Transgo shift kit for 09 Ram - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 42 Old 10-12-2010, 07:35 AM Thread Starter
sbarbs
sbarbs's Avatar
Anyone running a transgo shift kit in the 09 1500? I havent seen any application for the 09 but the trans hasn't changed for some time. I'm wondering if the computer will all but "undo" any changes the kit will make on performance. Any info would be appreciated.
2009 Dodge Ram 1500 QC - 5.7L, Superchips Tuner, Mufflex 14 inch Magnaflow Muffler with Factory Duals, Volant CAI, Catch Can, NGK plugs,180 stat, Transgo Reprogramming kit, Trans. line pressure booster, V6 Electric Fan,Amsoil Synthetics front to back, 5100 Bilstein leveling shocks, Powertrax Limited Slip, XD Spy wheels, Falken Wildpeak A/T tires, Pioneer AVH-P4400DVD, Infinity Component speakers, JL Audio Sub in Q Logic Enclosure, Kenwood 5 channel Amp, Stinger 1.2 Farad Cap, Weathertech floor liners, Debadged.....and more to come....
Future mods: AR Headers, Circle D converter, and 4" Superlift!!
sbarbs is offline
post #2 of 42 Old 10-12-2010, 07:07 PM
MGH
MGH's Avatar
I installed the kit and a line pressure booster about 6 months ago. This combination makes the shifts firmer and gets rid of most of the shutter in 3rd gear.
MGH is offline
post #3 of 42 Old 10-12-2010, 07:33 PM Thread Starter
sbarbs
sbarbs's Avatar
MGH, do yo know the part # of the kit you used? The application guide only goes to 07. I already have the pressure line booster installed.
sbarbs is offline
post #4 of 42 Old 10-12-2010, 07:50 PM
MGH
MGH's Avatar
The kit for the '07 is the one you need. Dodge has not made any changes to the inside of the 545 for a few years.
MGH is offline
post #5 of 42 Old 10-19-2010, 11:06 AM
RODGE84
Are you using a shift kit or the reprogramming kit?
RODGE84 is offline
post #6 of 42 Old 10-19-2010, 01:44 PM
Ramjoe
Quoted: 3 Post(s)
what does the line pressure booster do for a stock setup ...is there any benifits to just purchasing that.
Ramjoe is offline
post #7 of 42 Old 10-19-2010, 05:40 PM
MGH
MGH's Avatar
Reprogramming kit
MGH is offline
post #8 of 42 Old 10-20-2010, 08:15 AM
Ramjoe
Quoted: 3 Post(s)
anyone?
Ramjoe is offline
post #9 of 42 Old 10-20-2010, 09:42 PM Thread Starter
sbarbs
sbarbs's Avatar
The line pressure booster is a plug and play adapter that allows the TCM to increase line pressure in the transmission. The increased line pressure allows for the a tighter grip on the clutches. This will give you a slightly firmer shift and decrease potential slippage with the increased power output from the engine due to modifications.
sbarbs is offline
post #10 of 42 Old 10-20-2010, 10:05 PM
HEMI-PWRD
09 HEMI
HEMI-PWRD's Avatar
How much is this shift kit and line cost??
09 HEMI - CC SB
13.3 @100.6
Go to
for all your truck needs!!!
RIPPs Supercharger!, L&M CUSTOMS Transmission with Mag-Hytec trans pan, MGH/RIPPs tune, 2800-3000 Circle-D Stall Single Billet, 4.10 Gears, JBA Shorty headers with no CATS & custom Y-PIPE to Flowmaster SI/DO, Moe's 87mm TB, Diablo Intune, Moes pillard with boost and air/fuel gauges, 180 T-stat, Mopar V6 Efan, Denso 1 stage colder plugs, 3/5" drop, R/T hood, 2013 Sport wheels on Kuhmos staggered, Shaved grille-antenna-tailgate, HIDs, BT HEMI "T" shifter, and everything painted to match.
Next: Moe's Catch can, re-do tint, spray in bed-liner......
HEMI-PWRD is offline
post #11 of 42 Old 10-20-2010, 10:06 PM
HEMI-PWRD
09 HEMI
HEMI-PWRD's Avatar
Also.. about how much hp?? or reduction of 1/4 would it be with this mod?
09 HEMI - CC SB
13.3 @100.6
Go to
post #12 of 42 Old 10-26-2010, 11:56 AM Thread Starter
sbarbs
sbarbs's Avatar
Spoke with Transgo today. The kit can be bought from Summit for about $60. Part # is 545rfe-hd2. It's the reprogramming kit. The guy I spoke with said it will firm up shifts, but don't expect miracles. Basically the adaptive capability of the TCM will want to try and soften the shifts up on its own. The kit will prohibit that form happening completely. This kit comes with a line pressure booster as well for an increase of 30 psi in line pressure. He said some truck were throwing codes with it installed. The Sonnax one I have he said will be fine cause it only raises pressure 15psi. I thinks when Im ready to change my fluid, I will give this kit a try.
sbarbs is offline
post #13 of 42 Old 11-03-2010, 09:52 PM Thread Starter
sbarbs
sbarbs's Avatar
Just got the kit from summit and my ATF from Amsoil. I'm hoping to get this kit installed this weekend and do a filter change and fluid flush with the Amsoil ATF. While under there, going to replace transfer case fluid, and do the Diff fluids as well. I'll keep everyone posted on the results!
sbarbs is offline
post #14 of 42 Old 11-05-2010, 07:07 PM Thread Starter
sbarbs
sbarbs's Avatar
Well after a messy couple of hours I got the Transgo kit installed and flushed the trans and installed Amsoil ATF. Took it for a test drive and I can say that it shifts a bit better. Not a miraculous change, but shifts are firmer and quicker. I'll have to drive it a while more, especially on the highway to see if it was worth the money and time spent. At least I was able to put new filters in and a good quality synthetic ATF. I'll keep you guys posted as to the performance change.
sbarbs is offline
post #15 of 42 Old 11-05-2010, 08:51 PM
HEMI_ROM
Thanks for taking the time to write up your experience with this kit, good job.
2009 RCSB Sport 4x4 Ram, 3.92LSD, Superchips Flashpaq 93 Tune 8% TM, AFE Stage 2 CAI - Yeah its got a Hemi
HEMI_ROM is offline
post #16 of 42 Old 11-13-2010, 07:20 AM Thread Starter
sbarbs
sbarbs's Avatar
Just an update. As most of you know, the Dodge has an adaptive feature to its shifting based on your driving style. Well after driving the truck "hard" on the highway for about 10 miles, This thing shifts like a son of a bitch!!! Got off the highway and it act slike a totally different truck. I would love to check out my 0-60 with it shifting this good. You hammer the throttle and it flys! Love the transgo kit/sonnax combo. HIGHLY RECOMMENDED!
I think now I will have to upgrade my Torque converter to really take full advantage of the power. I've been looking at the Circle D billet converter. I think a slightly higher stall speed would launch this truck like crazy. WIth that I'll also need a Posi rear to make her hook up. $$$$$$$$$$
sbarbs is offline
post #17 of 42 Old 11-13-2010, 09:59 AM
JamesonS
Military Member
We need a write up with pics on the install
2011 Dodge Ram 1500 Laramie 4x4 - Bilsteins/Body Lift, 33" M/Ts on x12s,5% Windows, 35% Shield, Debadged, CBE
JamesonS is offline
post #18 of 42 Old 11-13-2010, 10:54 PM
Bubba_Hemi
5 Years... 6 Dodges
Bubba_Hemi's Avatar
So the kit comes with a line booster? But it's a 30psi one and the Sonnex is 15psi?
Did you keep your Sonnex one in or swap out the one that came with the kit?
WCOG
2009 Dodge Ram
1500 QC SB
TOTM- October '04: '04 Ram 2500 CTD 600 QC SB..........'05 Dodge Stratus SXT SE: October '05- COTM
Posting Foolishness 69.12% of the time
You have one hell of an interesting perspective on things... and by "interesting", I mean retarded
Bubba_Hemi is offline
post #19 of 42 Old 11-14-2010, 10:16 AM Thread Starter
sbarbs
sbarbs's Avatar
The kit doesn't come with a pressure booster. When I originally spoke with Transgo I was told it did,but when I got the kit it wasnt in there. Regardless I was told the one Transgo has wasnt working with the kit. I bought the Sonnax before I had the kit anyway. I think the sonnax was around $50 or so. Im very happy with the combo.
As far a write up. I didnt snap any photos. The instruction with the kit have clear pix and directions of the valve body. The only other thing you may need is torque specs on the reinstallation of the valve body and pan. I got my specs from my shop manual. The install is pretty straight forward, just be prepared to get dirty and full of fluid, if you are lying on your back under the truck. Wish I had a shop to work in.
sbarbs is offline
post #20 of 42 Old 11-14-2010, 03:11 PM
Bubba_Hemi
5 Years... 6 Dodges
Bubba_Hemi's Avatar
Yea, I bought the Sonnex a few months back and have been happy with it too... but it's always nice to get more. May look into doing this mod too.
WCOG
2009 Dodge Ram
1500 QC SB
    transgo shift kit megacab2500 3G Dodge RAM Diesel Talk 1 01-23-2010 04:38 PM
    transgo shift kit ?? superram8 3G Dodge Ram Performance Talk 23 09-16-2009 09:22 PM
    Transgo shift kit nickd907 3G Dodge RAM Diesel Talk 1 04-21-2009 08:26 AM
    Transgo shift kit which one heavy hemi 3G Dodge Ram Performance Talk 27 08-17-2007 02:21 AM
    transgo shift kit ApkRam 3G Dodge Ram Performance Talk 3 12-20-2006 08:55 PM
