2004 no heat only blows cold air - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 18 Old 12-18-2010, 06:51 PM Thread Starter
haf2race
Just started today, no heat. Is there a heater control valve? Is the heater core stopped up? Any ideas. I'll start working on it tomorrow morning. Thanks for help.
haf2race is offline
post #2 of 18 Old 12-18-2010, 09:43 PM
PCP
what's my bore?
PCP's Avatar
no heater control valve unless someone put one on.
510 rwhp and 522 foot lb of torque.
fastest 1/4 and 3rd time out 12.33 at 110 mph
check out our rat rod build.
Don't TOUCH my truck Club # 92
Silver truck club #235
Trucks and Guns Club #145
PCP is offline
post #3 of 18 Old 12-18-2010, 09:51 PM
05DaytonaHemi
05DaytonaHemi's Avatar
1st Cheak the coolent level might be low, if it's full feel both heater core hoses to see if one is hotter than the other. Might be clogged.
2005 Dodge Ram Daytona
05DaytonaHemi is offline
post #4 of 18 Old 12-19-2010, 08:52 AM
fannitti
fannitti's Avatar
check ur t-stat
fannitti is offline
post #5 of 18 Old 12-19-2010, 08:54 AM
clemsonteg
My wifes dakota used to do that from time to time, I would also check the thermostat and pull off both hoses that go to the heater core ( not at the firewall but where ever the hose connected) and I would flush out the heater core. Top of the radiator and it would run you out of the truck by then.
I hate to go ninja'n people that don't need ninja'n.
clemsonteg is offline
post #6 of 18 Old 12-19-2010, 09:42 AM Thread Starter
haf2race
It full of antifreeze. I'm getting ready to flush heater core, hopefully that will fix it.
haf2race is offline
post #7 of 18 Old 12-19-2010, 09:46 AM
Voodoo
Motörhead For Life!
Voodoo's Avatar
Quoted: 56 Post(s)
Is there no heat on both sides or just one ? If that's the case it could be the famous Door...
2012 Ram 1500 TRADESMAN REGULAR CAB 4X2 8' BOX ( TOTALED )
2014 Black Express
Edition 1500 Ram.
"You Can't fix Stupid"
Voodoo is offline
post #8 of 18 Old 12-19-2010, 03:18 PM Thread Starter
haf2race
flushed heater core and now heats good 120 degrees. I also did the wife's Durango which wasn't heating good either. Now her's is 134 degrees coming from the vents. Thanks for all your help.
haf2race is offline
post #9 of 18 Old 12-19-2010, 06:24 PM
clemsonteg
Im not sure what clogs them up like that, what scares me actually is that whatever sludge is in there could be in the rest of the engine as well.
post #10 of 18 Old 12-19-2010, 08:41 PM Thread Starter
haf2race
Just took it a second drive since flushing. It did it again, no heat. Turned the vent selector knob and it started heating again. I quess its the damn blend door. How much of a pain is it to pull dash?
haf2race is offline
post #11 of 18 Old 12-20-2010, 12:27 PM Thread Starter
haf2race
What parts do I need to fix the blend door? Is this something I have to get from dealer or can I rig something?
haf2race is offline
post #12 of 18 Old 12-20-2010, 02:16 PM
weedahoe
Tricked out Ram
weedahoe's Avatar
Quoted: 21 Post(s)
http://www.dieseltruckresource.com/d...d-t210483.html
http://www.turbodieselregister.com/f...-pictures.html
2004 2wd Dodge Ram QC w/a 5.7 with Royal Purple 5w-20 in the motor, RP Max ATF in the trans, 80-90w in the 4.56 Auburn LSD rolling on American Racing Dale Earnhart "Tank" 24s wrapped in Pirelli 325/45/24s (36" tires)
| Debadged | SRT-10 hood | Custom CAI | Fumoto oil valve | 12" of lift | Power Wire | 9007 Bi-Xenon 6k | 9006 Single Beam 6K | 2nd battery tray (2K CCA total) | Big 3 upgrade w/1ga wire | Altezza clear tails w/LEDs | Clear LED 3rd light | 26gal to 35gal fuel tank swap | Viair 380c air compressor | train horns | Ceramic pads (F&R) | Westin Nerfs | Chrome door/tailgate handles | Custom switch panel | Custom center console | B&M QuickSilver floor shifer | Xbox 360 | Audiobahn A8000V (1600w sub amp) | Audiobahn 2002V (400w mid/high amp) | 2 12" Kicker DVC CVRs in a FoxBox | 4 Kicker DS650s (front & rears) | 2 Kicker KS350s (dash) | 2 8" LCD screens in the sunvisors | 2 6" LCD screens in the headrest | Clifford 50.7x alarm | 20/15% tint | Diablo Trinity - custom and 93 tuned | Mopar 6.1 ignition conversion | Start ignition push button | KRC 210 cam | 6.1 springs & pushrods | 6.1 half covers | 180* T-stat | Taurus E-fan | Pacesetter ceramic LTs | dual DMH cutouts | (2) 4x14" round magnaflows | 4x24" tips | X pipe | Jimmy Jammers | Ported (85mm) TB | Innovate LC-1 wideband | Sonnax transmission pressure booster | Mopar slush mats | RBP grill | powder coated calipers | custom rim/grill lights |
Next projects:
- Custom center console
- B&M Quicksilver Floor shifter
- Custom CAI
weedahoe is offline
post #13 of 18 Old 12-20-2010, 09:13 PM
Daking
Ramman
Daking's Avatar
Quoted: 1 Post(s)
I think I have the same problem.
No heat.
I thought it may be because of my electric waterpump. I run no thermostat, so the pressure to the heater hose is not great. I did had a "****" blocker (restrictive plate) in the top hose.
My heater lines to get hot, so the core is getting hot.
On a recent off-road journey, The heat started working for no reason. Granted, we wore pointed to the sky, and pointing to the devil at times. I thought maybe the extream angles moved out any air bubbles.
But, now I have no heat again.
I just picked up an electric heater.. for now.
2004 Dodge RAM QC 4X4, 426 Hemi W/ Ported Big Valve Heads
, Forged internals, FastMan 84MM TB,, Headmen headers (3" Pipes), , ATI 5% Damper Pully
ATS 545RFE- TRIPLELOK TORQUE Billet CONVERTER, 4:56 Gears @ both ends, TrueTrac out back
Viper Electric Fan dual thermal controller, Electric Water Pump
1/4 Time... 13's
2010 Sand drags Points Champion
Daking is offline
post #14 of 18 Old 12-21-2010, 11:21 AM Thread Starter
haf2race
has anyone used the heatertreater blend door fix?
haf2race is offline
post #15 of 18 Old 12-21-2010, 12:55 PM
Daking
Ramman
Daking's Avatar
Quoted: 1 Post(s)
What is it?
1/4 Time... 13's
Daking is offline
post #16 of 18 Old 12-21-2010, 01:48 PM Thread Starter
haf2race
www.heatertreater.net they've fixed the broken blend, mode and recirc doors when the factory junk breaks
haf2race is offline
post #17 of 18 Old 12-22-2010, 05:05 PM Thread Starter
haf2race
Just did the heatertreater blend door fix. Both my doors were broken. This job was very easy to do with minimal parts to be taken off. I highly recommend this to anyone with a blend, mode or recirculation door problem. Took at 3hrs to fix both doors. all for less the $200. Sure beats the $900 the stealership was going to charge and the kit has a steel parts, no more broken doors here. Thanks Chris, you are the man.
haf2race is offline
post #18 of 18 Old 12-22-2010, 09:29 PM
99Slobra
Biggin
99Slobra's Avatar
I get warmer out out of the passenger side of my dash than my driver side..
wtf..hahaha
2004 2500 Hemi R/C 4x4 on 35's
K&N CAI
Bilstein 5100's
Black Magic 183
SC 3865
Not loud enough
99Slobra is offline
    rear air blows but no heat.. Rudnik 1G Dodge Durango General Talk 14 08-23-2010 10:22 AM
    Heat only blows hot for a few seconds racer190 Dodge Dakota 1st Gen (87 -96) Forum 5 01-23-2009 05:17 PM
    2002 Dodge Ram 1500 3.7lt ST, Heat blows hot while driving only, cold when not movin ehoez 3G Dodge RAM - General Talk 11 12-11-2008 09:17 AM
    no heat, blows cold 98 dakota barstickbilly 2G Dodge Dakota General Talk 5 02-14-2007 11:26 PM
    a/c blows cold back only mr.318 1G Dodge Durango General Talk 2 11-15-2005 01:01 PM
