Trans trouble code P0750 - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 16 Old 10-05-2010, 11:44 PM Thread Starter
Shanes66
SLOWER TRAFFIC KEEP RIGHT
Shanes66's Avatar
I m getting the code - shift solenoid error.
Can one just replace the shift solenoid? Is that part of the TCM? How hard to swap out the TCM, I know it is up on the firewall/fender area under the hood....
Thoughts?
2013 Dodge Challenger R/T
Super Track Pak - 3.92 - 6 spd
Shanes66 is offline
post #2 of 16 Old 10-06-2010, 01:29 PM
Rich 2500
Rich 2500's Avatar
The Shift Selenoid Pack is located on the valve body, you must drop the Tran. pan to get to it. Check page 21-452 in in following link.
Link:http://www.hotrodlane.cc/New%20HEMI%...mi%20trans.pdf
Elec. Blue 07 2500 Thunderoad QC Hemi 4X4
BTC #181
Mopar Cai, Mopar SS Nerf Bars, Mopar Tow Mirrors, Mopar Wheel Well Liners, EGR In Channel Window Vents, Tinted Windows 30%, Hella 500's behind the grill, Gibson Dual Sport Catback Exhaust, Magna Flow "Y" Pipe, Jet Stream Scoop, Power Wire, LineX Bedliner, Flexalite 180 Efan (shrouldless), Jet 180 Thermostat, Edge Evolution (used as monitor) DiabloSport Predator, Solid Steel Industries-Steering Stabilizer, Carli Starter Suspension System, Carli Adj. Track Bar, Toyo 35/12.50/17 MT on Stock Wheels, Carli Anti Sway Bar, Xeon Fogs 6000K
Rich 2500 is offline
post #3 of 16 Old 10-06-2010, 05:27 PM Thread Starter
Shanes66
Shanes66's Avatar
Thanks... Looks expensive!
Shanes66 is offline
post #4 of 16 Old 10-06-2010, 06:31 PM
Full Throttle
Full Throttle's Avatar
Quoted: 1 Post(s)
Just curious but did u use the key trick to get the code on the dash?
Full Throttle is offline
post #5 of 16 Old 10-06-2010, 08:52 PM
dmcelhannon
Admin - David Mack
dmcelhannon's Avatar
Quoted: 243 Post(s)
Ouch! Maybe a new Stage I - VB would cheaper; just a thought.
dmcelhannon is offline
post #6 of 16 Old 10-07-2010, 12:08 AM Thread Starter
Shanes66
Shanes66's Avatar
Full Throttle - Yes, but I also have the SC Tirepaq. It reads and clears codes.
dmcelhannon - PLEASE TELL ME MORE!!!
Shanes66 is offline
post #7 of 16 Old 10-07-2010, 01:10 AM
dmcelhannon
Admin - David Mack
Quoted: 243 Post(s)
SharaDon Performance - 45RFE & 545RFE - STAGE-II VALVE BODY
http://www.sharadon.com/sdparts.htm
post #8 of 16 Old 10-07-2010, 01:27 AM
Full Throttle
Quoted: 1 Post(s)
Just wondering have any of u experienced a red flash on the dash, in the small hole to the right of mph guage and left of water temp, it's a small hole, I've seen it flash a few times when turning the truck on?
post #9 of 16 Old 10-07-2010, 01:50 AM Thread Starter
Shanes66
Shanes66's Avatar
Full Throttle - I don't think so... but I can't say i have looked for it. What does the red flash mean?
dmcelhannon - Thanks!
Shanes66 is offline
post #10 of 16 Old 10-07-2010, 01:57 AM
Full Throttle
Quoted: 1 Post(s)
I have no idea what it means, but I have seen it flash a few times, but next time u start up your truck, look to see if u see a red flash
post #11 of 16 Old 10-07-2010, 02:43 AM
crasher76
Im wired!!!
crasher76's Avatar
low voltage, or a bad connection to your cluster
Black 2003 QC SB SLT 4x4 Offroad 5.7L HEMI, Original Owner 3.92 LSD, 260 cam, 6.1 Rods/Springs, Home Ported/Polished Heads, Psc1, 04 Map sensor and Fuel pump assembly, Oil pressure guage, Amsoil, Champs, MSD 8.5MM Full length Wires, Transgo HD w/out resistor, Superchip, 180 T-Stat, K/N 77 Series, Ceramic Flowtech headers with Y-Pipe, Stage 8 locks, Ditched the cat, O2 sensor mod, Jack Rabbit bed cover, Sprayed bed liner, Big Mouth Grill-Black, Blackend Headlights/Tails, Silverstar ultras, Ditched all chrome, Custom 10's sub enclosure, Upgraded 160 amp alt, Window tint, Relocated purge valve, Energy suspension bushings, Rear spring clamps, Rebuilt front suspension, Ditched Sway Bar, Passport 8500 Radar Detector, Ditched the baby seat- kid wasnt mine, Cigarette burn in the seat mod, Debadged, Custom Rewired/Properly Grounded.
crasher76 is offline
post #12 of 16 Old 10-07-2010, 02:52 AM
dmcelhannon
Admin - David Mack
Quoted: 243 Post(s)
... that's the 'Security Indicator' light.
post #13 of 16 Old 10-07-2010, 04:59 AM
Full Throttle
Quoted: 1 Post(s)
I just wondering since I've only seen the light while starting the truck, could it be the voltage of the battery, I still have the same battery from when I bought the truck new, about 8 years, so could this solve the problem? Sorry for taking your thread of topic, but as for tranny components check airram.com I think they have parts for the tranny?
post #14 of 16 Old 10-07-2010, 01:12 PM
dmcelhannon
Admin - David Mack
Quoted: 243 Post(s)
I just wondering since I've only seen the light while starting the truck, could it be the voltage of the battery, I still have the same battery from when I bought the truck new, about 8 years, so could this solve the problem? ....
That's old for a battery but I believe I would test it before I just replace it.
post #15 of 16 Old 10-07-2010, 01:39 PM Thread Starter
Shanes66
Shanes66's Avatar
Back to the transmission issue...
The website provided says the solenoid pack can be installed with simple hand tools.... Has anyone done this yet, and was it that easy of a job. I have simple hand tools and with enough pictures/detailed instructions feel that I am able to do it myself.... But it would be nice to hear from someone who has done the swap.... Also would this get rid of my P0750 Code...
Shanes66 is offline
post #16 of 16 Old 10-07-2010, 02:04 PM
dmcelhannon
Admin - David Mack
Quoted: 243 Post(s)
I've not done enough tranny work to say yes or no. I believe a good person for you to talk too is sawcut64 (Sam). Sent him a PM and pick his gray matter on this one.
edit: Seeing that the error has to do with an open or bad circuit, I think I would check the wiring harness, the connections, and grounds on the tranny before I started to drop money into the transmission.
    1997 P0750 P0700 Limp mode CrushtrepwRam Dodge Intrepid 1st Gen (93 - 97) 4 08-24-2009 07:02 PM
    p0700 and p0750 codes...help me... faststangxxx 3G Dodge Ram Performance Talk 13 12-23-2008 09:18 PM
    '08 Caravan, Trouble code 622 and 72, How to check trans fluid cgustafs Dodge Caravan General Talk 2 10-27-2008 12:44 PM
    odd trans code and trans problem NightWolf51 2G Dodge RAM - Drivetrain Talk 1 10-24-2005 04:44 PM
    Trans Trouble Code flsts 2G Dodge Dakota - Drivetrain Talk 3 12-17-2004 01:51 PM
