Keyless Entry Problems - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 13 Old 01-23-2011, 04:25 AM Thread Starter
tuffguy
Has anyone been having problems with their keyless entry? On my 2010 ram, the lock feature and the remote start feature work fine. I have been having problems with the unlock portion. It will not unlock 9 times out of 10, doesn't matter if I'm 30 feet away or 1 foot away . If I use the remote to start the truck, it will unlock it: if its running. With both remotes; I have the same problem. I have an appointment to get this checked out, I was curious if others have had a similar problem and what the result was. Thanks.
10 Dodge 1500 CC 4x4
tuffguy is offline
post #2 of 13 Old 01-23-2011, 06:11 AM
BTbt
My 09 sometimes will not unlock as well, hit lock then unlock most times gets it to unlock, too close to side of truck seems to be worse.I have not taken it back for this yet.Been like this since new, 38000 kms ago.
BTbt is offline
post #3 of 13 Old 01-23-2011, 06:15 AM
BMRbrnSNRbrd
Try harder
BMRbrnSNRbrd's Avatar
I have a '10 and the fob works flawlessly...
Mineral Gray 2010 Dodge Ram CC Hemi Sport
Exterior: Limo tint | Painted tips | Painted calipers | De-badged | Painted grill inserts | Gloss black b-pillars | Color matched antenna base |
VHT tinted puddle lights | Color matched tailgate handle | Shaved and two-toned grill | Painted Vararam lid w/ two-toned Ram badge |
Color matched Laramie 2500 flares | Shaved tailgate badge | Shortened and painted antenna
Lighting: Color matched headlights retrofitted with 5000k Morimoto projectors |
5000k HID fog lights tinted with Lamin-x | 6000k HID retrofitted reverse lights
Interior: Color matched interior plastics | 2 MTX 12" subs in a cheap box | REN MyGig 30gb headunit | Black microsuede wrapped headliner and sun visors | Black microsuede wrapped and shaved pillars | Black microsuede wrapped custom made door inserts | SEM black painted interior plastics
Suspension: McGaughy's 2/5 Economy drop | BrakeMotive cross-drilled and slotted rotors | All black Milano M724 22s | 305/40R22 Nitto 420s | AirLift Helper Bags
Performance: Superchips Vivid Paq w/ trans tuning | Vararam Air Grabber | Magnaflow 18" Muffler | Raceland USA E-Cutout |
Billet Technology Oil Catch Can | Clutch fan delete | 180 T-stat | Magnaflow Y-Pipe with relocated crossover pipe
BMRbrnSNRbrd is offline
post #4 of 13 Old 01-23-2011, 06:16 AM
dwins1900
dwins1900's Avatar
Do you guys have your evic display programmed to unlock/lock all four doors at once. when I changed that in the evic settings that fixed mine. one push of the button and they opened right up.
dwins1900 is offline
post #5 of 13 Old 01-23-2011, 08:19 AM
2014LaramieCrew
2014LaramieCrew's Avatar
Quoted: 9 Post(s)
Pop the fob apart and clean the battery contacts. Check battery voltage while open.
2014 Laramie 4x4 CC 6.5' bed
2014LaramieCrew is offline
post #6 of 13 Old 01-23-2011, 09:49 AM
dwins1900
dwins1900's Avatar
Yes Ive heard of people doing this also with good results. those things get dirty in your pockets
post #7 of 13 Old 01-23-2011, 04:01 PM Thread Starter
tuffguy
Thanks for the ideas. Mine is set up to open all 4 doors at once. I have the same problem with both fobs. The one I actually use and the one that hangs on the key rack all of the time.
tuffguy is offline
post #8 of 13 Old 01-23-2011, 05:14 PM
ChryslerTech
ChryslerTech's Avatar
There's a flash update for the FOBs on 2010s only
'09 Quad Cab Monotone Laramie/Sport Conversion, Bushwacker Pocket Flares, ProComp 6 inch lift, RevTek 2 inch spacers, 3" Body Lift, 35x13.5x20, ProComp, 20x10 Rockstars, Predator, 4.56s -Traded in- ROTM Feb '11
'11 2500 Laramie, 8" BDS lift, 37x12.5x 20 BFG KM2s on 20" Eagle 079s, Predator, Bushwacker flares
ChryslerTech is offline
post #9 of 13 Old 01-26-2011, 11:34 AM
Marchboom
Marchboom's Avatar
If the fob is getting enough voltage to operate the "lock" feature, why would the voltage be any different for the "unlock" feature?
Maybe the contacts on the "unlock" part of the switch are not making a good contact.
My 2009 Ram does the same thing. The lock operation works fine but it doesn't always unlock. Have to hit the button a few times.
John
2009 Dodge Ram 1500, 4X4, Crew Cab, Hemi, 3.55, Bright Silver.
Marchboom is offline
post #10 of 13 Old 01-26-2011, 12:37 PM
Moparn4life
My 09 operates just the same as yours. Lock works every time - unlock sometimes takes multiple clicks.
2009 Ram 1500 Crew TRX4
Moparn4life is offline
post #11 of 13 Old 01-26-2011, 02:02 PM
Marchboom
Marchboom's Avatar
I'm wondering if the factory has addressed this problem?
John
post #12 of 13 Old 07-10-2011, 05:35 PM
marsolais
Back from Iraq & lovin it
marsolais's Avatar
How do you do this?
2010 Ram 1500 Quad Cab 4X4 Big Horn Hemi.
2009 Ram 1500 Quad Cab 4X4 ST 4.7L (lemon).
2010 HD Street Glide.
2007 CBR1000RR Repsol (sold).
2007 YZ450F (sold).
2004 ZX6R 636 Full track bike (sold).
What do all soldiers have in common?
No matter how strong we are TAPS will always bring a tear to our eye, for we have endeared more than most people can fathom. We have fought and died on lands far from home for reasons many will never understand.
1LT Kaylor I will never forget you or your message.
PFC Tuazon, ride on fellow 293rd soldier. “Best of the Best”
marsolais is offline
post #13 of 13 Old 07-10-2011, 07:28 PM
topgun
topgun's Avatar
There is a flash for 2010 and 2011 but not 2009. Read somewhere that the 09 supplier and part was slightly different so the software would need to be different. So no flash for the 09's.
Got the same issue here and it's not the fob itself causing the problem.
2012 2500 HD Hemi Crew Outdoorsman 4X4, Black and MG
Cooper AT3's, Bedrug, AMP Power Steps, Corsa Exhaust, Undercover SE, S&B Intake, Moroso Catch Can
topgun is offline
    factory keyless entry install on a non-keyless model magnumsgt 2G Dodge RAM - General Talk 2 09-29-2009 09:25 PM
    Keyless Entry help DodgeD 98 1G Dodge Durango General Talk 2 01-16-2008 07:36 AM
    keyless entry porkchop2245 3G Dodge RAM - General Talk 0 03-27-2007 07:29 PM
    keyless entry out RonG 2G Dodge Durango General Talk 4 12-27-2006 12:13 PM
    keyless entry on NON-factory keyless entry truck 79rallysport 3G Dodge RAM - General Talk 9 10-08-2006 10:43 AM
