ESP/BAS/ABS Error - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 17 Old 12-12-2010, 08:23 AM Thread Starter
soad
soad's Avatar
ESP/BAS/ABS Error
I have an 09 Ram with 11,000 miles on it. Last night when driving home a whole bunch of lights when off on my truck. The ABS light, the ESP light, the EVIC said "park assist off" and said "ESP BAS" and "Service 4wd". This stayed on for 5 minutes then turned off. But after another few minutes it started going on and off every 30 seconds or so the whole way home (over an hour). This morning it is doing the same thing.
Two questions: Obviously I'm going to call the dealership on Monday morning, but I have to work and will have to drive the truck in the 8-12 inches of snow we are getting tomorrow....is the truck safe to drive with all this stuff turning on and off constantly?
Will whatever is wrong be covered under factory warranty? I really don't want to spend any money right now
Thanks!
2009 Ram CC Sport 4x4 Hemi Chick Magnet
2007 Durango 4x4 Hemi Grocery Getter
soad is offline
post #2 of 17 Old 12-12-2010, 08:42 AM
mattyb777
mattyb777's Avatar
I also have an 09 with 10,300 miles and I had the ABS, BRAKE, ESP MDS, TRACTION CONTROL lights come on and stay on last night while driving....
another member told me to check the electrical connections that go to the wheel hubs for the ABS....which I havent had a chance to do yet.
Not sure if this helps....I hope more members can chime in
2012 Ram 1500 CC 4x4 / Mineral Grey / MyGig RBZ / Locpic v5 / Back-up Cam /
COMING SOON:
LOTS!
mattyb777 is offline
post #3 of 17 Old 12-12-2010, 09:09 AM
SnowDogs
SnowDogs's Avatar
I would be cautious about the ABS, you will be able to stop just may not have the ABS. Can you take it to a parts store that lets you use their scanners for free to see if it will pickup anything? Advanced Auto and Auto Zone both have this service around here.
Your factory warranty will cover everything, 3 years or 36,000 miles bumper to bumper except tires, brake pads, wiper blades. If you have an extended warranty you would have to pay the deductable but only after the 3/36 warranty was over.
I Love my fur-wheel-drive !!!
4th Gen Truck Club member #28
Orange Truck Club member #25
2009 Dodge Ram 1500 QC sunburst Orange
2010 Dodge Nitro Detonator Stone White (wife's ride)
3 Siberian Huskies 2, 3 and 4 years old and a good ole dogsled. Much more fun than any vehicle!
SnowDogs is offline
post #4 of 17 Old 12-12-2010, 09:30 AM
hemisport25
2k10 Ram 1500 Sport
hemisport25's Avatar
As already mentioned, these problems sound like a wire harness coming apart ultimately disconnecting sensors from the ECU..
hemisport25 is offline
post #5 of 17 Old 12-12-2010, 04:07 PM Thread Starter
soad
soad's Avatar
Well, I needed to go to the store. I pulled the truck out of the garage the lights were going on and off. I put the truck in drive and while still standing still the spedo was going between 0 and 15mph. I slowly hit the gas and heard the grinding that you get when the truck loses traction (the ABS or the ESP....I'm not sure) the truck kinda jumped forward, and then it went normally. At the stop sign it did the same thing so I just turned around.....
Will the dealership tow it for me under the factory warranty if I call? I am really hesitant to drive it right now.
soad is offline
post #6 of 17 Old 12-12-2010, 05:05 PM
blackhemi4x4
Shut up and drive!
blackhemi4x4's Avatar
My dealership towed me for free. They did inform me that I would be responsible if it turned out not to be a warranty issue.
You should be fine
2010 Ram 1500 QuadCab 4x4 5.7 HEMI Big Horn
mods: debadged
future mods: Exhaust, tires, tow hooks, skid plates, a/t tires, red brake calipers, maybe a tuner, line-x, 12" ported sub under a seat, colormatched grille
-Will be keeping it mostly stock.
My G/F also has the same truck, only hers is 100% stock-2010 Ram 1500 QuadCab 4x4 5.7 HEMI Big Horn
Former owner of 2007 Ram QC 4x4 BigHorn 5.7
99 Neon ES auto
01 Neon ES 5 speed
a handful of dodge Shadows (4 of them, all running)
early 90's D50
Im no longer amotorkat :P
blackhemi4x4 is offline
post #7 of 17 Old 12-13-2010, 09:20 AM
jball
Do the key check real quick, cycle from on-accessory (repeat 3 times) and leave it in the on position.
It will flash any diagnostic trouble codes where your odometer is if there is something wrong.
jball is offline
post #8 of 17 Old 12-13-2010, 09:32 AM
BMRbrnSNRbrd
Try harder
BMRbrnSNRbrd's Avatar
Definitely shouldn't drive and the dealership better tow it.
Mineral Gray 2010 Dodge Ram CC Hemi Sport
Exterior: Limo tint | Painted tips | Painted calipers | De-badged | Painted grill inserts | Gloss black b-pillars | Color matched antenna base |
VHT tinted puddle lights | Color matched tailgate handle | Shaved and two-toned grill | Painted Vararam lid w/ two-toned Ram badge |
Color matched Laramie 2500 flares | Shaved tailgate badge | Shortened and painted antenna
Lighting: Color matched headlights retrofitted with 5000k Morimoto projectors |
5000k HID fog lights tinted with Lamin-x | 6000k HID retrofitted reverse lights
Interior: Color matched interior plastics | 2 MTX 12" subs in a cheap box | REN MyGig 30gb headunit | Black microsuede wrapped headliner and sun visors | Black microsuede wrapped and shaved pillars | Black microsuede wrapped custom made door inserts | SEM black painted interior plastics
Suspension: McGaughy's 2/5 Economy drop | BrakeMotive cross-drilled and slotted rotors | All black Milano M724 22s | 305/40R22 Nitto 420s | AirLift Helper Bags
Performance: Superchips Vivid Paq w/ trans tuning | Vararam Air Grabber | Magnaflow 18" Muffler | Raceland USA E-Cutout |
Billet Technology Oil Catch Can | Clutch fan delete | 180 T-stat | Magnaflow Y-Pipe with relocated crossover pipe
BMRbrnSNRbrd is offline
post #9 of 17 Old 12-13-2010, 09:39 AM
Moparn4life
You have a bad wheel speed sensor. I had one go bad last winter. It took the dealer 4 trys to get it fixed. replaced the TIPM, ABS sensor and finally a rear wheel speed sensor to get it fixed. I also had intermittant brakes being applied when going down the road - since the wheel speed sensor was malfunctioning & telling the abs sensor that wheel slip was occuring. It was very weird driving it. The dealer told me that it was ok to drive - though I didn't much.
2009 Ram 1500 Crew TRX4
Moparn4life is offline
post #10 of 17 Old 12-13-2010, 10:06 AM Thread Starter
soad
soad's Avatar
The tow truck just picked my baby up. I called the dealership this morning, he told me to call Chrysler Roadside Assistance. The lady from there was real nice and now I'm just waiting at home for them to call.....had to call off work today....
soad is offline
post #11 of 17 Old 12-13-2010, 10:09 AM
dmcelhannon
Admin - David Mack
dmcelhannon's Avatar
Quoted: 250 Post(s)
I'd have it towed but it's up to the dealer if they pay for it or not; some do and some don't. But there's now way I'd drive-it even around the block.
dmcelhannon is offline
post #12 of 17 Old 12-13-2010, 03:20 PM Thread Starter
soad
soad's Avatar
So the dealership called a few hours ago and said it was a bad wheel sensor (good call guys ) They said they didn't have the part but would get one in tomorrow. They just called back and said that they were able to fix the sensor and will not have to replace it....does this make sense? I REALLY don't want this to happen again, will just fixing instead of replacing lead to more trouble in the future? They still are going to keep it overnight to do 2 recalls on the truck.
Thanks for all your help guys!
soad is offline
post #13 of 17 Old 12-13-2010, 03:25 PM
BMRbrnSNRbrd
Try harder
Glad to hear you got it worked out. If it were me, I would call back and ask them how they fixed it and what was wrong to begin with. I agree that it needs to be fixed correctly so the same issue doesn't catch you off guard again.
post #14 of 17 Old 12-13-2010, 05:02 PM
King
The plugs come loose and there is a RRT for the repair. Simply clean the connection and plug back in.. People with lifts have a better chance of having the problem.
His 2011 2500 4x4 Cummins crew ....Hers 2011 Ford Eco Boost Crew... Daughter 09 Inferno Red SLT Crew Cab loaded.
King is offline
post #15 of 17 Old 12-13-2010, 05:19 PM Thread Starter
soad
soad's Avatar
Thanks guys! I don't have a lift, I guess I'm just unlucky Would that RRT be "09-041 -- 2009 DS flash ABS/ESP module" or another one? I just want to double check with the mechanic when I talk to him tomorrow.
soad is offline
post #16 of 17 Old 12-13-2010, 05:28 PM
King
Not 100% sure but there is one for checking the connections at the wheel hubs.
King is offline
post #17 of 17 Old 01-10-2011, 11:12 AM
RogueOps
RogueOps's Avatar
Yes this is the problem, i have about 127 000km on my 09 laramie 4x4, It ust happend to me again this morning on the way to work, this is the 9th time i will now have to take it in, its always the rear abs/speed sencor in the back wheels, always either a bad connection to the sencor or the wireing harness fails, the first time they didnt warranty it cause it was muddy and "warranty doesnt cover off highway driving" so after that when ever it happens i spend about 2 hrs washing it including the frame and suspension so they cant say anything about off highway driving and they warranty it, i find it usually happens if i hit a bad set of washboards it seems to dislodge the connection to the sencor, ive told them this but they dont actually fix anything just replace sencors so it keeps happening, usually takes 2-3 tries for them to fix the connection problem before it clears and stays cleared. I do have 2" blocks in the back but had the problem several times before the blocks were installed
RogueOps is offline
    Error code 0601 - Control Module ROM Error phildog 2G Dodge RAM - General Talk 1 12-07-2005 04:10 PM
    ABS Error Light & Brake Error Light 78RamCharger01D 1G Dodge Durango General Talk 7 09-11-2005 02:54 PM
    Log out error mopar fan DodgeTalk.com Site Feedback and Ideas 2 05-01-2004 05:37 PM
    Error NJRamFreak DodgeTalk.com Site Feedback and Ideas 4 07-07-2003 09:07 AM
