winter here AZ.
post #6 of 14 Old 01-24-2011, 12:34 PM
RubberFrog
I RECOMMEND FUKKEN WAX
RubberFrog's Avatar
dust
'07 QCSB, Flame Red 5.7 4x4 SLT
Performance:
Internal: Custom Cam, 180 T-Stat - Intake: Ported Throttle Body, K&N Filter - Exhaust: Edelbrock Shorties, Magnaflow Y Pipe, Raceland Cutout, Dumped Gibson Catback
Tuning & Monitoring: SuperChimps, Aeroforce Interceptor w/ afr
Suspension & Tires:
Lift: 6" Suspension, 3" Body Lift - Wheels: Custom Painted BMF S.O.T.A.s, 37" Trail Grapplers, Mopar Wheel Well Liners
Appearance:
Bed: Leer 100XQ Shell, Line-x XTRA, Defender Roof Rack - Other: SRT Hood, Bushwacker Pocket Flares,Tow Mirrors, Nerf Bars, 2500 Tow Hooks, Shorty Antenna, Tactical Grill
AV:
Tunes: Kenwood DDX512, Infinity Reference Speakers, Kicker 10" Sub, Kicker 400.1 Amp, FoxBox - Video: 10.4" TFT-LCD Flip-down Overhead Monitor, R Cam, Chuck Norris Kicked My Ass
Lighting:
Led Tails, Smoked Cab Lights, 4x VisionX 180w, Hella 500's
RubberFrog is offline
post #7 of 14 Old 01-24-2011, 01:27 PM
TwinStick
Yup, just like when i turn our funace on in the house.
08' PowerWagon w/6-speed manual G-56. 05' 30' toyhauler camper.(10,500lbs)
Hellwig LoadPro 35 bolt on 4 leaf helper springs.
No honey, I'm NOT done buying shit for the truck yet !!!
PurpleCrainium Diff Guards
K&N air filter --- WeatherGuard 20" black bed toolbox.
winch TPC bypass
Dual battery set up w/2 Sears DieHard Platinums-Gp 65 under hood-Gp 31 Marine deep cycle in bed toolbox w/plug-n-play set up. Custom 2000/4000w inverter set up w/quick connect. Triple bike mounts above the bed- custom made by me.
Crapload of recovery gear-always subject to adding more.
Fab Four rear bumper. Soon to be- a BuckStop Baja front bumper.--Temporarily on hold, see reason below.
Installed: Borgeson #000951 steering shaft. PSC steering brace(notched for PW by Rusty-thanks bud). Carli HD CroMo adjustable track bar. Carli CroMo control arms. Carli HD upper & lower balljoints x 2 sets (replaced under warrenty) & triple sealed u-joints in front axle shafts & rear driveshaft. Moog HD tierod ends x 4. Running total is now $4800. Yup, now i'm broke !!!
What, you ask, is the difference between a Dodge Ram and a PowerWagon ?? PW frame part # 55398868AC---Reg 2500 #55398813AC
About 2" taller, 12,000lb winch w/mounting brace between framerails,electronic disconnecting swaybar(for awsome articulation),electronic locking axles front & rear(for true 4-wheel drive),tow pkg, fully skidplated,forged one piece Alcoa rims w/internal beadlock lips,larger diameter(one ton) axleshaft in rear,160 amp alt,HD battery,4.56 gears,low range electronic recalibration of gas pedal sensitivity,more but thinner leafs in rear spring pack(for better articulation), 33" BFG All-Terrain tires. 78.016:1 crawl ratio. All for $6100.00 more! Oh yeah, almost forgot-Bilstein shocks. Gear ratios: 1st 6.29:1 2nd 3.48:1 3rd 2.10:1 4th 1.38:1 5th 1.0:1 6th .79:1.. Rev 5.74:1.
TwinStick is offline
post #8 of 14 Old 01-24-2011, 01:57 PM
Bent
or Heater speed load resistor .
the times I've smelled burning from the vents in an automotive environment was either when the load resistor was about to fail, or when the fan motor brushes were about to fail
(I've experienced both).
Bent is offline
post #9 of 14 Old 01-24-2011, 06:16 PM
Hemi_2500
Bigg Rigg
Hemi_2500's Avatar
I have been having this exact problem also. I figuered is was my fan speed control resistors going out.
Proud Member of the White Truck Club #77
Proud Member of the Military Truck Club #10
2013 Dodge Dart Limited Turbo
2003 Dodge Ram 2500 Hemi
2015 Dodge Journey Limited
Hemi_2500 is offline
post #10 of 14 Old 01-25-2011, 12:06 AM
99Slobra
Biggin
99Slobra's Avatar
I got this when I cranked open my a/c mode the other morning to use my heater on a cold 35 degree morning..
Freaked me out for a second..hahaha
2004 2500 Hemi R/C 4x4 on 35's
K&N CAI
Bilstein 5100's
Black Magic 183
SC 3865
Not loud enough
99Slobra is offline
post #11 of 14 Old 01-26-2011, 08:51 AM Thread Starter
jason57gizmo
I hope that's all it is. Sounds like it makes sense. Is there an easy way to clean out/off the dust/dirt that causes this smell?
post #12 of 14 Old 01-26-2011, 11:18 PM
99Slobra
Biggin
99Slobra's Avatar
use it more often? lol
K&N CAI
Bilstein 5100's
Black Magic 183
SC 3865
Not loud enough
99Slobra is offline
post #13 of 14 Old 03-29-2011, 08:30 AM Thread Starter
jason57gizmo
Ive got to say, it looks like you were right. It was probably some dust burning on the rarely used heater. It has completely gone away.
post #14 of 14 Old 03-29-2011, 02:49 PM
99Slobra
Biggin
99Slobra's Avatar
yeah kinda weird. Never had it on any other vehicle.
K&N CAI
Bilstein 5100's
Black Magic 183
SC 3865
Not loud enough
99Slobra is offline
    a/c went out... burning smell moparman2k2 3G Dodge RAM - General Talk 3 05-31-2010 10:58 PM
    08: remove front cupholder; turn off "change oil" GaryMN Dodge Caravan General Talk 3 01-24-2010 03:09 PM
    "smoke" from vents Monkie 2G Dodge RAM - General Talk 11 04-27-2009 06:13 PM
    windows fog, dog barks...."vapor" through center dash vents....1990 B350 maxi... jhs Dodge B-Series Vans 1971 - 2003 4 04-20-2009 08:43 AM
    02 Dodge Ram AC "Wild Vents" stratos50 3G Dodge RAM - General Talk 7 07-27-2008 08:46 PM
