truck stuck in 4 wheel drive mode - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 7 Old 12-19-2010, 12:40 AM Thread Starter
vardenafil3
today it rained//snowed on the way to work. i had the truck in 4 wheel high. i never got my speeds above 35 to 40 mph on my trip. when i turned in to the parking lot at work my truck started hopping. i immediately took the truck out of 4 wheel drive. i figured it was hopping because it was in 4wheel high. as i turned into a parking stall the truck started to hop again even though i was in 2 wheel drive. i made a few trips around the parking lot. the truck seems as it wont leave 4 wheel drive as it hops when i make turns. the 4x4 light is not on indicating the truck is not in 4 wheel drive. the 4x4 shifter will shift from 4 high through neutral to 4 lo and back. but when ever i drive it in 2wheel mode it still feels like its in 4wheel mode. i never had this problem before usually i just throw the selection lever in 2 wheel drive position then im good. any suggestions on how to get my truck unstuck?
vardenafil3 is offline
post #2 of 7 Old 12-19-2010, 01:16 AM
dmcelhannon
Admin - David Mack
dmcelhannon's Avatar
Quoted: 247 Post(s)
I'm not 100% ... there has been some threads where members have had problems like this and it was dirty wiring harness connections or solenoids. The first thing I would try is a spray wash to clean the tranny and then put some dialectic grease inside the connectors. If that doesn’t solve it, I have a tranny shop give it a quick look.
dmcelhannon is offline
post #3 of 7 Old 12-19-2010, 01:19 AM
!05RAM05!
Previously Micash21
!05RAM05!'s Avatar
Mine did this the other day. I actually had to revert to old school 4x4 methods. Stop, drive in reverse for about 15-20 feet, then go forward again. You have this feeling like something is "dragging"
New: 2005 Dodge Ram 1500 QCSB 4x4 Hemi Laramie Bright Silver
Flowmaster SI/DO 40 Series. Superchips 3865 - 91 Tune, 2/4 drop, More to come............
::GONE BUT NOT FORGOTTEN::2005 Dodge Ram 1500 QCSB 4x4 Hemi Sport Black
5.5" Rough Country Lift, Dick Cepek DC2 20x9, 325/60R20 Nitto Terra Grappler's, Superchips 3865 - 91 Tune, Extang Tonneau Cover, K&N Cold Air Intake, Bosch Platinum 4 plugs, Magnaflow Y-Pipe, SI/DO Flowmaster Original 40 Series, Synthetic Everything, 7000K Headlights, Foglights and Hellas..
1998 Dodge Durango SLT 4x4 Black
Hypertech 87 Tune, K&N Cold Air Intake, Bosch Platinum 4 plugs, Bosch 8.5mm Wires. Ported Throttle Body, SI/DO Flowmaster Original 40 Series Muffler, Headman Headers, 3" PA BL, 2" T/S Lift, 33x12.50R15 Firestone Destination M/T's, 15x8 Eagle Alloy Wheels.
BTC Member 211 - Steel Reserve
!05RAM05! is offline
post #4 of 7 Old 12-19-2010, 06:31 PM
mirada80
2005 Hemi Ram
mirada80's Avatar
Quoted: 2 Post(s)
x2 my brother had same problem in 06 dakota and this fixed it. Its actually what the dealership said to try.
2004.5 2500 QC SB 4x4 5.9 H.O.
MODS | Studded | Cold Air | 5" Turbo Back | Fass Fuel | Tinted Windows | HIDS
03 Silver Dodge Ram 1500 4x2 5.7 Hemi
MODS | Home Brew Ram Air CAI | Superchips 3815 | Comp Custom Grind Cam | 6.1 Springs And Pushrods | 06+ Coil Conversion | High Idle Mod | Summit Racing 25% Underdrive | Circle D 3200 245mm converter l TMR Mod | Sonnax Line Pressure Booster | Pacesetter Longtubes l Matching Off Road Y-Pipe l Magnaflow 14" SI/SO muffler | Electric Fan | 180 Stat | Walbro 255 With 05 Sending Unit | Auburn Limited Slip| B&M ProStick Ratchet Shifter | Custom Gauges | Custom Shifter Surrond | Ventvisors | Debadged | Tinted Tails | Tinted Third Brake Light | Smoked Headlights | 5000k HIDS in heads | 3000k HIDS in fogs | Roll Pan | Shorty Antenna | Custom Painted Grill | Street Scene Bumper | Poor mans 2/4 Drop | Dipped 17" Ram SS/T Wheels With Radials | 2009+ Chrome 20's | And A Little Bit of ZEX
BEST 1/8-Motor-8.43@80.52__Spray-7.85@89.12
BEST 1/4-Motor-13.38@98.9_Spray-12.27@110.42
BEST 60'-1.75
SOLD05 Patriot Blue Pearl Dodge Ram 1500 4x4 5.7 Hemi
mirada80 is offline
post #5 of 7 Old 12-19-2010, 11:23 PM Thread Starter
vardenafil3
thanks guys that worked. i got it unstuck. appreciated the advice
post #6 of 7 Old 12-20-2010, 06:29 PM
mirada80
2005 Hemi Ram
mirada80's Avatar
Quoted: 2 Post(s)
Welcome
BEST 60'-1.75
mirada80 is offline
post #7 of 7 Old 12-22-2010, 08:09 AM
rockmanm35
rockmanm35's Avatar
Usually backing has worked for me on all types of 4WD.
rockmanm35 is offline
    Stuck in 4 wheel drive after going to Pep-Boys to diangose AC.... sorka 2G Dodge Durango General Talk 7 06-09-2010 02:22 PM
    truck seems like its stuck in 4 wheel RaiderRex1200 3G Dodge RAM - 4X4 Talk 6 02-17-2010 11:38 AM
    Code 26 & Stuck in 2Limp Mode Beyonder Dodge Caravan General Talk 3 07-12-2009 06:37 PM
    2002 Dodge Durango Stuck in Drive - Wheel Dragging s0lidgr0und 1G Dodge Durango - Drivetrain Talk 4 12-15-2007 07:25 PM
    Transmission is stuck in limp mode ????? SixT8Chevl 3G Dodge RAM Diesel Talk 0 05-15-2007 06:54 PM
