fuel line - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 11 Old 12-27-2010, 11:02 PM Thread Starter
njram2500
dodgeram2500
njram2500's Avatar
fuel line
i did my fuel pump today and i broke one of the plastic piece connection that goes fuel line its a little rubber quick disconnect piece that goes to the fuel pump can i just replace the hole plastic piece or do i have to buy a hole line with it and if so how involved is it to replace the fuel line
96 ram 1500 5.9 (360) ext cab long bed
k and n air intake
airaid throttle body spacer
265/75r16 treadwright max trax m/t (E)
pacesetter shorty headers with a hi flow manaflow cat in to a supper 44 muffer duel out the rear
Rebuilt trans
3.55 gears
Rebuilt transfer case
(93) sct tunner by hemifeaver
njram2500 is offline
post #2 of 11 Old 12-28-2010, 09:02 AM
mad 1
mad 1's Avatar
they do have out a repair kit ,,,, has the fuel quick disconect 90 and fuel line with a brass you slip the two plastic tubing over,,, heat the tubing to make more flexiable
and when cools draws tight ans seals,,, if too hot will melt hole,,,
they say to heat hot water but hard to do the fuel line on truck
hot air gun or hair dryer might be better,,,
2011 Ram Power Wagon
1997 Ram 1500 5.2 auto 4x4 ext
SCT tune by Hemifever, Fastman 50mm,14x3 open air cleaner, Magnaflow,4:11,, 265/75/16
1993 Jeep YJ4.6 Stroker,, 5 speed,
Alum. head, roller rocker, Duel header, Magnaflow,,4:56,, 33" MTRS,, 2"' lift, Warn Wench, Nates Bumpers
2007 700 Yahama Grizzly ATV
Maxis Bighorns, Power tip,, Play Ground SE Kentucky
2009 Blast 150 Toybox F/S
mad 1 is offline
post #3 of 11 Old 12-28-2010, 09:13 AM
mad 1
mad 1's Avatar
that kit
Dorman Products:
800-060
should be chyr 3/8 with 90 on end
mad 1 is offline
post #4 of 11 Old 12-28-2010, 12:06 PM
Moparite
Moparite's Avatar
Quoted: 302 Post(s)
I went to the Dorman Products website and nothing came up for that #. Did a search and only thing they have for the fuel system is the filler neck.
Moparite is offline
post #5 of 11 Old 12-28-2010, 12:39 PM
97Ram_4X4
97Ram_4X4's Avatar
When mine broke mine I could not find the repair kit.I ordered a new line from the dealer an it was 85.00 about 3 years ago
1997 Ram 1500 5.2 4X4
2002 Dakota Sport 4.7 4X4
2003 Durango 4.7 4X4
97Ram_4X4 is offline
post #6 of 11 Old 12-29-2010, 03:01 AM Thread Starter
njram2500
dodgeram2500
njram2500's Avatar
uhh just more problems lol, i made a rubber hose piece that i clamped on the fuel line just for now. Than i got every thing back up and i go to prime the fuel pump a couple times then i looked underneath it was leaking like a siv so i looked a my fuel line and it was cracked in two places. so i went to the dealership and attempted to order a direct fit fuel line that would fit. what a mistake that was lol the guy was on the computer for like 10 mins trying to figure out the diagram and to see what line i need so we finally figured everything out. Then he goes on to tell me that they do not make that fuel line any more and he cannot order it. so i left angry and pissed and i just ended up taking it to a shop and have them bend a new fuel line. but thanks for the help sorry i couldn't use it lol
k and n air intake
Rebuilt trans
3.55 gears
post #7 of 11 Old 12-29-2010, 09:46 AM
mad 1
mad 1's Avatar
dorman under fuel system,,, fuel line connectors and retainers
called Quick Connection 90 degree w/18 '" nylon tube
check your line size ,,they have a 5/16 and 3/8
the two parts 800-059 or 800-060
belived i used the 3/8 800-059
rechecked with parts house and looked up my self
went by part catagory not by vehical search
mark
mad 1 is offline
post #8 of 11 Old 12-31-2010, 09:25 PM
Xray
Quoted: 12 Post(s)
Hmm, I bought a fuel line from a dealer for my 96 last summer.
I would have just made my own and saved $50, but I preferred a 1 piece to a 2, which is what you'd have to settle for doing it yourself.
I'd get under there and make sure they didn't install it half assed. Lines should be flared where they connect, no part of the fuel line should be in contact with the frame.
Xray is offline
post #9 of 11 Old 01-01-2011, 01:39 PM
Moparite
Moparite's Avatar
Quoted: 302 Post(s)
I went to NAPA the other day with two Dorman #'s. I measured my fuel line and it is 5/16 but not sure what's on the pump. They have one made by Dorman with their name on it. The guy looked it up but they are not vehicle specific. Make sure you know what sizes you have beforehand. Does anyone know what size the pump fitting is? I think it is also 5/16. NAPA didn't have one(fuel pump) to check it with. I have a hose also on mine because the fitting broke when i went to take it off when changing the fuel pump. Worked ok for about 8 months and then started to leak. I tightened the clamps but need to be replaced. Luckily my steel line ok.
Moparite is offline
post #10 of 11 Old 01-01-2011, 08:00 PM
posram
rusty ol' turd
posram's Avatar
if your fuel lines are that rusty, have the shop check the brake line too, i'd bet it's no better. I've used a fuel line repair kit with the quick disconnect for a 04+ Ford Crown Vic, it worked just fine.
1995 Ram 2500 4X4 5.9 Magnum NV4500.
posram is offline
post #11 of 11 Old 01-01-2011, 09:47 PM Thread Starter
njram2500
dodgeram2500
njram2500's Avatar
ok they replaced the new fuel line looks good i can take pics if you guys want to see it. well 400 dollars later every thing is fixed and i think my break lines were replaced when i got the truck
k and n air intake
Rebuilt trans
3.55 gears
    fuel leaking form fuel line at fuel rail CduB 2G Dodge RAM - General Talk 12 06-16-2010 11:48 PM
    3rd Gen 4.7L Fuel Rail/Line (No Fuel Injectors Needed) W0rLDWaR4 Wanted - Dodge Truck Parts 0 12-20-2009 05:25 PM
    which fuel line is the pressue side or feed line????? STOVEBOLT Dodge Ram Truck 1st Gen (88 - 93) Forum 2 10-04-2009 10:04 PM
    o-ring fuel line to fuel rail stavenstumper Dodge Intrepid 1st Gen (93 - 97) 1 01-19-2008 06:25 PM
    fuel line fuel rail P Larkin 2G Dodge Ram Performance Talk 2 11-19-2004 10:50 AM
