Replacing Holley 6280 feedback Carb - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 8 Old 10-14-2010, 08:25 PM Thread Starter
XCA2139
I have recently purcahsed a 87 D150 4x4. I has a Holley 2bbl Carb with an electrical connector hooked to it. The wires go into the side of the carb itself. It also has the idle selenoid. Can I replace this carb with the Holley 2280 and just leave the wires that are for the 6280 unplugged or will I have any problems. I dont have to worry about any emmisions etc. Or is there some other things that would have to be done to run a 2280 in place of the 6280.
thanks in advance
XCA2139 is offline
post #2 of 8 Old 10-15-2010, 06:56 AM
Delray Dude
440 and a 4 speed
Delray Dude's Avatar
Unless there is something I'm not aware of, you should be ok to replace the carb. my 87 is a 2WD and I don't have any electrical connections to my 2 bbl carb. and i'm still (at the moment) running the factory computer. I have removed the air pump, it's true dual exhaust with no O2 sensor, and the cats were M.I.A. when i bought the truck - runs great.
Delray Dude is offline
post #3 of 8 Old 10-15-2010, 07:08 AM
Delray Dude
440 and a 4 speed
opps. I went out and looked at my truck - i do have an electrical connection to the carb. didn't have time - but before you replace - you might unplug the harness that goes to the carb and see if it causes a problem.
I'm planning on ditching the computer soon - so I'm pretty sure this is just a sensor that the computer uses to monitor, so i'd say unplug it and see what happens. if you ditched your computer already, then it should be no problems.
post #4 of 8 Old 10-15-2010, 08:25 AM
charlie1935
charlie1935's Avatar
Quoted: 6 Post(s)
I think that wire controls the air-fuel ratio to some degree. On my 87 if I'm not mistaken the O2 sensor is in the driver side ex. manifold. I'll look after while.
Grouchy Old Man
Sport short bed
R&S Automotive cat back duals
SSBC slotted rotors
Tri wing tonneau cover
Ultra 50/51 16x10 wheels
265 70x16 Firestone Destination LE tires
3.55 rear
99-01 sport headlights with Silverstar bulbs
MSD coil
Fram Boost intake -Freebie. I won it
Edelbrock shocks
Yes, grandpas like toys too
87 D100 318 auto. stock
Calling an illegal alien an 'undocumented immigrant' is like calling a drug dealer an 'unlicensed pharmacist'
charlie1935 is offline
post #5 of 8 Old 10-15-2010, 09:18 AM Thread Starter
XCA2139
I UNPLUGGED IT YESTURDAY AND DROVE IT HOME 12 MILES DIDN'T REALLY NOTICE ANY DIFFERENCE. THE ELECTRICAL CONNECTOR HAS I THINK 5 TERMINAL IN IT. PLUGS UP ON PASSENGER SIDE AND THEN RUNS TO DRIVER SIDE OF CARB. BUT REALLY DIDNT SEE ANY DIFFERENCE IN PERFORMANCE. I THINK I HAVE A FLOAT STICKING IN MY CARB AND CAUSING IT TO FLOOD AFTER I CUT IT OFF, EVEN HAS GAS RUNNING INTO THE VACUM CANISTER IN A 3/8 HOSE THAT COME OFF SIDE OF THE CARB WHILE SITTING. i WAS JUST WONDERING OF THERE IS THE SAME VACUM HOOK UP ON THESE CARBS. I WAS TOLD THEY ARE THE SAME EXCEPT FOR THE FUEL MIXTURE(ELECTRICAL) DEAL.
THANKS
XCA2139 is offline
post #6 of 8 Old 10-15-2010, 09:37 AM
charlie1935
Quoted: 6 Post(s)
I believe thats right on the electrical hook up. I noticed on some carb rebuilders site that they list one with the elect. and one with out it for 1987.
Grouchy Old Man
Sport short bed
SSBC slotted rotors
3.55 rear
MSD coil
Edelbrock shocks
post #7 of 8 Old 10-15-2010, 09:57 AM Thread Starter
XCA2139
I Just Dont Want To Order The 2280 With Out The Electrical Connection And Then There Be Some Differences In Vacum Lines Etc.
XCA2139 is offline
post #8 of 8 Old 10-15-2010, 11:55 AM
charlie1935
Quoted: 6 Post(s)
Well, I looked and there is no O2 sensor on the D 100, its on my 87 5th ave.
Also no electrics on the carb on the D 100. Just a solenoid with a 2 wire plug going to it.
Grouchy Old Man
Sport short bed
SSBC slotted rotors
3.55 rear
MSD coil
Edelbrock shocks
    What holley, or similar carb would i need? TireTrack 1972-1987 Dodge Ram Trucks (D, W-series) 12 07-07-2010 06:26 PM
    Rare Holley Carb threetwos For Sale - Truck Parts 2 11-13-2008 11:04 AM
    feedback carb (6280) connector hellbent_racer Dodge B-Series Vans 1971 - 2003 0 10-05-2008 12:23 PM
    Holley 6280 cfm rating & specs 87Dodgeman 1972-1987 Dodge Ram Trucks (D, W-series) 5 05-23-2007 07:33 AM
