pcv valve - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 18 Old 01-18-2011, 06:41 PM Thread Starter
Travs4X4Ram
Travs4X4Ram's Avatar
pcv valve
Where is the pcv valve on an 08 4.7L? I know previous years it was on the oil filler tube, but I am having a hard time locating it. I tried the search feature, but came up nothing.
Thanks guys!!
08' Ram 4.7L QCSB Big Horn 4x4
K&N Drop-in, Hella 500FF's, Philips' CrystalVision Ultras in the heads, fogs, and Hella's, Westin step rails,
ProCaps bed rail caps, DeeZee bed mat, stubbie antenna, additional back-up lights, EZ Down tailgate damper,
Synthetic fluids througout, 275/60/20 Cooper Discoverer AT3
Travs4X4Ram is offline
post #2 of 18 Old 01-18-2011, 06:49 PM
SilsHemi
Dodge Fanatic!
Next to TB.
Sil
SilsHemi is offline
post #3 of 18 Old 01-18-2011, 07:57 PM
01off-road
Pretty sure that picture is just for the HEMI.
01off-road is offline
post #4 of 18 Old 01-18-2011, 08:00 PM
01off-road
Oil filler tube.
post #5 of 18 Old 01-18-2011, 08:02 PM
dmcelhannon
Admin - David Mack
dmcelhannon's Avatar
Quoted: 247 Post(s)
No; I don't think that it.
dmcelhannon is offline
post #6 of 18 Old 01-18-2011, 08:02 PM
01off-road
post #7 of 18 Old 01-18-2011, 08:20 PM
SilsHemi
Dodge Fanatic!
Yep. My bad.
I know they've moved the PCV valve around in the 4.7's.
Sil
SilsHemi is offline
post #8 of 18 Old 01-18-2011, 08:21 PM
dmcelhannon
Admin - David Mack
Quoted: 247 Post(s)
#6
I couldn't find it ... thanks.
... you should spell out your acronym.
post #9 of 18 Old 01-19-2011, 06:45 AM
weedahoe
Tricked out Ram
weedahoe's Avatar
Quoted: 21 Post(s)
Good to know info.
2004 2wd Dodge Ram QC w/a 5.7 with Royal Purple 5w-20 in the motor, RP Max ATF in the trans, 80-90w in the 4.56 Auburn LSD rolling on American Racing Dale Earnhart "Tank" 24s wrapped in Pirelli 325/45/24s (36" tires)
| Debadged | SRT-10 hood | Custom CAI | Fumoto oil valve | 12" of lift | Power Wire | 9007 Bi-Xenon 6k | 9006 Single Beam 6K | 2nd battery tray (2K CCA total) | Big 3 upgrade w/1ga wire | Altezza clear tails w/LEDs | Clear LED 3rd light | 26gal to 35gal fuel tank swap | Viair 380c air compressor | train horns | Ceramic pads (F&R) | Westin Nerfs | Chrome door/tailgate handles | Custom switch panel | Custom center console | B&M QuickSilver floor shifer | Xbox 360 | Audiobahn A8000V (1600w sub amp) | Audiobahn 2002V (400w mid/high amp) | 2 12" Kicker DVC CVRs in a FoxBox | 4 Kicker DS650s (front & rears) | 2 Kicker KS350s (dash) | 2 8" LCD screens in the sunvisors | 2 6" LCD screens in the headrest | Clifford 50.7x alarm | 20/15% tint | Diablo Trinity - custom and 93 tuned | Mopar 6.1 ignition conversion | Start ignition push button | KRC 210 cam | 6.1 springs & pushrods | 6.1 half covers | 180* T-stat | Taurus E-fan | Pacesetter ceramic LTs | dual DMH cutouts | (2) 4x14" round magnaflows | 4x24" tips | X pipe | Jimmy Jammers | Ported (85mm) TB | Innovate LC-1 wideband | Sonnax transmission pressure booster | Mopar slush mats | RBP grill | powder coated calipers | custom rim/grill lights |
Next projects:
- Custom center console
- B&M Quicksilver Floor shifter
- Custom CAI
weedahoe is offline
post #10 of 18 Old 01-19-2011, 02:01 PM Thread Starter
Travs4X4Ram
Its not on the oil filler tube. The the filler tube is on the drivers side of the engine, where as in previous models it was on the passenger side.
post #11 of 18 Old 01-19-2011, 03:32 PM
01off-road
Ok. Forgot the 4.7 changed in 08. Do u have a Chilten (sp) manual or alldatadiy account? That will tell you.
post #12 of 18 Old 01-19-2011, 05:28 PM Thread Starter
Travs4X4Ram
I looked on other forums, and I think it is on the driver side valve cover. I had to work today, so I was not able to check.
post #13 of 18 Old 01-19-2011, 07:18 PM
frazier79
Squiddy
frazier79's Avatar
i'd be interested to learn its location as well. how often should a positive crankcase ventilation valve be swapped, anyways?
2012 2500 ST CC 4x4
Gone, But Never Forgotten -
2008 QCSB 4.7l 6speed manual 4wd
3.92 gears Y Pipe Magnaflow
frazier79 is offline
post #14 of 18 Old 01-19-2011, 07:19 PM
01off-road
That's interesting. I need to prolly change mine out. Kinda never even thought about it.
post #15 of 18 Old 01-19-2011, 09:53 PM
wrenchin4alivin
[[[[[[[Paul]]]]]]]
wrenchin4alivin's Avatar
Thumbs up PCV
Thanks guys!!
The PCV valve (2) is mounted into the top/rear of the left valve cover.
Disconnect plastic line (1) from end of PCV valve.
Use a small screwdriver to disengage PCV valve from valve cover.
2002 QC 1500 4.7 2wd
wrenchin4alivin is offline
post #16 of 18 Old 01-19-2011, 10:08 PM
naztyram23
naztyram23's Avatar
I have always done the rattle test. If it rattles when you shake it its good to go. If it doesn't then its gummed up and needs to be changed out.
2003 QC 1500
Current "MOD" List:
Headman shorty's/180 t-stat/Black magic E-fan/ 6.1 cam, springs and pushrods/456 gear/detroit tru tac locker/Nitrous outlet nano kit
/FJO progressive window switch/stage three sharadon valve body/moes ported throttle body/hoosier slicks/cal-tracs/flowmaster 40 series/vararam/diablo sport tuner/ Morso Drag shocks/ Light bar with hella lights/ PML diff cover/LC-1 wide band/ DMH e-cutout
"MOD" to get:
Inertia motorsports p&p heads.
Pround Member of the United States Army
naztyram23 is offline
post #17 of 18 Old 01-19-2011, 10:31 PM
dmcelhannon
Admin - David Mack
Quoted: 247 Post(s)
If you have the 4.7L engine, you need to be sure you clean out the hose and tube that connects to the PCV. They can collect water and crap from the crankcase and keep the PCV stsyem from working.
... FYI
post #18 of 18 Old 01-20-2011, 07:06 PM Thread Starter
Travs4X4Ram
Yeah, I have heard about the rattle test, but I bought a new PCV valve for $6 at the dealership, so might as well just change it.
    custom valve spring tool for changing cam/valve springs weedahoe For Sale - Truck Parts 21 01-20-2011 11:25 AM
    How common are valve spring/broken valve issues on 03 Rams? Theo911 3G Dodge RAM - General Talk 2 02-03-2010 07:05 AM
    Combo valve/RWAL valve truckman323 2G Dodge RAM - General Talk 0 08-17-2009 09:17 PM
    ERG Valve ke7bgy@canby.co 2G Dodge RAM - General Talk 2 12-13-2004 02:11 PM
