2001 caravan Crank sensor location - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 3 Old 10-20-2010, 03:28 PM Thread Starter
mculjat
Hello,
I need help locating the crank sensor on a 2001 3.3 caravan (no flex). I have seen a diagram of where it is supposed to be but when I look I cannot find it. Any help on location would be great.
Thanks!
mculjat is offline
post #2 of 3 Old 10-20-2010, 04:44 PM Thread Starter
mculjat
Found it -- it's in the same position as shown in the link below. Note however that the years, look of part etc are different so there's no air filter in the way but physical access to the sensor was achieved reaching into the same location (passenger side of battery) -- not an easy spot but it was there.
Thanks to all who looked!
mculjat is offline
post #3 of 3 Old 10-20-2010, 08:26 PM
penco8
in the 30 years I've been around these, the crank sensor on the 3.3 or 3.8 has been in the exact same spot since day 1 in the bellhousing. also I've only encountered a need to replace one! it is VERY easy to access take out the air filter hose and it's right there 10mm socket and that's it! passenger doesn't have a battery unless you have a right hand drive vehicle.
penco8 is offline
    need location of crank and cam position sensor daracer2 2G Dodge Dakota - Drivetrain Talk 1 07-24-2008 12:56 PM
    Location crank position sensor RonaldLora 2G Dodge Intrepid - General Talk 1 04-27-2007 09:06 PM
    97 caravan trans crank sensor ivantruckman Dodge Caravan General Talk 1 04-16-2007 02:03 PM
    crank sensor re-location chizzle1 2G Dodge Ram Performance Talk 9 08-07-2006 07:47 AM
    Replacing crank sensor 1996 Caravan 3.3 xtremexnyc Dodge Caravan General Talk 2 06-29-2006 12:39 PM
