crankcase vent - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 6 Old 09-26-2010, 07:15 PM Thread Starter
bigdogg
bigdogg's Avatar
crankcase vent
i never noticed this till today but is it normal to be getting exhaust?/ smoke out of the crankcase tube
12 ram 1500 laramie- stock
09 ram 1500 sport- Traded
03 dodge ram 4x4 1500 Reg/Sb with hemi- Traded
97 dodge ram 2500 4x4 ext cab/long box with 12v Cummins- 5" stacks
Banks quick turbo(37psi), banks twin ram intake, Brute force HD CAI, pyro and boost gauge, pulled fuel plate out and turned starwheel
"living the black gold rush"
bigdogg is offline
post #2 of 6 Old 09-26-2010, 07:44 PM
Clunk
Clunk's Avatar
Quoted: 19 Post(s)
Looks pretty nasty doesn't it? It smells even worse.
You ever see those Super Stock tractor pullers pulling? You see their blow-by coming out the bottom of the engine? Ours isn't that bad.
'01.5 2500 4x4 Red QC Sport HO SWB, 6spd.,cowl hood, 4" ex., Edge Drag Comp, Banks boost & pyro pillar mount, single black Holley 140gph lift pump...13psi WOT, US Gage & 4 grease gun lines for fuel pressure monitor, 2% Biodiesel in the tank, Amsoil in the trans and Valvoline in the pan. Vulcan Big Line kit, Napa #2790 BHAF, cheapo fuel cooler, Jammer 100's, Cat C300 turbo 3.55 gears jes' like Ram3500Dually sez..., ARP studs,
Take time to turn so's you don't burn.
Clunk is offline
post #3 of 6 Old 09-26-2010, 07:47 PM Thread Starter
bigdogg
bigdogg's Avatar
ya looks a little strange, like i said i never noticed till today. i need to add oil tomorrow maybe that well stop it
bigdogg is offline
post #4 of 6 Old 09-26-2010, 08:00 PM
Clunk
Clunk's Avatar
Quoted: 19 Post(s)
All internal combustion engines produce a certain amount of combustion gas leakage past the piston rings...even "gapless$$$" rings leak a little.
The PCV valves on gassers re-introduce those gasses to the intake manifold. Our diesels can't take the chance of those gasses possibly condensing back to oil then accidently getting a slug of that oil to make uncontrolled power/runaway since getting off the throttle won't stop the slug because there's no throttle butterfly like a gasser.
Clunk is offline
post #5 of 6 Old 09-26-2010, 08:56 PM
Bluedually4x4
Bluedually4x4's Avatar
Its part of owning a diesel. The higher compression ratio also contributes to it as well.
1998 1 ton dually 4x4. 12valve Cummins 5 speed manual. TST # 10 fuel plate DPI 75 hp injectors ATS 3 piece exhaust manifold BHAF intake 5" Turbo back exhaust dual 5" stacks South Bend 13.5 clutch 2001 flip out towing mirrors 16 degrees of timing and 3000GS BD Super B turbo
Dynoed at 452 horse power
And over 900 foot pounds
Bluedually4x4 is offline
post #6 of 6 Old 11-09-2010, 05:15 AM
speedy81304
also some of that vapor or smoke you see. is oil vapors as oil gets hot is burns off vapor, kinda like water just before it boils. you will see steam. you can do like i did and extend the crank case breather tube. to help keep some of the oil mist from getting all over my engine bay. I ran the tube down and infront of the engine crossmember.
my 05 doesnt do it as much as the 01 does. but yes its wierd when you come to a stop at the end of an off ramp. and you see some smoke in front of your truck and it smells like burning oil. first time when i got the truck i thought O crap i got a bad oil seal leaking. and opened the hood to find no oil leaks. but some vapor coming out the breather tube. as stated the higher compression ratio, and the amount of heat with in the cylinders as oil hits the bottom of the hot pistons gasses build up.
just be glad. your not driving an old 2stroke diesel like an old 8-71 screamer. they smoke and burn off oil like oil is free.
speedy81304 is offline
    Crankcase breather Mudchucker 3G Dodge Ram Performance Talk 4 12-23-2007 11:53 AM
    crankcase vent tube OncGMnowHemi 3G Dodge Ram Performance Talk 15 07-13-2007 10:18 AM
    05 Cummins Crankcase vent tube spitting oil Hopi 3G Dodge RAM Diesel Talk 8 01-01-2007 08:50 PM
    c.a.intakes, crankcase vent? fitzer 2G Dodge Dakota Performance Talk 4 08-14-2006 07:01 PM
    1998 Stratus defogger vent suddenly changes to front vent Stratfan Dodge Stratus 1st Gen (95 - 00) 0 03-05-2006 11:01 AM
