Can't fill tank with gas! - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 40 Old 12-20-2010, 09:06 PM Thread Starter
jason13
jason13's Avatar
I think I have exhausted my searching abilities looking to see if I could find an answer to this problem. Any input would help, I am stumped...
A few days ago I let the wife drive my truck to a training she had in the mountains and needed the 4x4 rather than the Charger (her normal car). Prior to leaving she filled my tank all the way up to full. She came home and I drove the truck around for a few days longer and needed to get some fuel. Here is where things start to get weird...
I get to the Shell Station I have been filling up at for years, (Fleet Card) and try to put gas into the tank. Immediately the pump kicks off as if the tank were full. I knew this was not the case, I mean after all it is a Hemi and loves to drink fuel... I tried a few more times. Once again as soon as the fuel would start to flow it would click right off. So I figured it was a pump problem. I move to a different pump and low and behold the same issue is happening. They guy comes out (noticed I was having issues) and asked me, "Are you sure it's not full?" Feeling like an idiot already I say that I was sure it wasn't full after a 250 mile trip. I got frustrated and ended up leaving with the few dollars I could get in the tank in about 10 minutes of trying.
So I take the truck home, do some research into this issue and found one other thread relating to the same issue. Only problem is that the guy said he used a pressure washer and thought he may have cleared a vent tube in the process. I don't want to spray water in any vent tubes at this point..
A day later, I go to a completely different gas station and sure enough.... Same problem. I spend about 20min letting gas trickle into the tank (got like 3 gallons in ten min). Got just enough gas in the tank to get where I needed to go and back.
So my question is: Can anyone direct me as to where to start on this one? I am fairly good with mechanics, done lifts on my own, small motor projects, etc... I would rather do this myself than take it somewhere for someone to "guess" as to what the problem is.
Any help would be greatly appreciated.
Jason
2006 Ram 2500
6" Suspension Lift
38x13.50x20 Toyos
jason13 is offline
post #2 of 40 Old 12-20-2010, 09:16 PM
darkness80
darkness80's Avatar
sounds like you got some gas in the vent tube....can easily happen if the tank gets over filled....not sure where the vent is on the rams but if you can track it down, you may be able to get the fluid out. should be an easy fix.
SOLD...2006 ram lone star, QC 4x4, flame red, painted stock 20's, painted grille,LED fogs...HEMI..
Painted Stock Wheels Club #5
darkness80 is offline
post #3 of 40 Old 12-20-2010, 09:27 PM
MonsoonMike
Site Administrator
MonsoonMike's Avatar
Quoted: 229 Post(s)
Was gonna say the vent tube is blocked some how?
::2014 Ram 2500 CTD Crew Cab Granite Crystal Metallic::
My Vehicle Build =
MonsoonMike is offline
post #4 of 40 Old 12-20-2010, 09:37 PM Thread Starter
jason13
jason13's Avatar
Do you guys know if this is the tube that goes back up to the filler kneck? It looks like that vent could come off, but then i am unsure if I should shoot some air in there with the compressor or if I risk messing something else up by doing it. Thank you so much for the replies. DT rocks! I will definately post the resolution when I find it.
J.
2006 Ram 2500
6" Suspension Lift
38x13.50x20 Toyos
jason13 is offline
post #5 of 40 Old 12-20-2010, 10:29 PM
darkness80
darkness80's Avatar
i do believe the vent tube goes to the filler neck....cause if the tank gets to full i know it can go in to the vent...but i think there is a back flo valve so you may not be able to shoot air into it it. id try some small air tubing and try to syphon out the fluid
post #6 of 40 Old 12-20-2010, 10:31 PM
rye
Moderator
rye's Avatar
I also believe the tube comes up to the filler neck, and you should be able to spray some compressed air in the tube to clear it out before you try and replace it. Wear safety goggles for this one though.
DODGETALK.COM MODERATOR
5.9 2003 1500 4x4
Official Dodgetalk Facebook Page:
rye is offline
post #7 of 40 Old 12-20-2010, 10:32 PM
99Slobra
Biggin
99Slobra's Avatar
goggles and close your mouth..lol
Fuel usually ruins the taste of things for awhile..haha
2004 2500 Hemi R/C 4x4 on 35's
K&N CAI
Bilstein 5100's
Black Magic 183
SC 3865
Not loud enough
99Slobra is offline
post #8 of 40 Old 12-21-2010, 03:13 PM
RTHemi2
I have the same issue. It was bad for a while, seemed to clear itself up for a month or two, and now it is doing it again.
I can get about 1 or 2 gallons going slow and it will kick off. After the tank gets about half full, I can actually go nearly full speed the rest of the way.
2005 Quad Cab 4x4, Big Horn Edition, Flame Red, Swiss Cap
Color Match Bug Shield, 2008 Stock 20's, Mostly Debadged,
Alpine CD, Infinity door speakers, Memphis Audio amp and subs,
Mopar "Ram" floor mats for summer, Weather Tech for winter,
Line-X, Rumble Bee Scoop w/ billet insert, Billet bumper insert,
Wrangler Silent Armor's, Lotsa gas money.
RTHemi2 is offline
post #9 of 40 Old 12-21-2010, 03:34 PM
Shots
Don't fear the sheepdog
Shots's Avatar
Quoted: 134 Post(s)
Well FWIW my patrol car (yeah yeah it's a Ford) actually does this if I have the nozzle all the way in. If I put it in all the way, pull it out about .5", then start filling, I can fill at almost full speed. I guess I should tell the service guy but I never really think about it until I'm at the gas station. You may want to try that until you can figure out how to resolve your problem.
Shots:
2014 CC Sport 4x4
Mods:
Level / Zone lift / Tint 50 fronts 10 backs / Custom BedRug / Extang Solid Fold / Partial Debadge / Mickey Thompson Baja MTZ 315-70-17 on Classic III rims / PSI Autorestyling flares / Pacer cab lights
If only you could understand what it's like to go home to your family, greeted with smiles and kisses like any other day, and not have the heart to tell them you almost didn't make it home. Respect those who protect and serve.
The unwanted, being underpaid, who will go unappreciated, doing the unthinkable, for the ungrateful.
Shots is offline
post #10 of 40 Old 12-21-2010, 04:16 PM
jerry cole
check for recalls or rrt's at your dealer
jerry cole is offline
post #11 of 40 Old 12-21-2010, 04:19 PM
weedahoe
Tricked out Ram
weedahoe's Avatar
Quoted: 21 Post(s)
There is a check valve in the tank. Normally we see guys who are trying to fill their tank and in doing so, right as it gets full it kicks off and fuels flows out the filler hose. From my understanding, you dont replace the check valve. You replace the tank.
2004 2wd Dodge Ram QC w/a 5.7 with Royal Purple 5w-20 in the motor, RP Max ATF in the trans, 80-90w in the 4.56 Auburn LSD rolling on American Racing Dale Earnhart "Tank" 24s wrapped in Pirelli 325/45/24s (36" tires)
| Debadged | SRT-10 hood | Custom CAI | Fumoto oil valve | 12" of lift | Power Wire | 9007 Bi-Xenon 6k | 9006 Single Beam 6K | 2nd battery tray (2K CCA total) | Big 3 upgrade w/1ga wire | Altezza clear tails w/LEDs | Clear LED 3rd light | 26gal to 35gal fuel tank swap | Viair 380c air compressor | train horns | Ceramic pads (F&R) | Westin Nerfs | Chrome door/tailgate handles | Custom switch panel | Custom center console | B&M QuickSilver floor shifer | Xbox 360 | Audiobahn A8000V (1600w sub amp) | Audiobahn 2002V (400w mid/high amp) | 2 12" Kicker DVC CVRs in a FoxBox | 4 Kicker DS650s (front & rears) | 2 Kicker KS350s (dash) | 2 8" LCD screens in the sunvisors | 2 6" LCD screens in the headrest | Clifford 50.7x alarm | 20/15% tint | Diablo Trinity - custom and 93 tuned | Mopar 6.1 ignition conversion | Start ignition push button | KRC 210 cam | 6.1 springs & pushrods | 6.1 half covers | 180* T-stat | Taurus E-fan | Pacesetter ceramic LTs | dual DMH cutouts | (2) 4x14" round magnaflows | 4x24" tips | X pipe | Jimmy Jammers | Ported (85mm) TB | Innovate LC-1 wideband | Sonnax transmission pressure booster | Mopar slush mats | RBP grill | powder coated calipers | custom rim/grill lights |
Next projects:
- Custom center console
- B&M Quicksilver Floor shifter
- Custom CAI
weedahoe is offline
post #12 of 40 Old 12-21-2010, 04:58 PM
Rocky31186
Rocky31186's Avatar
Correct, if its the check valve (we see it on 90's toyotas all the time now) You have to replace the tank...
Sounds to me like its the vent hose.. No evap engine lights?
2006 Jeep GCSRT8 6.1L AWD
BT Catch Can - FRI LilBoy Cam - Magnaflow Exhaust - Vortech V-3 Blower - Johan Tuned - Stage I Injectors - Aero340 Fuel Pump - Eibach Lowering Kit - Boost/AirFuel/Fuel Pressure Gauges.
Rocky31186 is offline
post #13 of 40 Old 12-21-2010, 05:15 PM
NHHEMI
NHHEMI's Avatar
Same issue here. It comes and goes. It just did it to me earlier today. It is worse when it is under 1/2 tank. If I top off at 1/2 tank + or once I hit 1/2 tank while filling it seems to go ok. Before that it clicks off every few seconds and is a royal PITA!
2011 Jeep Patriot
"Latitude"
4WD 2.4L
Royal Purple #1
NHHEMI is offline
post #14 of 40 Old 12-21-2010, 08:31 PM Thread Starter
jason13
jason13's Avatar
Well i am glad to see I am not alone on this. I have no check engine lights on or any issues with the way the truck runs. Just can gas 'er up! LOL
Maybe with the gas prices here in Cali this is a good thing?
I am going to pull the vent tubing off this weekend provided we get some dry weather. I thought about just taking off one end and blowing (please hold the comments). I figured this may not be the best option if there is something in there as it could end up in the tank or some other place that the "clog" could end up. I will post as to my findings after the job. Sounds like a few folks could use a solution to this.
J.
2006 Ram 2500
6" Suspension Lift
38x13.50x20 Toyos
jason13 is offline
post #15 of 40 Old 12-21-2010, 08:39 PM
Marx
Marx's Avatar
just put the nozzle in halfway and it should fill up, mine also does this if the pumps are fast flowing
remember its the pump that turns off the gas not your truck
05' 5.7L HEMI 1500, leveled, 35x12.50R18 Nitto Trail Grappler's on CR Black Iron Villian's, Blistein 5100's, K&N drop-in air filter, Magnaflow exhaust, Blue LED dash.
Marx is offline
post #16 of 40 Old 12-21-2010, 08:43 PM Thread Starter
jason13
jason13's Avatar
Thanks for the "tip". LOL
All joking aside... I tried pulling it half way out, I treid holding the little ribbed cover on the nozzle back sort of like you would if you were filling a 2 gallon plastic gas can. To my surprise the damn pump still kicked off. I evern tried different gas stations... Nothing. At this point just so I can get around, I think I am going to fill my 5 gallon cans and then fill it with the can rather than the pump. Like I said above, I will post the resolution as soon as I find it.
I am greatly aprriciative of the responses so far. Thanks for all who have contributed to this annoying problem of mine. I just finished reading the post from a guy with his piston through the wall of his Hemi.... Makes this isssue seem a little minor. I wish him the best of luck.
J.
2006 Ram 2500
6" Suspension Lift
38x13.50x20 Toyos
jason13 is offline
post #17 of 40 Old 12-21-2010, 09:27 PM
Will225
Will225's Avatar
Have you tried sticking a screw driver down the fill line to see if anything is clogging it?
And while you have the screw driver down there (holding the flip thing open) go ahead and start the truck. This should unclog it by the rush of air.
2015 6.7L Cummins MegaCab 4x4 Laramie
GOD Squad: 1981 - Eternity!
Military Club Member #74
Will225 is offline
post #18 of 40 Old 12-21-2010, 10:01 PM
RamLion
Victims arent we all
RamLion's Avatar
if you want to make your gas pumping faster prior to your getn the tank fixed...just fill up a 5gallon jug or a ten gall jug and pour it into tank..would seem a little faster....
4/6.5 inch mcgauphys/belltech combo,springs and spindle..
RamLion is offline
post #19 of 40 Old 12-21-2010, 10:04 PM
TwinStick
I had this happen once on my 2000 Dakota. Turns out someone was siphoning gas out, must have almost got caught & the hose they were using was still in the gas fill tube, just went down in & was enough to not allow full flow from pump into tank. I removed the hose from the gas cap area (from behind), removed hose & no more problems.
08' PowerWagon w/6-speed manual G-56. 05' 30' toyhauler camper.(10,500lbs)
Hellwig LoadPro 35 bolt on 4 leaf helper springs.
No honey, I'm NOT done buying shit for the truck yet !!!
PurpleCrainium Diff Guards
K&N air filter --- WeatherGuard 20" black bed toolbox.
winch TPC bypass
Dual battery set up w/2 Sears DieHard Platinums-Gp 65 under hood-Gp 31 Marine deep cycle in bed toolbox w/plug-n-play set up. Custom 2000/4000w inverter set up w/quick connect. Triple bike mounts above the bed- custom made by me.
Crapload of recovery gear-always subject to adding more.
Fab Four rear bumper. Soon to be- a BuckStop Baja front bumper.--Temporarily on hold, see reason below.
Installed: Borgeson #000951 steering shaft. PSC steering brace(notched for PW by Rusty-thanks bud). Carli HD CroMo adjustable track bar. Carli CroMo control arms. Carli HD upper & lower balljoints x 2 sets (replaced under warrenty) & triple sealed u-joints in front axle shafts & rear driveshaft. Moog HD tierod ends x 4. Running total is now $4800. Yup, now i'm broke !!!
What, you ask, is the difference between a Dodge Ram and a PowerWagon ?? PW frame part # 55398868AC---Reg 2500 #55398813AC
About 2" taller, 12,000lb winch w/mounting brace between framerails,electronic disconnecting swaybar(for awsome articulation),electronic locking axles front & rear(for true 4-wheel drive),tow pkg, fully skidplated,forged one piece Alcoa rims w/internal beadlock lips,larger diameter(one ton) axleshaft in rear,160 amp alt,HD battery,4.56 gears,low range electronic recalibration of gas pedal sensitivity,more but thinner leafs in rear spring pack(for better articulation), 33" BFG All-Terrain tires. 78.016:1 crawl ratio. All for $6100.00 more! Oh yeah, almost forgot-Bilstein shocks. Gear ratios: 1st 6.29:1 2nd 3.48:1 3rd 2.10:1 4th 1.38:1 5th 1.0:1 6th .79:1.. Rev 5.74:1.
TwinStick is offline
post #20 of 40 Old 12-22-2010, 06:33 AM
weedahoe
Tricked out Ram
weedahoe's Avatar
Quoted: 21 Post(s)
Maybe try fueling up slower instead of letting the pump run wide open to fill the tank faster
Next projects:
- Custom CAI
weedahoe is offline
    Gas Tank Won't Fill Right? I Might Have the Answer! fins2fuselage 1972-1987 Dodge Ram Trucks (D, W-series) 0 09-15-2008 09:51 PM
    Is it true that a full tank of diesel burns slower than a full tank of gas? Darcity 3G Dodge RAM Diesel Talk 9 05-21-2008 10:45 PM
    Gas Fill Up mmastinRT 1G Dodge Durango General Talk 6 05-06-2008 12:53 PM
    How much money to fill your tank? 04SLTHemi 2G Dodge Durango General Talk 31 10-28-2005 11:06 PM
