Rear axle seal replacement?? - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 5 Old 11-10-2010, 05:42 PM Thread Starter
rcrrox
How do I get the axle out of my truck '97 1500?? I have limited slip rear end and there's a brass clip inside diff housing that looks like it's holding it in. Doesn't look like there's a lot of room to somehow get it apart although I'm sure it can be done. In addition are the gears/clutches in the limited slip going to fall apart if I pull out axle? I have the brake off and the diff cover off. Please tell me everything I need to know.
Thanks in advance
rcrrox is offline
post #2 of 5 Old 11-10-2010, 10:28 PM
Woodstock
Woodstock
Woodstock's Avatar
Here are some pictures to show you what is needed to remove the axles. (You don't have to remove the rear diff.) The first picture shows you the bolt to remove so that you can slide the cross pin out. The second picture shows the pin slid partially out. Once you slide the pin out push the axle in towards the diff. then take a small magnet and remove the C-clip and pull the axle shaft out.
This is the write up I pirated the pictures from. -Thanks 95_318SLT.
http://www.dodgetalk.com/forums/showthread.php?t=276136
2000 1500 Sport 5.9 4X4 QC 46re w/TFODjr
SCT by hemifever, 4.10 Gears, Stainless Steel Headers
HellBent Steel leveling kit, 33X12.50X16 Super Swamper TSL Radials
1985 350 Custom Dually 360ci 4barrel 727
1990 Jeep YJ 4.2 waiting for 5.9 swap
Woodstock is offline
post #3 of 5 Old 11-10-2010, 10:43 PM
Woodstock
Woodstock
Woodstock's Avatar
Here is a picture of the axle pushed in and the C-clip removed. The C-clip goes in the grove on the axle (the right axle in the picture). *Don't spin the spider gears like these in the picture. If you don't turn the axles with the cross pin removed the spiders should stay in place.
post #4 of 5 Old 11-11-2010, 09:51 AM Thread Starter
rcrrox
Thank you very much. I actually got some some info from a axle guy via my Napa store before you posted so the axle is now out and i'm on to removing and replacing a wheel bearing that suffered some collateral damage when I was taking out the leaking seal. Should be a runner today
rcrrox is offline
post #5 of 5 Old 11-11-2010, 10:55 AM
Woodstock
Woodstock
Woodstock's Avatar
Good to hear.
    Stupid question about front axle removal/seal replacement closer9 2G Dodge RAM - 4X4 Talk 9 09-27-2010 01:12 AM
    fromt passenger axle seal replacement jenks 1G Dodge Durango - Drivetrain Talk 2 10-27-2008 07:06 PM
    front axle seal replacement question black05Durango 2G Dodge Dakota - Drivetrain Talk 4 01-13-2008 06:25 PM
    Driver's side front axle seal replacement -5 hours? MSCH2112 2G Dodge RAM - Drivetrain Talk 9 09-28-2003 10:10 PM
    Front axle seal replacement article! MSCH2112 2G Dodge RAM - 4X4 Talk 1 06-26-2003 01:31 PM
