Limp mode on 3-4 shift 99 Durango P0753 - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 17 Old 01-13-2011, 10:31 AM Thread Starter
zukgod1
zukgod1's Avatar
99
5.9
47re (I think, it's been a few years.)
So here's the deal.
Bought this truck with a bad trans, rebuilt it (with help from member here) with some better parts and it's been working great for the last 5 years and 22k miles.
A while back I was getting a random check engine light and limp mode, it would come and go so I decided to dig into it and after a couple hours of testing using Identifix/ Mitchell testing procedures for the code I had (P0753) I came up with a bad PCM. replaced it had it re-flashed for my vin and accy at the dealer and drove it for about a month with no problems then it started coming back.
Decided to go ahead ahead and service the trans and installed all new electronics while there so everything in the trans is new and adjusted the bands as well and replaced the trans pigtail.
Now it is an instant limp/ check engine light upon the 3-4 shift, driving with OD off it's fine.
I'm about to drive this into something really solid at this point so before I commit Ins fraud I decided I would ask for help here
99, SLT, Leather, 4x4, 5.9, T/S lift, tint, DVD, Magnaflow exhaust, CAI, trans built with all kinds of go fast parts, back under the D and it actually works!!
zukgod1 is offline
post #2 of 17 Old 01-13-2011, 10:46 AM
tactransman
Transmission Man!
tactransman's Avatar
What code is it tripping now? Oh .. and you have a 46RE.
Terry aka tactransman
'99 Ram 1500 4X4 5.9 Automatic #110 in the White Truck Club
Aren't you tired of getting your parts for your Super Bee from a kid that thinks a Civic is a "hot rod"!
Mods:
MSD Blaster 3 Coil
Magna Flow Cat and "Y" pipe
46RE Built to the Hilt
Transgo TF OD JR Shift Kit (With Mods)
Billet Cover Converter
Upgraded to five direct clutch drum
Five Overdrive Brake Clutch pack
47RE STEEL front planetary
Sonnax Reverse servo parts
HD Kevlar Lined Rigid Int Band
Deep Pan w/cooling tubes
3.8 ratio Int lever
billet Int servo struts
tactransman is offline
post #3 of 17 Old 01-13-2011, 10:58 AM Thread Starter
zukgod1
zukgod1's Avatar
Same code P0753.
Last night I looked in the Trans part of the PCM and found a Generator field code so I spent a couple hours following that around, it all checked good.
Currently however all I have is the P0753, it does not show as pending or current unless I turn off the OD switch and left it attempt to shift in to 4th.
zukgod1 is offline
post #4 of 17 Old 01-13-2011, 11:02 AM
tactransman
Transmission Man!
Code Description: P0753 - Trans 3-4 Shift Solenoid / Trans Relay Circuits
Functional Operation; 4th gear operation is provided electrically through the OD solenoid. The voltage in the OD Solenoid control circuit is monitored by the PCM whenever the key is on. If the actual circuit voltage is different than the expected voltage, code P0753 will set.
Possible Causes;
# Failed Transmission Control Relay
# Failed OD Solenoid
# Open or shorted OD Solenoid control circuit
# Open or shorted Trans Control Relay output circuit
# Open or shorted Fused B+ circuit
# PCM - Internal failure
DIAGNOSTIC ROUTINES
1. Be sure to perform the Preliminary Tests
2. If any of the following codes are present, diagnose them first; P1765
3. Disconnect the solenoid connector at the transmission and check for the presence of battery voltage at pin #1 with the engine running. If there is no voltage present, perform test P1765.
4. If codes P0743, P0748 and P0753 are all present, and you have 12 volts at pin # 1 of the solenoid connector, replace the TCC / OD solenoid assembly.
5. Disconnect the solenoid connector at the transmission to test the OD Solenoid. Connect an ohmmeter across pin# 6 and pin# 1 of the solenoid connector on the transmission side. The resistance should be between 25 & 60 ohms. If not, replace the TCC / OD Solenoid assembly.
6. Measure the resistance between pin# 6 of the solenoid connector (transmission side) and a good ground. If you have less than 5 ohms, replace the TCC / OD Solenoid assembly.
7. Disconnect the solenoid connector at the transmission to test the internal wiring. Make sure that your Governor Solenoid connector (inside the pan) is plugged in if you disconnected it in the previous step. Connect an ohmmeter across the pins of the solenoid connector on the transmission side. Resistance values should be as follows;
* Between pin# 6 and pin# 2 = above 100K ohms
* Between pin# 6 and pin# 3 = above 100K ohms
* Between pin# 6 and pin# 4 = above 100K ohms
* Between pin# 6 and pin# 5 = 28 - 68 ohms
* Between pin# 6 and pin# 7 = 50 - 120 ohms
* Between pin# 6 and pin# 8 = above 100K ohms
If any of the resistance values (above) are not within specs, replace the TCC / OD solenoid assembly.
8. Check the integrity of the OD Solenoid control circuit from the PCM connector to the transmission solenoid connector.
9. Check the OD Solenoid control circuit for a short to ground.
10. Check the OD Solenoid control circuit for a short to voltage.
11. Check the integrity of the Trans Control Relay output circuit from the Trans Control Relay connector to the solenoid connector.
12. Check the Trans Control Relay output circuit for a short to ground.
13. Disconnect all three PCM connectors. Disconnect the solenoid connector at the transmission and measure the resistance across pin# 6 and every other pin in the connector. Each pin should measure over 100K ohms. If you have under 100K ohms between pin# 6 and any other circuit in the connector, repair the wiring harness for wiring shorted together.
14. If all other possible causes have been eliminated, replace the Powertrain Control Module (PCM).
Mods:
MSD Blaster 3 Coil
3.8 ratio Int lever
post #5 of 17 Old 01-13-2011, 11:30 AM Thread Starter
zukgod1
zukgod1's Avatar
Been there/ done that tested good but as I posted I replaced everything electronic in side it anyway to eliminate the possibility of an intermittent failed part plus I replaced the pigtail at the trans.
Previously using Identifix testing procedures I diagnosed a bad PCM, replaced it. Had the same problem so I replaced it again (so 2 new PCM's now). problem persists.
Now the code is instant instead of random so I made something mad.
I've tested the harness between the PCM and trans looking for a break in a wire somewhere/ nope.
Tested resistance on everything as directed via Mitchel and the factory repair manual. Nothing.
Tested and replaced the Trans relay.
If I go through all these tests I still come up with the conclusion the PCM is bad but how can I get 3 bad PCM's? 4 if you count the original PCM also.
zukgod1 is offline
post #6 of 17 Old 01-13-2011, 12:07 PM
tactransman
Transmission Man!
Try by passing the relay. See if it shifts OK.
Mods:
MSD Blaster 3 Coil
3.8 ratio Int lever
post #7 of 17 Old 01-13-2011, 01:09 PM Thread Starter
zukgod1
zukgod1's Avatar
I'm out for a test drive.
zukgod1 is offline
post #8 of 17 Old 01-13-2011, 09:02 PM Thread Starter
zukgod1
zukgod1's Avatar
Works fine with the relay by-passed.
Shifts through all 4 gears, converter locks etc.
SO WTH???
PCM again?
zukgod1 is offline
post #9 of 17 Old 01-14-2011, 07:12 AM
tactransman
Transmission Man!
That is what I figured. The computer is seeing a problem with the wiring some where (tripping the code) and is killing the power to the relay turning off the relay and taking your 12 volts away from the transmission. You have a wiring problem some where.
This does bug me also though" Last night I looked in the Trans part of the PCM and found a Generator field code so I spent a couple hours following that around, it all checked good." Some where I remember reading that the alternator can cause the relay to not be activated, let me do some checking today.
Mods:
MSD Blaster 3 Coil
3.8 ratio Int lever
post #10 of 17 Old 01-14-2011, 10:14 AM Thread Starter
zukgod1
zukgod1's Avatar
The reading I did showed it needs 10v in that circuit to keep the relay working. At idle it has about 8.7v then anything above idle it goes to 10.5-11v but I dont have a way to monitor that field when driving to see if the voltage drove or not.
zukgod1 is offline
post #11 of 17 Old 01-14-2011, 12:38 PM Thread Starter
zukgod1
zukgod1's Avatar
Just for gits and shiggles (and because I have parts houses at the ready) I installed a new alt and went for a drive.
Shifts fine, no limp mode.
It does shift into 4th a bit late but it shifts..... I'm so confused.
zukgod1 is offline
post #12 of 17 Old 01-16-2011, 01:30 AM Thread Starter
zukgod1
zukgod1's Avatar
Well after a new alternator and about 100 miles it's shifting great.
I'm stil in TOTAL amazement that the secondary field in the alternator will screw up the trans control relay/shifting. Trust me though it does.
zukgod1 is offline
post #13 of 17 Old 01-25-2011, 02:32 PM Thread Starter
zukgod1
zukgod1's Avatar
Well SONOFA!!!!
Code has returned.
Lasted for just over a week..
Suggestions on something really solid to run into?
zukgod1 is offline
post #14 of 17 Old 01-25-2011, 02:38 PM
tactransman
Transmission Man!
Is it still tripping it "instant"? It seems like the alt did something if it took this long. Hum .............................?
Mods:
MSD Blaster 3 Coil
3.8 ratio Int lever
post #15 of 17 Old 01-25-2011, 03:02 PM Thread Starter
zukgod1
zukgod1's Avatar
No it's not instant.
I reset it for the wife this morning and she drove it approx 25 miles from home to babysitters and on the return trip it set.
Leaving a stop sign.
She didn't tell me about it last night as she knows I'm getting frustrated and there are train tracks no to far from our house.
Durango + Train = Train win Durango looses..
zukgod1 is offline
post #16 of 17 Old 03-15-2011, 11:13 PM
76-warlock
any update on this? I'm having the same problem right now.
HEY YA'LL WATCH THIS!!!!!
1999 "D" w/360 4wd 2"T/S 32" procomp allterrain
1976 d-100 Warlock 2wd w/ 318 and a true 4-speed!!!
318 Enthusiast member #(123)
76-warlock is offline
post #17 of 17 Old 03-16-2011, 04:22 PM Thread Starter
zukgod1
zukgod1's Avatar
At this point I have it parked it in a dark corner of the shop.
The light continues to randomly pop up.
I have ran new wires from the ECM to the Trans relay for not only the control but power and ground are ran new as well. The only OE wire left is the one going directly to the trans.
Dont forget I have replaced the pigtail with a new OE pigtail already.
But for now as far as my Durango is concerned its staying in the corner until either I see fit to spend more time on it OR I hack out the stock axles and toss in some new Dana 60's and make it a crawler.
zukgod1 is offline
    Help!!!!! Limp Mode 03RamMar1ne 3G Dodge RAM - Drivetrain Talk 1 05-05-2009 03:11 PM
    How do I get out of limp mode? Gusaroo Dodge Caravan General Talk 5 04-10-2009 12:33 PM
    Limp Mode 05moparsilver 3G Dodge Ram Performance Talk 7 05-24-2008 11:27 PM
    Limp mode Gregjy 3G Dodge RAM - General Talk 1 03-15-2008 03:01 PM
    Limp mode xswinnyx 2G Dodge Intrepid - General Talk 6 05-19-2006 01:08 PM
