03 Ram 2500 ABS light and Brake light come on when making sharp right turns - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 3 Old 11-19-2010, 07:53 AM Thread Starter
Ram2500 Girl
Question 03 Ram 2500 ABS light and Brake light come on when making sharp right turns
Hey
I bought a 03 Ram 2500 4x4 a few months ago. The brake line busted when I first got it, now the ABS light and Brake light come on when I turn into parking spaces. Any ideas? I've read that it could be the sensors. My boyfriend looked at the brake lines last night and they all checked out fine. He didn't have time to check out anything else. I live on a mountain so I'm constantly on bumpy dirt roads. I also read that a lot of people who have this problem also have problems with the Speedometer, I havent had a problem. I love this truck and I know all about dodge's trans problems, so i'm hoping it doesn't have to do with the trans at all. it did have a trans flush before I took it home from the dealer. let me know your ideas! thanks
Ram2500 Girl is offline
post #2 of 3 Old 11-19-2010, 08:06 AM
!05RAM05!
Previously Micash21
!05RAM05!'s Avatar
Get it hooked up to a scanner and see if you can pull any codes. Not every code generates a check engine light.
New: 2005 Dodge Ram 1500 QCSB 4x4 Hemi Laramie Bright Silver
Flowmaster SI/DO 40 Series. Superchips 3865 - 91 Tune, 2/4 drop, More to come............
::GONE BUT NOT FORGOTTEN::2005 Dodge Ram 1500 QCSB 4x4 Hemi Sport Black
5.5" Rough Country Lift, Dick Cepek DC2 20x9, 325/60R20 Nitto Terra Grappler's, Superchips 3865 - 91 Tune, Extang Tonneau Cover, K&N Cold Air Intake, Bosch Platinum 4 plugs, Magnaflow Y-Pipe, SI/DO Flowmaster Original 40 Series, Synthetic Everything, 7000K Headlights, Foglights and Hellas..
1998 Dodge Durango SLT 4x4 Black
Hypertech 87 Tune, K&N Cold Air Intake, Bosch Platinum 4 plugs, Bosch 8.5mm Wires. Ported Throttle Body, SI/DO Flowmaster Original 40 Series Muffler, Headman Headers, 3" PA BL, 2" T/S Lift, 33x12.50R15 Firestone Destination M/T's, 15x8 Eagle Alloy Wheels.
BTC Member 211 - Steel Reserve
!05RAM05! is offline
post #3 of 3 Old 11-19-2010, 08:17 AM
TwinStick
Probably a wheel bearing. They have ABS sensors in them. If it is & you only want to replace them once, check this out. http://www.dodgetalk.com/forums/show...03#post3819603
08' PowerWagon w/6-speed manual G-56. 05' 30' toyhauler camper.(10,500lbs)
Hellwig LoadPro 35 bolt on 4 leaf helper springs.
No honey, I'm NOT done buying shit for the truck yet !!!
PurpleCrainium Diff Guards
K&N air filter --- WeatherGuard 20" black bed toolbox.
winch TPC bypass
Dual battery set up w/2 Sears DieHard Platinums-Gp 65 under hood-Gp 31 Marine deep cycle in bed toolbox w/plug-n-play set up. Custom 2000/4000w inverter set up w/quick connect. Triple bike mounts above the bed- custom made by me.
Crapload of recovery gear-always subject to adding more.
Fab Four rear bumper. Soon to be- a BuckStop Baja front bumper.--Temporarily on hold, see reason below.
Installed: Borgeson #000951 steering shaft. PSC steering brace(notched for PW by Rusty-thanks bud). Carli HD CroMo adjustable track bar. Carli CroMo control arms. Carli HD upper & lower balljoints x 2 sets (replaced under warrenty) & triple sealed u-joints in front axle shafts & rear driveshaft. Moog HD tierod ends x 4. Running total is now $4800. Yup, now i'm broke !!!
What, you ask, is the difference between a Dodge Ram and a PowerWagon ?? PW frame part # 55398868AC---Reg 2500 #55398813AC
About 2" taller, 12,000lb winch w/mounting brace between framerails,electronic disconnecting swaybar(for awsome articulation),electronic locking axles front & rear(for true 4-wheel drive),tow pkg, fully skidplated,forged one piece Alcoa rims w/internal beadlock lips,larger diameter(one ton) axleshaft in rear,160 amp alt,HD battery,4.56 gears,low range electronic recalibration of gas pedal sensitivity,more but thinner leafs in rear spring pack(for better articulation), 33" BFG All-Terrain tires. 78.016:1 crawl ratio. All for $6100.00 more! Oh yeah, almost forgot-Bilstein shocks. Gear ratios: 1st 6.29:1 2nd 3.48:1 3rd 2.10:1 4th 1.38:1 5th 1.0:1 6th .79:1.. Rev 5.74:1.
TwinStick is offline
    Dome/Cargo/3rd Brake light OUT!!?? Radio turns on but no sound!! jz8fenton 2G Dodge RAM - General Talk 15 12-02-2007 05:24 PM
    ABS/BRAKE light turns on & a/c shuts off?? jonnyquest 3G Dodge RAM - General Talk 0 11-29-2007 04:34 AM
    ABS and BRAKE light 94 Ram 2500 ram ebn 2G Dodge RAM - General Talk 1 08-03-2007 03:06 PM
    (ABS) and BRAKE light turns on...... mrjivester 1G Dodge Durango - Drivetrain Talk 7 12-20-2005 04:59 AM
