Code PO138, damn O2 sensor, how to change - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 6 Old 01-01-2011, 01:29 PM Thread Starter
V2Rider
V2Rider's Avatar
Quoted: 10 Post(s)
Its the driver side after the CAT sensor, after doing a search on here. My CEL came on today, but for hours of driving, so engine symptoms or anything. Got home, hooked up my Hypertech programmer, and it gave me the PO138 code. I searched here and found out what it is, but need to know if I can change it, or if a dealer will need to. I am mechanically good, just never changed an O2 sensor on a Ram. I know it probably wont hurt much, except may want to run a little rich, if I clear the code, but want to fix it. Any help, or walk through appreciated. Thanks.
Previous:2003 Ram 2500 HD 4X4, Sold but not forgotten
Current: 2015 Dodge Ram 1500 Laramie CC Black on Black, FULLY loaded
AMSOIL
V2Rider is offline
post #2 of 6 Old 01-01-2011, 01:35 PM
GreatWhiteNorth
It's as easy as changing plugs. I think it's a 22mm wrench to remove it from the bung, and the electrical end is just a plug.
'03 4.7 QCSB 4x4 5spd manual
Performance Mods: Flex-a-lite 180 e-fan, Magnaflow cat back kit, Powerwire, Yukon 4.56s, Ported Heads, SCT Tuned by HemiFever, 70MM TB from Stampede4.7, Magnaflow Y-pipe, Paxton Novi 2000 Super Charger, 206 Cams
Appearance Mods: T-Bar crank, Cooper Discoverer S/T 265/70/17, Debadged, Color matched handles and mirrors
GreatWhiteNorth is offline
post #3 of 6 Old 01-01-2011, 01:38 PM Thread Starter
V2Rider
V2Rider's Avatar
Quoted: 10 Post(s)
Ok thanks, everything is closed today, so I will have to wait. I just won't drive it right now. Is it something I should be able to get at just crawling under the truck, or do I need to lift it up?
AMSOIL
V2Rider is offline
post #4 of 6 Old 01-01-2011, 01:41 PM
silverhemidan
Silverhemidan
silverhemidan's Avatar
Quoted: 2 Post(s)
I would try taking it out and cleaning it 1st,the electrical side too. and then clear the code and see if it comes back on.
I just had the same problem,cleaned it and so far I'm good.
PS:I did not have to raise my vehicle..
from a manual
The Oxygen Sensors (O2S) are attached to, and protrude into the vehicle exhaust system. Depending on the
engine or emission package, the vehicle may use a total of either 2 or 4 sensors.
Federal Emission Packages : Two sensors are used: upstream (referred to as 1/1) and downstream (referred to as
1/2). With this emission package, the upstream sensor (1/1) is located just before the main catalytic convertor. The
downstream sensor (1/2) is located just after the main catalytic convertor.
California Emission Packages: On this emissions package, 4 sensors are used: 2 upstream (referred to as 1/1
and 2/1) and 2 downstream (referred to as 1/2 and 2/2). With this emission package, the right upstream sensor (2/1)
is located in the right exhaust downpipe just before the mini-catalytic convertor. The left upstream sensor (1/1) is
located in the left exhaust downpipe just before the mini-catalytic convertor. The right downstream sensor (2/2) is
located in the right exhaust downpipe just after the mini-catalytic convertor, and before the main catalytic convertor.
The left downstream sensor (1/2) is located in the left exhaust downpipe just after the mini-catalytic convertor, and
REMOVAL
CAUTION: Never apply any type of grease to the oxygen sensor electrical connector, or attempt any soldering
of the sensor wiring harness.
WARNING: THE EXHAUST MANIFOLD, EXHAUST PIPES AND CATALYTIC CONVERTER BECOME VERY HOT
DURING ENGINE OPERATION. ALLOW ENGINE TO COOL BEFORE REMOVING OXYGEN SENSOR.
1. Raise and support vehicle.
2. Disconnect wire connector from O2S sensor.
CAUTION: When disconnecting sensor electrical
connector, do not pull directly on wire going into
sensor.
3. Remove O2S sensor with an oxygen sensor
removal and installation tool.
4. Clean threads in exhaust pipe using appropriate
tap.
INSTALLATION
Threads of new oxygen sensors are factory coated
with anti-seize compound to aid in removal. DO NOT
add any additional anti-seize compound to threads
of a new oxygen sensor.
1. Install O2S sensor. Tighten to 30 N·m (22 ft. lbs.)
torque.
2. Connect O2S sensor wire connector.
3. Lower vehicle.
Silver Truck Club Member#127
2004 2500 Hemi - Off-Road Pkg.w/4.56's
6" Lift PP Long Arms/Coils/Bilstein 5160's/ Dynatrac free spin hubs/Dynaloc hubs/spicer axle ujoints,
Carli Ball Joints/Carli deaver 4" leaf springs/Thuren Shackles/Carli Long Travel Air Bags
37x12.5x17 Cooper STT's/XD Enduros
n-fab step bars with Line-X
MagnaFlow (#14329)/Superchips
20% tinted windows Don Thuren steering stabilizer True Flow CAI
Tonneau cover/Husky liners/4-channel Amp/
Rockford sub/ Panasonic HU/kenwood speakers Hella 500's behind grill/Wheel Liners/Bushwacker Pocket style flares/Aeroforce Interceptor/BD Steering Box Stabilizer/steering upgrade,Carli Trackbar/ retrofit projectors,infiniti FX35 projectors,shaved,black matte paint,6k,from Unique Coatings.
silverhemidan is offline
post #5 of 6 Old 01-01-2011, 01:43 PM Thread Starter
V2Rider
V2Rider's Avatar
Quoted: 10 Post(s)
So I need a special tool for this? Damn, I almost thought I was going to just go take it out and clean it.
AMSOIL
V2Rider is offline
post #6 of 6 Old 01-01-2011, 01:48 PM
silverhemidan
Silverhemidan
Quoted: 2 Post(s)
No,you might be able to get it with a wrench,I was able too.
I don't remember what size it was.
the sensors after the cat are the easier ones.Atleast on my truck
    Code P0406 (EGR Sensor A High)...false code??? gwhite 2G Dodge Durango General Talk 9 07-20-2010 12:01 PM
    OBD Code PO138 newuser 2G Dodge Ram Performance Talk 1 03-04-2010 07:12 AM
    How to change your TPS - Throttle Position Sensor Error Code P0121 tomk 3G Dodge RAM - General Talk 4 09-20-2007 03:18 PM
    Damn broke my little sensor? mitchgmace 3G Dodge RAM - General Talk 4 08-05-2006 07:55 PM
