NEED HELP Misfire only when cold. - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 15 Old 11-09-2010, 06:44 PM Thread Starter
SilverSandRam
SilverSandRam's Avatar
Here is my latest problem with my dream truck that has turned into a nightmare. For whatever reason when the block is cold and it is started it misses like crazy, the way the whole truck shakes when the engine is under a load makes me think it’s going to blow sky high. The engine light flashes for about 5 seconds and then goes off. After the engine warms up a little the problem completely goes away and it runs like a bat out of hell. I just changed the plugs to Champion stockers and it still did it this morning. I took it to Pep Boys to have the error code read and it came up as the # 6 cylinder misfiring. Unfortunately they were not able to tell me what was causing it unless I paid to have a diagnostic test done. I am going to switch the coil pack out on that cylinder tomorrow and see if that fixes it. If not ”God forbid” what is my next cheapest step?
2006 Ram 1500 5.7 Hemi 4x4
SilverSandRam is offline
post #2 of 15 Old 11-09-2010, 06:57 PM
fannitti
fannitti's Avatar
swap coils with a diff cylinder and have the codes cleared. start it the next more and when it flashes and dose it things check the coad and see if the misfire moved with the coil, if it did then u found ur prob.
fannitti is offline
post #3 of 15 Old 11-09-2010, 07:01 PM Thread Starter
SilverSandRam
I'll try it! To me its just weird that it only does it when its cold...
post #4 of 15 Old 11-09-2010, 07:22 PM
JFM-jr
JFM-jr's Avatar
Thats exactly what I would suggest, it's ignition related so a coil,wire,or plug. It's great you have a cylinder number to work with makes your job ALOT easier, I suspect the coil is your problem. keep us posted
09 Hemi powered Ram QC 2500 Sport
Fuel Boost rims 17x9 +20MM
Nitto Terra Grapplers 305/70/17
OEM 4.56 gears
SuperChips Cortex 3950 (1449666)
JFM-jr is offline
post #5 of 15 Old 11-10-2010, 01:01 AM
BossMaverick
This is exactly what my truck did when my EGR valve went out. If swapping coil packs do nothing for you, it might just be your EGR valve. The EGR valve is common to go out on these trucks. It's reasonably priced and easy to install.
BossMaverick is offline
post #6 of 15 Old 11-10-2010, 01:09 AM
ceri
'11 5.7L R/T Classic
ceri's Avatar
Quoted: 3 Post(s)
You might be able to clean your EGR valve with carb cleaner vs. buying a new one, but a new one is only like $35 at most of the auto retailer brick and morters anyway. Not saying that's the problem, just throwing that in if it turns out to be.
2002 Dodge Ram 1500 QC SB 4.7L V8 2WD SOLD!
2004 Dodge Ram 1500 QC SB 5.7L V8 2WD SOLD!
2011 Dodge Challenger R/T Classic 5.7L V8 RWD SELLING!
2005 Dodge Ram 1500 QC SB Laramie 5.7L V8 4WD
ceri is offline
post #7 of 15 Old 11-10-2010, 05:43 AM
Doug D
Quoted: 8 Post(s)
$35? Dang, the cheapest I could find an EGR for my '06 Hemi was $77 (local dealer), other dealers charge $95 or so and it was a dealer only item. None of the local auto stores (Advance, AZ, NAPA) carried them. Not too hard to replace - at least it's fairly easy to get to.
2006 Dodge Ram SLT Quad Cab 1500 4x2 w/Hemi (MDS)
2010 Dodge Journey SXT 3.5L V6
Doug D is offline
post #8 of 15 Old 11-10-2010, 06:28 AM
DeMoN-HeMi
NEVER DOUBT THE DEMON
DeMoN-HeMi's Avatar
Quoted: 1 Post(s)
thats what mine did when i had a bad coil
Official DodgeTalk Lighting/Wiring Expert & Retired Moderator- Daniel
2003 1500 HEMI QC -Slammed and Sprayed,
2014 Ram 1500 Black on Black Edition HEMI! - The hauler
2013 Charger - The Toy
1995 Camaro - The Project
"Dont Spread my Wealth, Spread my Work Ethic!"
"Debt is normal, be WEIRD" - Dave Ramsey
DeMoN-HeMi is offline
post #9 of 15 Old 11-10-2010, 08:56 AM
ceri
ceri's Avatar
Quoted: 3 Post(s)
Ouch. I paid ~$42 at an autozone when I did mine, but I've read up on here where people have been getting them for $35 more recently. Could be the '06s aren't carried at the local retailers.
ceri is offline
post #10 of 15 Old 11-10-2010, 06:34 PM Thread Starter
SilverSandRam
Thanks guys for the impute I am going to change the coil out first thing in the morning before I start it to see if that fixes the problem.
post #11 of 15 Old 11-12-2010, 08:30 AM Thread Starter
SilverSandRam
No luck with the new coil, just took it to the dealership.
post #12 of 15 Old 11-12-2010, 08:44 AM
Limedust
Limedust's Avatar
Quoted: 17 Post(s)
I'm willing to bet you have a break in the wiring somewhere on that primary cylinder spark circuit. When the truck is cold, the wiring "shrinks up" and you can get an open circuit (resulting in a misfire). When the engine block heats up, the copper expands and closes up whatever gap you had in the wiring, and the truck runs normally.
Note that the wiring can include the coils, the wires that come from the PCM to the coils, or the heavy gauge plug wires.
Check that all of the connectors are tight, and all of the coils are firmly seated.
2012 Chevy Cruze Eco Manual
2005 Dodge Ram 1500 QCSB "Hemi" SLT 4x4
2004 Dodge Durango "Hemi" AWD/4x4
Limedust is offline
post #13 of 15 Old 11-13-2010, 06:58 PM Thread Starter
SilverSandRam
Looks like it has a bad injector, GOOD TIMES!
post #14 of 15 Old 11-14-2010, 02:58 AM
ceri
ceri's Avatar
Quoted: 3 Post(s)
That's actually not as bad as you might think. Replacing an injector is much easier than something piston or block related. You can swap in a new injector fairly easily. Not saying a shops not going to bend you over for it, but it could definitely be worse. If they haven't already done the work, I'm almost certain you could swap it yourself on a Saturday with a little research for under $100. Rock auto lists an '06 injector for $55 new or $43 reman.
ceri is offline
post #15 of 15 Old 11-16-2010, 08:28 PM Thread Starter
SilverSandRam
Thanks for the info, its under warrenty so its not going to be too bad.
    Cylinder 5 misfire, and now cylinder 8 and a random misfire... suggestions? itsaRAMthing 2G Dodge Ram Performance Talk 21 01-10-2011 09:36 AM
    A/C cold on driver side, but not cold on passenger?? shad9876 3G Dodge RAM - General Talk 9 06-22-2009 08:46 PM
    multiple misfire/random misfire ZoomZilla 3G Dodge Ram Performance Talk 43 01-29-2009 12:32 PM
    cold start rough idle when cold dodge_johnny 2G Dodge Dakota General Talk 1 01-06-2008 09:34 AM
    cold misfire 2.7 jimdec 2G Dodge Intrepid - General Talk 4 07-09-2007 06:15 AM
