Whine during acceleration... - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 22 Old 11-08-2010, 11:45 AM Thread Starter
Dodge4L1fe
Quoted: 43 Post(s)
I've noticed a slight whine during acceleration which has seemed to have started within the last few hundred miles... is this normal? My engine has 65K on it
Dodge4L1fe is offline
post #2 of 22 Old 11-08-2010, 11:58 AM
Beach Assault
Beach Assault's Avatar
Quoted: 12 Post(s)
Could be bearings or tranny or axles...
Are you 'sure' the stereo is off?
You need to pinpoint where the whine is coming from.
Big Black Limited w/Hemi and 20" Chrome Ram Wheels
Roof Carrier for 20" Spare
Removed Front Spoiler
Tinted Front Windows
Blackened Tail Lights
SmittyBilt Grill Guard
Blacked out the grill
1 1/2" Torsion Lift
Westin Sidebars
OEM Mudflaps
Rancho RSX Series Shocks
Red Brake Calipers
Slotted Rotors
Hawk Pads
MOPAR/Magnaflow CAT-Back exhaust
SuperChips[tm] Tuned 93 Octane
Taylor "Shorty" Sparkplug wires
Home-built PVC SRI
DodgeTalk.com Durango Club Member #41
Beach Assault is offline
post #3 of 22 Old 11-08-2010, 01:08 PM Thread Starter
Dodge4L1fe
Quoted: 43 Post(s)
Not sure about bearings, tranny, or axles.
Stereo is off.
post #4 of 22 Old 11-08-2010, 03:02 PM
DaveLeg
DaveLeg's Avatar
Hmmm You're from PA...Whining during acceleration... Sounds like your driving around with my wife. Just slow down, tell her you were just joking about her mother, and the whine should subside. though it will only be a temporary fix. Good Luck
DaveLeg is offline
post #5 of 22 Old 11-08-2010, 03:23 PM
CopperMtnGuy
Where is the snow?
CopperMtnGuy's Avatar
He's single though...haha
Does it "grind" when making turns at all?
Could be the early signs of a drive shaft U joint failure...
05 Jeep KJ Limted 4x4 (NP242)- Lifted, skids, tow hooks, Huskyliners
07 Land Rover LR3 SE 4.4 4x4
09 Jeep WK Laredo 4x4
2005 Durango HEMI 4x2 Limited (Traded)
Sig pic by Dodge4L1fe
CopperMtnGuy is offline
post #6 of 22 Old 11-08-2010, 05:10 PM Thread Starter
Dodge4L1fe
Quoted: 43 Post(s)
no grinding when turning
post #7 of 22 Old 11-09-2010, 06:51 PM
05kota
05kota's Avatar
New tires?
05kota is offline
post #8 of 22 Old 11-09-2010, 06:54 PM
gwin99
RangoFuse
gwin99's Avatar
have you only noticed this whine with the heater fan going and rpms just rev over 2k? i was told this was the compressor on mine (ac is shot)... had this going for two winters now...
04 Dodge Durango 4.7L V8 (+54K Miles)
EXTERIOR:
Atlantic Blue
No Door Molding
OEM Running Boards
Mopar Hood and Window Air Deflectors
265/70/17 Goodyear Wrangler SilentArmor Rubber
EBC GreenStuff Pads
EBC 3GD Slotted Rotors
Timken hubs (front)
INTERIOR/ELECTRONICS:
3.4Ghz P4, 3GB RAM CarPC running Centrafuse
- W/ GPS, Audio/Video Playback from 320 GB HD, Hands-free phone and
internet access via BT to phone
M4-ATX Power Supply
AE SoundMax Sound Card
Navibe GM720 USB GPS Puck
BS003 Dongle BlueSoli Bluetooth Dongle
Custom Center Info Console with 8 " TouchScreen
Alpine iDA-X200 Head Unit for audio amplification
Front Pass Side 7" LCD Monitor
Driver/Pass 7" LCD Head Rest Monitors
XR9000 2Way Remote Starter w/Alarm
OEM Dodge Slush Mats
ENGINE:
K&N High-Flow Air Filter
SUSPENSION:
Bilstein Shocks
gwin99 is offline
post #9 of 22 Old 11-09-2010, 06:56 PM Thread Starter
Dodge4L1fe
Quoted: 43 Post(s)
No that's not happening here
post #10 of 22 Old 11-10-2010, 12:59 PM
screwballl
2nd04Durango
screwballl's Avatar
There are a few possibilities, the ones that come to mind (remember these are just general mentions, each situation may be different):
The A/C clutch on the compressor is slowly going out, this usually has a increasing pitched whine as the RPMs increase starting around 1K RPM.
Transmission needs a drain and refil (but not a flush unless you have done that every 10K miles already). This usually has a kind of vacuum whine sound, starts in a very narrow range, like mine does it from 1600-1900 RPM, but as it gets worse as time goes on where it typically runs from 1500-2500 RPMs.
Fan clutch starting to go, this whine starts low and slowly winds up in pitch until around 2500 RPM then stays constant, even if RPMs go higher.
Mine has had a slight vacuum/turbo type pitch to it since we bought it at 40K miles which I have found is mostly the air intake is not 100% sealed, and then a slightly different whine coming from my transmission that needs a drain and refill.
04 Durango Limited 5.7L decked out with every option Dodge made at the time. 75,000 Miles as of July 2014
screwballl is offline
post #11 of 22 Old 11-10-2010, 01:07 PM Thread Starter
Dodge4L1fe
Quoted: 43 Post(s)
About 24K miles ago, the tranny was professionally flushed and refilled with synthetic. I will double check the air intake, but it doesn't sound like a turbo. It could be the fan clutch, but I don't think it has anything to do with the AC system as this occurs anytime, whether the AC is on or not.
post #12 of 22 Old 11-11-2010, 09:39 AM
piercejb
piercejb's Avatar
i think i get the same whining noise going up hills. I feel like it is a transmission noise.
2006 durango 4WD 4.7L 285/75/r17 nitto terra grapplers
Home made 2in body lift
Ready lift TB leveling keys
custom running boards
blacked out stock wheels
Yakima Roof Racks and Attachments
MagnaFlow, Resonator removed
Westin brush guard and tail guards
Hella off road lights
Durangos are for Off-Roading!
piercejb is offline
post #13 of 22 Old 11-11-2010, 09:54 AM Thread Starter
Dodge4L1fe
Quoted: 43 Post(s)
It might be... I'll see if it needs to be serviced when I get my tune up
post #14 of 22 Old 11-12-2010, 03:11 PM
screwballl
2nd04Durango
screwballl's Avatar
First, I would be curious about the synthetic... generally that is only recommended in high stress racing or drag transmissions on occasion, not everyday usage. In some cases, using anything outside of the originally recommended fluid can be cause for concern with many of these new vehicles since the late 90s. They are designed with certain specifications and fluids to work properly.
TSB 21-010-06
Automatic Transmission Fluid Usage ATF+4 (Type MS9602)
2004 - 2007 (HB) Durango
NOTE: ATF+4 must always be used in vehicles that were originally filled with
ATF+4. DO NOT USE ANY OTHER FLUID.
NOTE: ATF+4 is backward compatible with ATF+3 , ATF+2, and ATF+. Additionally,
ATF+4 can be used to top off vehicles that used ATF+3, ATF+2, or ATF+.
Sometimes simply removing the entire air intake hat, checking the seal around the air filter and other seals/connecting hoses can find it.
As for the AC system, it doesn't have to be in use or turned on inside to be affected, the belt is still turning the compressor which means it still monitors and charges the system and would still be affected.
post #15 of 22 Old 11-17-2010, 06:56 PM
rangoneer
Power Aficionado
rangoneer's Avatar
rear differential pinion bearing
05 LTD Black HEMI ...loaded with the basics
I NEED MORE POWER!! ...and to lose some weight!
rangoneer is offline
post #16 of 22 Old 11-17-2010, 07:10 PM Thread Starter
Dodge4L1fe
Quoted: 43 Post(s)
Well I'm not sure what the exact cause is, but I talked to another member and I found a way to fix it. I think it has to do with the fluids in the transfer case sitting in the cold weather. When I started up the D, I let it warm up a little bit and right before I put it in drive, I let it sit in neutral for a few seconds so the fluids cycle through the transfer case.
post #17 of 22 Old 12-01-2010, 06:53 PM
rangoneer
Power Aficionado
rangoneer's Avatar
any update?
post #18 of 22 Old 12-01-2010, 06:57 PM Thread Starter
Dodge4L1fe
Quoted: 43 Post(s)
Originally Posted by rangoneer View Post
any update?
Check the post above yours...
It seems to go away once the vehicle has warmed up to normal running temp
Also, I haven't noticed the "whine" as much lately
post #19 of 22 Old 12-01-2010, 07:09 PM
rangoneer
Power Aficionado
rangoneer's Avatar
yeah, I read that. Doesn't really seem like a "fix".
Does the transmission engage normally regardless of warm up?
post #20 of 22 Old 12-01-2010, 07:12 PM Thread Starter
Dodge4L1fe
Quoted: 43 Post(s)
yes
    Intake whine Jagsfan 3G Dodge RAM - General Talk 2 02-24-2009 08:37 PM
    trans whine? gear whine? me whining?? GrimReaper 3G Dodge RAM - Drivetrain Talk 12 09-16-2007 09:33 AM
    whine lwRam 3G Dodge RAM - General Talk 1 07-30-2007 12:49 PM
    Tranny whine? Haeusser 2G Dodge RAM - Drivetrain Talk 9 06-15-2005 05:35 PM
    whine rock60 3G Dodge RAM - Drivetrain Talk 0 09-10-2003 05:22 PM
