1998 Dodge Caravan charging problem? - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 4 Old 11-21-2010, 02:06 PM Thread Starter
mustang_lad
My step-mother has the 98 dodge caravan sport 3.3L v6, one day on the way home my dad noticed that he battery light was on and the lights started to flash. the Alt. was taken out and checked and its fine. It also has a new battery and new belt in it. I am sitting in it when i am typing this, it sits with out it running at 25.5v at the battery it dipps down to 20.2v when you start it and after it starts with nothing running stays at 24.1v all at the battery with every thing running its at 22.1v (headlights highbeam, A/C, fog lights, rear def. and inter lights all on.) After you turn the van off it slowley makes its way back to the 25.5v it had in it.
I hope this helps any more info needed i will try my best thanks
PS- if you want me to te ll you about my name i am willing later.
mustang_lad is offline
post #2 of 4 Old 11-21-2010, 03:25 PM
donald7150
donald7150's Avatar
dude i'd check it with another meter
25.5 volts is totally retarded haha
I know if my multimeter has a low battery it will give me rediculously high readings similar to yours
2005 Chrysler 300 (DD): 6000K 50W HIDs, Niteshades, LED Interior light Conversion...
'99 Caravan: Work van. 6000K HID headlights and fogs
'92 Chrysler Daytona IROC R/T (2.2L DOHC Turbo-III)
donald7150 is offline
post #3 of 4 Old 11-21-2010, 06:22 PM Thread Starter
mustang_lad
i think i know what happen i had the meter set to AC and not DC my bad
post #4 of 4 Old 11-22-2010, 11:00 AM
StandOnCliff
StandOnCliff's Avatar
If it still isn't charging and the light is still on, you may want to check the fusible link. It's found near the battery positive terminal.
StandOnCliff is offline
    97 Caravan charging problem eehoepp Dodge Caravan General Talk 14 03-16-2009 12:04 PM
    1998 Caravan Start and Run Problem with PCM deputylynch Dodge Caravan General Talk 0 11-15-2008 07:25 AM
    1998 Grand Caravan Trans problem mikemckee Dodge Caravan General Talk 4 05-31-2006 11:48 PM
    1998 Dodge Caravan heater not hot! HELP! knight75 Dodge Caravan General Talk 3 12-23-2005 09:28 PM
    90 Dodge D150 Charging Problem egreen Dodge Ram Truck 1st Gen (88 - 93) Forum 6 01-12-2005 09:15 PM
