Engine ticking!! - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 14 Old 11-19-2010, 02:19 PM Thread Starter
DSflyer05
Engine ticking!!
Hi all. I started up my truck today and heard a loud noticeable ticking from under the hood. I drove it home last night and nothing was wrong then. When I opened the hood it just got louder but I can't narrow where it is coming from. When I give it some gas the ticking speeds up with the RPMs. I checked the oil because I thought it might be something internal at first and the oil was a little low. I'm just coming up to the 3000 mile mark now for the oil change. I added to it just to see if the tick would go away but it didn't change anything. I'm just wondering if anybody had any ideas on what it might be or where I should start looking. Thanks in advance. By the way I just toped it off with fuel (89 oct) yesterday to so could it be bad gas? Thanks again.
2005 1500 Ram 5.7 Hemi Quad Cab
2.5 inch Ready Lift Level Kit
295/70/17 Nitto Trail Grappler MT
Magna Flow Dual Exhaust w/ 3.5 inch tips
Hella 700FF Driving Lights (Behind the Grill)
Line-X Spray In Bed Liner
B&W Turn Over Ball Gooseneck Trailer Hitch
DSflyer05 is offline
post #2 of 14 Old 11-19-2010, 02:27 PM
Jmw132001
Jmw132001's Avatar
Quoted: 2 Post(s)
Sounds like it could be the valves. One could be loose causing a "tick" sound and would be persistent with the rpms.
Justin
Resigned July 19th 2011
COIN HOLDERS ASSOCIATION MEMBER # 88
Beta tester for online games.
1998 Dodge Ram 1500 qc sport 360 4x4
208,300 original miles (as of 9-25-10)
new transfer case, brakes, shocks, radiator, water pump(twice cause of faulty parts), front balls joints, trak bar, front u-joints, tires, heater core.
Jmw132001 is offline
post #3 of 14 Old 11-19-2010, 02:50 PM
hemi_jeff
hemi_jeff's Avatar
May just be Hemi tick. Do a quick search and be prepared to read for hours.
2011 Ram 1500 Sport Crew Cab 4x4
3.92 LSD | Line-X Bedliner | Monster XD Wheels | LED tag lights | LED switchback front signals | HID fogs | Retrofit Headlights | Mufflex 14"
Previous Trucks:
hemi_jeff is offline
post #4 of 14 Old 11-19-2010, 03:17 PM
dizzyD
Registered MOPAR User
dizzyD's Avatar
Quoted: 24 Post(s)
And it doesnt go away when the engine been running for 5-10 Minutes?
2012 Challenger SXT+ 220ci 5 speed, blackberry pearl, FM xxMM, diablo in-tune I1000, Carbon fiber pedal covers, 11% tint
1999 Durango SLT+ leather, 360ci 4x4, hughes plenum rebuild, superchips 3865, tow pkg, 3.55 LSD, rear tail light guard, K&N CAI, FM 50MM TB, crystal clear headlights, Torsion/shackle lift, Rancho RSX's, Pacesetter headers, dual trans & oil temp a-pillar pod, chrome deep trans pan, drilled & slotted rotors, 10 disc cd changer.
2004 Ram 1500 SLT 2WD QC LB 345ci, FM 84MM TB, slotted brake rotors, step bar, diamond plate pedals, locking gas door, tow package w/ 3.55 lsd, Hellwig LP-15, shell and carpet kit, 18% door window tint, Magnaflow 12641, Slammed1's 3" spindle lift and 2.5 coil spacer, rear lift shackles, Airraid MIT, superchips 3815, 6K front winch & custom Winch Plate, Autometer phantom trans gauge mounted in Mopar SRT A-Pillar single pod, lumber/roof rack, Rancho 9000X shocks, ATS fender flairs, 1" BL, gap guards, black grille, silver painted bezel
2005 Dodge Magnum RT- Midnight Blue -Vroom Lakewood front strut bar, K&N Filter
Gone but not forgotten 93 factory freak CC dakota lifted 4x4 318
dizzyD is offline
post #5 of 14 Old 11-19-2010, 04:33 PM Thread Starter
DSflyer05
Update
As stated previously I filled the oil back to full on the dip stick, and let it run for a while and took it out and took it out for a drive. After a while the loud ticking went away, the hemi tick is still there like always. I put some fuelsystem cleaner in it as well. Hpofully it will stay away for good now. Now I just have to figure out why it was a Qt. low on oil in just under 3000 miles.
Last edited by DSflyer05; 11-19-2010 at 04:34 PM. Reason: Spell check thinks it's smatter than I am!
post #6 of 14 Old 11-19-2010, 04:37 PM
Dodge4L1fe
Quoted: 43 Post(s)
What brand and type of oil are you using?
Dodge4L1fe is offline
post #7 of 14 Old 11-19-2010, 05:09 PM
dizzyD
dizzyD's Avatar
Quoted: 24 Post(s)
also how many miles on ticker?
dizzyD is offline
post #8 of 14 Old 11-20-2010, 01:34 AM
dmcelhannon
Admin - David Mack
dmcelhannon's Avatar
Quoted: 245 Post(s)
A few 4.7L owners in the past have said the "tick" was an exhaust leak. They claimed the manifold had come lose and caused the sound you're hearing. They also claimed they put in new exhaust gaskets with better locking nuts on the manifold and everything was like new; no "tick".
There have been others that have said the "tick" was worn rockers. Some have even said they heard the "tick" and later, one of the rockers failed; this of coarse damage the head. And yet others have said they have been told by Dodge tech’s, it’s the timing chain tensioner causing the noise. The timing chain tensioner needs to pump up oil pressure upon startup and that it was a common issue. If you can rule out the exhaust like mentioned above you may want to consider changing to lighter weight oil for the winter and better oil filter as well. Some have always run m1 5W30 syn-oil and have experienced the tapping noise. They changed out to M1 0w30 synthetic-oil with the M1 oil filter and it has reduced the tapping quite a bit. I personally do not like running the low weight oil in my truck. One thing is for sure; you need to make sure to let the engine warm up a couple of extra minutes until that tapping stops before driving away.
My truck had 26-miles on it when I drove it off the lot. The engine was quite as a church mouse. Around 75K, I replaced everything from the head gaskets up when I had the big valve cylinder heads and cams to on the engine. Now the engine has the "tick”.
dmcelhannon is offline
post #9 of 14 Old 11-20-2010, 03:38 PM
05Ramhendrix
Ramistered User
05Ramhendrix's Avatar
Quoted: 15 Post(s)
exhaust manifold leak, my guess is there is a broken manifold or header bolt
Scott
2005 QC HEMI * 2wd * PSB Bright Silver * AEM Brute Force Intake * Powerwire * Jetstream Scoop * Stant 14168 180* T-stat * Superchip Flashpaq 3865 w/ Trans Tuning * BBK Ceramic Shorty Headers * Magnaflow Y Pipe * Magnaflow Catback * Motive 4.56 Gears LSD * Rough Country 6" Lift *Moto Metal 951 20x10 *Nitto Terra Grapplers 305/55/20 * Alpine Audio
05Ramhendrix is offline
post #10 of 14 Old 11-20-2010, 04:32 PM
MikeHTally
Got 2 Hemis
MikeHTally's Avatar
Quoted: 55 Post(s)
I agree. Does it stop or get quieter after warm-up?
'03 1500 QCSB Hemi
Vent shades/15% tint
A.R.E. Tonneau/Bed Rug
Nerf step bars
Rear LED light bar/LED frt. turn signals
LED tails & 3d brake light/White Night backup lamps & LED interior lights
Halos/projector headlights KC HiLites Titanium Driving lights
Tailgate Easy Lift & EZ Down
E&G Classics mesh grill
WeatherTech Floor Liners
Overhead console with HomeLink
JVC KD-AR780 Receiver & CH-X1500 Changer
Jensen 6x9 3-way up frt., 5 1/4" 2-way rear
GenTex auto-dimming mirror & Towing mirrors
Fender liners & Ram splash guards
Silver Truck Club Member #140
S.N.A.T.C.H. Club Member 666-666
2 1/2" level kit
Jetstream Scoop/Power Wire
MagnaFlow Stainless Cat-back SI/DO
TrueFlow intake kit
Hellwig 7651 sway bar
Flex-a-lite Black Magic Extr. 180 Elect. Fan
Dick Cepek Chrome DC-1s/Bridgestone Revo2 285/70
MikeHTally is offline
post #11 of 14 Old 11-21-2010, 09:09 PM
GregInAtl
GregInAtl's Avatar
My 4.7 tick until it warns up (2 minutes tops) is this sludge in the engine blocking the oiling until it warms, or could this be the manifold? I'd think it'd keep ticking?!
Greg
12 Ram express QC...4/5.5 drop, helper bags, Polk audio, pioneer, homemade hard tonneau, blk headlights, tinted tails, painted handles, much more
05 Ram 5/6 drop, rear helper bags, SRT 22" reps -SOLD-
86 Buick GN, upgrades all over it, dropped 4/3" and 20"s--SOLD--
06 Stratos 201 Pro XL, Yamaha 225
GregInAtl is offline
post #12 of 14 Old 11-22-2010, 08:33 AM Thread Starter
DSflyer05
I was using 5w20 oil. I was suprised to see it burned through a quart in 3000 miles. I added a Qt and ran it for a while than the ticking stoped, now I just have the regular hemi tick ( which is alot quiter compaired to the tick I had.) I thought it may have needed to warm up for a while to but I have an automatic starter and let it warm up for a couple minutes before i leave the house so that wasnt the issue either. Atleast its gone now!
post #13 of 14 Old 11-22-2010, 09:53 AM
dizzyD
dizzyD's Avatar
Quoted: 24 Post(s)
Sounds like exhaust
dizzyD is offline
post #14 of 14 Old 11-22-2010, 10:13 AM
atvanish
atvanish's Avatar
My 5.7l Hemi in my Durango has a broken exhaust manifold bolt as well...
2006 Power Wagon QC w/ 35" BFG KM2's, Rhino Lined Bed, B&W turnover hitch, nerfs, TSC toolbox & ventvisors...
atvanish is offline
    engine ticking Mdixon7795 2G Dodge Ram Performance Talk 11 04-06-2009 09:17 PM
    ticking after engine heats up??? Jarvis 1G Dodge Durango General Talk 6 03-09-2009 08:01 AM
    Engine Ticking? Faisal Dodge Neon SRT-4 Talk 6 11-15-2005 03:39 PM
    Ticking In Engine Darrel 3G Dodge RAM - Drivetrain Talk 46 04-25-2005 08:25 PM
    possible solution to engine ticking jailer 3G Dodge RAM - General Talk 3 05-11-2004 08:11 PM
