Intrepid Check Fault Codes - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 15 Old 09-22-2004, 06:46 PM Thread Starter
RAM MAN
Originating Member
RAM MAN's Avatar
Lightbulb Intrepid Check Fault Codes
Checking Fault Codes
To obtain fault codes using the MIL (Check Engine Light):
1. Cycle ignition key to ON, OFF, ON, OFF, ON within 5 second (do not actually crank engine!!)
2. Count the number of times the MIL on the instrument panel flashes on and off. The number of flashes represents the trouble code. There is a slight pause between the flashes representing the first and second digits of the code. Longer pauses seperate the individual two digit trouble code.
Example: Lamp flashes 4 times, pauses, then flashes 6 more times. This is an indicates a DTC of 46.
3. Lamp will always flash 55 at the end of the test. This signals the end of the test.
MIL Code
Description of Diagnostic Trouble Code
12*
Battery has been disconnected within last 50 key-on cycles
55*
Completion of fault code display on Check Engine Lamp
54**
No camshaft signal detected during cranking
53**
PCM Internal Fault detected
47***
Battery voltage sense below target charging during engine operation
46***
Battery voltage above target charging during engine operation
42*
Open or shorted condition detected in the auto shutdown relay circuit
41***
Open or shorted condition detected in the generator field control circuit
34*
Open or shorted condition in the Speed Control vacuum or vent solenoid circuits
33*
Open or shorted condtion detected in the A/C clutch relay circuit
32**
Open or shorted condtion detected in the EGR transucer solenoid circuit
31**
Open or shorted condtion detected in the duty cycle purge solenoid circuit
27**
Injector #3 or #2 output driver doesn't respond properly to the control signal
25**
Open or shorted condtion detected in one or more of the idle air control motor circuits
24**
Throttle Position Sensor input above/below acceptable voltage limits
22**
Engine Coolant Temperature Sensor input above/below acceptable voltage limits
17*
Engine did not reach operating temperature within acceptable limits
15**
No vehicle speed sensor signal detected during road load conditions
14**
MAP sensor input above/below acceptable voltage limits
13**
No difference recognized between the engine MAP reading and the barometric (atmospheric) pressure reading from start-up
11*
No crank reference signal detected during engine cranking
43**
Peak primary circuit current not achieved within maximum dwell time (could be on ignition coil #1, #2 or #3)
42*
Open condition detected in the ASD Relay Output Circuit
32**
Required change in air/fuel ratio not detected during diagnostic test
62*
Unsuccessful attempt to update EMR mileage in the PCM EEPROM
63**
Unsuccessful attempt to write to an EEPROM location by the PCM
23**
Intake air temperature sensor input above/below acceptable limits
16*
Knock sensor either shorted to ground or 12 volts. Will not detect open circuit
61
Barometric pressure out of range
27**
Injector #4 output driver does not respond properly to the control signal
53**
PCM internal fault detected
27**
Injector #5 or #6 driver does not output does not respond properly to the control signal
77*
Malfunction detected with power feed to speed control servo solenoids
34*
Speed control switch input above/below acceptable voltage limits
33
A/C pressure sensor input above 4.9 volts/below .098 volts
35**
Open or shorted condition detected in the control circuit of the low/high speed radiator fan
66
No messages received from Transmission Control Module / No messages received from Body Control Module
42*
Open of shorted condition detected in the fuel pump relay control circuit
43**
Misfire detected (hook up scan tool reader to determine which cylinder)
31*
Insufficient or excessive vapor flow detected during evaporative emission system operation
37**
Incorrect input state deteceted for the Park/Neutral switch
52**
Rich air/fuel mixture has been indicated by an abnormally lean correction factor
51**
Lean air/fuel mixture has been indicated by an abnormally rich correction factor
17**
Engine does not reach 20F within 5 minutes with a vehicle speed signal
24**
TPS signal does not correlate to MAP sensor
14**
5 volt output to MAP sensor open
45**
Automatic transmission input DTC has been set in the transmission controller
25**
Actual idle speed does not reach target idle speed
71**
5 volt output from regulator does not meet minimum requirement
42*
Open circuit between PCM and fuel gauge sending unit / Circuit shorted to voltage between PCM and fuel gauge sending unit / No movement of fuel level sender detected
65**
No release of brake switch seen after too many accelerations
44**
Battery temperature sensor input voltage above/below acceptable limits
11**
Intermittent loss of either camshaft or crankshaft position sensor
72**
Catalyst efficiency below required level
21**
O2 sensor
11**
CKP sensor target windows have too much variation
21
Oxygen Sensor reponse slower than minimum required
* - Check Engine Lamp will not illuminate if this Diagnostic Trouble Code was recorded. Cycle Ignition key as described and observe code flashed by Check Engine Lamp
** - Check Engine Lamp will illuminate during engine operation if this DTC was recorded.
*** - Generator Lamp illuminated
Good luck on your project.
RAM MAN is offline
post #2 of 15 Old 11-11-2004, 04:23 PM
peter_w67401
peter_w67401's Avatar
As I understand this the proceedure you mentioned it only works up to and including 1996 models. I guess there was a change in the OBD II in '97 that deleted this function. Is this true or does the key flip function still trigger the codes on the check engine light on models built after 1996?
peter_w67401 is offline
post #3 of 15 Old 01-31-2005, 08:52 PM
MomtoCamNC
MomtoCamNC
Wink Checking codes on 96 and later models
I checked mine today, it does work on newer models, I have a 2001 Intrepid ES. Nice to know I can locate the codes myself without having to take the car in to the dealership and get ripped off everytime with a 90$ fee.
Found this site tonite, glad to be here.
MomtoCamNC is offline
post #4 of 15 Old 02-08-2005, 08:13 AM
anseladams
Quick question, I have a fault code of 12, battery has been disconnected uring the last 50 starts. How do I clear the check engine light then.
Thank you in advance for your reply.
Nick
anseladams is offline
post #5 of 15 Old 02-08-2005, 10:32 AM
peter_w67401
As I understand the computer on these cars code 12 should not turn on the check engine light. Is code 12 the only code you are getting? The codes can be cleared with a scan tool or by disconnecting the battery ( so much for code 12) and with the cables disconnected touch the cables together to dissipate any stored current. This should wipe the computer (and all your presets on the radio......nuts!). Then run the car for a bit and if the check engine light comes back on again I would have the car scanned by someone with a scan tool or take it to a shop. There are some codes that will not display with the key flip feature. If you have access to a Haynes manual or similar book I would also consult it. Good luck..........................Pete
post #6 of 15 Old 02-08-2005, 10:38 PM
ANISINTREPID
Question Code 1684 In 99 Dodge Intrepid
I had a 1684 code in my 99 dodge intrepid,i changed the battery and i checked again i stilll have the same code,whats should i do to clear it.
even when i changed the battery the radio stations are still in the memory could it be that the code is still in the memory.
ANISINTREPID is offline
post #7 of 15 Old 02-08-2005, 10:43 PM
peter_w67401
Try disconnecting the battery cables and touching them together after they are both free from the battery and then reconnecting them to the battery. This shoud erase the computers memory as well as the radio....................Pete
post #8 of 15 Old 02-09-2005, 05:25 AM
anseladams
Pete,
Thanks it worked, I don't have the check engine light, and I drove my Intrepid for awhile and so far no check engine light. An auto parts store that does free code scanning had said it was my oxygen sensor (again), thought when checking the flashing check engine lights I only came out with error codes 12 and 13, now they're gone. I just learned about turning the ignition key three times to get the flashing code, I didn't know this car had such a feature. I took my wife's Kia to same auto parts store with a check engine light, they said it was her anti theft system, the car does not have one, turns out to have been a clogged air filter. Are those code scanners that good?
Nick
post #9 of 15 Old 02-09-2005, 03:16 PM
peter_w67401
Yes they can be. You can got to a web sight www.obddiagnostics.com. They have an interface box for about $80.00 and a free program you can down load to turn your pc or lap top into a code scanner and engine monitor. It is pretty effective and will work with some pretty unsophisticated computers. The set up works on 1996 and newer cars as they have the OBD II setup. It will work on your KIA as well as your Dodge. It isnt as sophisticated as a true scan tool but for the do it your self type it is a great tool to have...............................Pete
post #10 of 15 Old 03-10-2005, 12:04 PM
OutKzt
Okay - I got a bunch of codes
12 (We know this is not a big proble), 31, 51 & 45.
What should I do ???
OutKzt is offline
post #11 of 15 Old 03-10-2005, 12:19 PM
OutKzt
Nevermind
Forget my last question.
I cleared the computer using the method described in this thread and drove around and guess what no more check engine light. I guess when I had my engine put in a few weeks ago they forgot to do this.
Thanks for all the tips.
OutKzt is offline
post #12 of 15 Old 03-20-2005, 10:36 PM
slucas130
slucas130's Avatar
I ran across these tips on my Avenger Owners group page (http://www.asog.net/phpBB21/portal.php). There a list of all the mopar codes and this trick does work for newer rides. I just bought an '02 Intrepid last week and it worked.
I am the light. What you seek is fire!
~95 Avenger~96 Grand Carvan~02 Intrepid~
slucas130 is offline
post #13 of 15 Old 04-07-2005, 04:44 PM
Ahimoth687
Thumbs up Fault Codes: 1999 Digital Read Out
My 1999 Intrepid uses digital output so my error codes, although reached the same way (on/off comb 3x), I get 4 digits that I couldn't find in the above codes. I googled it and found the following:
1999 Dodge Intrepid Computer Codes
Code What it means
30 Sensor heater relay problem
36 Sensor heater relay problem
106 MAP sensor voltage out of range detected at startup
107 MAP sensor voltage too low
108 MAP sensor voltage too high
112 Intake air temperature sensor voltage low
113 Intake air (charge) temperature sensor voltage high
116 Coolant temparature sensor reading doesn't make sense
117 Engine coolant temperature sensor voltage low
118 Engine coolant temperature sensor voltage high
121 Throttle position sensor and MAP sensor disagree with each other
122 Throttle position sensor voltage low
123 Throttle position sensor voltage high
125 Taking too long to reach proper operating temparature and switch to energy-efficient mode
130 Sensor heater relay problem
131 Oxygen sensor seems to be shorted out or broken
147 Oxygen sensor heater element not working properly (this device helps to reduce emissions more quickly)
151 Oxygen sensor voltage problem - short circuit to ground?
152 Oxygen sensor voltage problem - short circuit to active 12V?
153 Oxygen sensor response too slow
154 Oxygen sensor does not show either a rich or lean condition - may need replacement
155 Oxygen sensor heater element not working properly (this device helps to reduce emissions more quickly)
157 Oxygen sensor voltage problem - short circuit to ground?
158 Oxygen sensor voltage problem - short circuit to active 12V?
159 Oxygen sensor response too slow
160 Oxygen sensor does not show either a rich or lean condition - may need replacement
161 Oxygen sensor heater element not working properly (this device helps to reduce emissions more quickly)
171 The oxygen sensor is saying that the system air/fuel mix is far too lean (too much fuel is being added as a correction).
172 The oxygen sensor is saying that the system air/fuel mix is far too rich (too much air is being added as a correction).
174 The oxygen sensor is saying that the system air/fuel mix is far too lean (too much fuel is being added as a correction).
175 The oxygen sensor is saying that the system air/fuel mix is far too rich (too much air is being added as a correction).
176 Flex fuel sensor can't be seen
178 Flex fuel sensor problem
179 Flex fuel sensor problem
182 Compressed natural gas temperature sensor problem
183 Compressed natural gas temperature sensor problem
201 Injector #1 control circuit problem (open or shorted)
202 Injector #2 control circuit problem (open or shorted)
203 Injector #3 control circuit problem (open or shorted)
204 Injector #4 control circuit problem (open or shorted)
205 Injector #5 control circuit problem (open or shorted) (doesn't apply to PT Cruiser!)
206 Injector #6 control circuit problem (open or shorted) (doesn't apply to PT Cruiser!)
207 Injector #7 control circuit problem (open or shorted) (doesn't apply to PT Cruiser!)
208 Injector #8 control circuit problem (open or shorted) (doesn't apply to PT Cruiser!)
209 Injector #9 control circuit problem (open or shorted) (doesn't apply to PT Cruiser!)
210 Injector #10 control circuit problem (open or shorted) (doesn't apply to PT Cruiser!)
300 Misfire detected in multiple cylinders.
301 Misfire detected in cylinder #1.
302 Misfire detected in cylinder #2.
303 Misfire detected in cylinder #3.
304 Misfire detected in cylinder #4.
305 Misfire detected in cylinder #5. (Obviously not a problem for PT Cruisers)
306 Misfire detected in cylinder #6.
307 Misfire detected in cylinder #7
308 Misfire detected in cylinder #8.
309 Misfire detected in cylinder #9.
31 0 Misfire detected in cylinder #10.
320 Crankshaft position sensor reference signal cannot be found while the engine is cranking.
325 Knock sensor (#1) signal is wrong.
330 Knock sensor (#2) signal is wrong.
340 No camshaft signal being received by the computer
350 A coil is drawing too much current.
351 Coil #1 is not reaching peak current at the right time
352 Coil #2 is not reaching peak current at the right time
353 Coil #3 is not reaching peak current at the right time
354 Coil #4 is not reaching peak current at the right time
355 Coil #5 is not reaching peak current at the right time
356 Coil #6 is not reaching peak current at the right time
357 Coil #7 is not reaching peak current at the right time
358 Coil #8 is not reaching peak current at the right time
401 A required change in air/fuel mixture was not detected during diagnostic test.
403 An problem was detected in the EGR solenoid control circuit.
404 The EGR sensor's reported position makes no sense
405 EGR position sensor voltage wrong.
406 EGR position sensor voltage wrong.
412 The secondary air solenoid control circuit seems bad (this is used for the aspirator).
420 The catalyst seems inefficient (#1).
432 The catalyst seems inefficient (#2).
441 Evaporative purge flow system not working properly
442 A leak has been detected in the evaporative system!
443 Evaporative purge flow system solenoid not working properly
455 A large leak has been detected in the evaporative system!
456 A small leak has been detected in the evaporative system!
460 The fuel level sender is not reporting any change over a long distance. Something seems wrong.
461 The fuel level sender is not reporting any change over a long time. Something seems wrong.
462 Fuel level sender voltage wrong.
463 Fuel level sender voltage wrong.
500 Haven't heard from the speed sensor lately.
505 The idle speed air control motor doesn't seem to be working correctly.
522 Oil pressure sensor problems
523 Oil pressure sensor problems
551 The power steering switch may not be working. (Neons: high pressure is showing up at high speed)
600 Oh-oh! The coprocessors aren't talking to each other within the computer!
601 Internal computer error!
604 Internal computer error! (RAM check)
605 Internal computer error! (ROM)
615 Starter relay circuit problem
622 Generator field control problem
645 A/C clutch relay circuit problem.
700 The automatic transmission computer or Aisin computer has a problem - ask it what's going on. I don't know.
703 Brake switch circuit information seems wrong.
711 Based on the transmission temperature and its operations, it looks like the transmission temperature sensor's gone bad.
712 Transmission fluid temperature sensor voltage wrong.
713 Transmission fluid temperature sensor voltage wrong.
720 The Output Shaft Speed Sensor doesn't match the reported vehicle speed.
740 The engine's running faster than it should for these speeds, so I think thetorque convertor clutch lock-up system is bad
743 Torque converter clutch (part throttle unlock) solenoid circuit problem - shift solenoid C electrical fault
748 Governor Pressure Solenoid circuit problem (Transmission relay circuit problem in Jeep RE transmissions)
751 Overdrive override switch has been pressed for over five minutes. Just thought you should know.
753 Overdrive solenoid control circuit problem (transmission relay circuit in Jeep RE transmissions.)
756 Shift solenoid B (2-3) fault
783 The overdrive solenoid can't go from 3rd gear to the overdrive gear.
801 Transmission reverse gear lockout solenoid circuit problem!
833 Problem with the clutch-released switch circuit?
1192 Inlet air temperature sensor voltage is wrong
1193 Inlet air temperature sensor voltage is wrong
1194 Oxygen sensor heater performance is faulty
1195 Oxygen sensor is slow
1196 The oxygen sensor switched too slowly (bank 2).
1197 The oxygen sensor switched too slowly (bank 1).
1198 Radiator coolant temperature sensor voltage is wrong.
1199 Radiator coolant temperature sensor voltage is wrong.
1281 The engine is staying cold too long - check your thermostat.
1282 The fuel pump relay circuit seems to be having a problem.
1288 The intake manifold short runner tuning valve circuit seems to be having a problem.
1289 There's a problem in the manifold tuning valve solenoid control circuit.
1290 Compressed natural gas system pressure is too high
1291 The heated air intake sensor does not seem to be working.
1292 Natural gas pressure sensor issue
1293 Natural gas pressure sensor issue
1294 Can't get to target engine speed, check for vacuum leaks and idle speed motor issues.
1295 The throttle position sensor doesn't seem to be getting enough electricity.
1296 The MAP sensor doesn't seem to be getting enough electricity.
1297 The MAP sensor doesn't change its reading when the engine is running!
1298 During wide-open throttle, the engine runs lean.
1299 MAP Sensor and Throttle Position Sensor signals don't match, check for a vacuum leak.
1388 Auto shutdown relay circuit problems?
1389 No Z1 or Z2 voltage seen by the computer when the auto shutdown relay is used.
1390 Cam and crank signals don't match - did the timing belt skip a tooth?
1391 Sometimes, I can't see the crank or cam sensor signal.
1398 I can see the Crank Sensor's signal when I prepare for Misfire Diagnostics. Try replacing it.
1399 Problem in the Wait to Start Lamp circuit - (diesels only?)
1403 EGR position sensor not getting (enough) voltage.
1476 Too little secondary air injection during aspirator test.
1477 Too much secondary air injection during aspirator test.
1478 Battery temperature sensor voltage wrong.
1479 Transmission fan relay circuit problems?
1480 PCV solenoid circuit problems?
1481 Transmission RPM pulse generator signal for misfire detection seems wrong.
1482 Catalyst temperature sensor circuit shorted low.
1483 Catalyst temperature sensor circuit shorted high.
1484 The catalyst seems to be overheating!
1485 Air injection solenoid circuit problems.
1486 Pinched or blocked hose in the evaporative hose system.
1487 Control circuit of the #2 high-speed radiator fan control relay is having problems.
1488 Auxiliary 5-volt sensor feed is too low.
1489 High speed radiator fan control circuit problem.
1490 Low speed radiator fan control circuit problem.
1491 Radiator fan control circuit problem (may be solid state relays as well as other circuits).
1492 Ambient or battery temperature sensor voltage wrong
1493 Ambient or battery temperature sensor voltage wrong
1494 Leak Detection Pump (LDP) pressure switch problem - electrical or the pump itself.
1495 Leak Detection Pump (LDP) pressure switch problem - the solenoid circuit.
1496 Sensor feed is below an acceptable limit. (under 4v for 4 seconds - should be 5v).
1498 High speed radiator fan control circuit problem. (#3 control relay)
1594 Voltage too high in charging system.
1595 Speed control vacuum or vent solenoid control circuits shorted or lost.
1596 Speed control switch always high
1597 Speed control switch always low
1598 A/C pressure sensor voltage high
1599 A/C pressure sensor voltage low
1681 No messages received from the cluster control module (dashboard computer).
1682 Charging system doesn't seem to be working well. Check alternator, etc.
1683 Speed control servo power control circuit problem.
1684 The battery has been disconnected within the last 50 starts.
1685 Invalid key received from the Smart Key Immobilizer Module.
1686 No messages received from the Smart Key Immobilizer Module.
1687 No messages received from the Mechanical Instrument Cluster module.
1693 The companion engine control module has shown a fault.
1694 No messages received from the powertrain control module-Aisin transmission.
1695 No messages received from the body control module.
1696 Unsuccessful attempt to write to an EEPROM location!
1697 Unsuccessful attempt to update Service Reminder Indicator (SRI or EMR) mileage!
1698 No messages received from the electronic transmission control module or the Aisin transmission controller.
1719 Transmission 2-3 gear lockout solenoid control circuit problem.
1740 Either the tcc solenoid or overdrive solenoid systems doesn't seem to be making much sense.
1756 Transmission control pressure not equal to target. (Mid pressure problem)
1757 Transmission control pressure not equal to target. (Zero pressure problem)
1762 The Governor Pressure Sensor input was too high or too low for 3 consecutive park/neutral calibrations.
1763 The Governor Pressure Sensor input is too high
1764 The Governor Pressure Sensor input is too low.
1765 Open or short in the Transmission Relay control circuit.
1899 The Park/Neutral switch seems to be stuck!
Ahimoth687 is offline
post #14 of 15 Old 05-01-2005, 06:05 PM
tman2003
Are there any pc based scan tool for OBD-I?
thanks
tman2003 is offline
post #15 of 15 Old 05-02-2005, 01:54 PM
Ahimoth687
Scan tool
I found this via google and there are plenty others to look through. I suggest you compare a few of the places first before getting into one. obd-onboarddiagnostics(dot)com/OBD-software.htm. I had previously thought about doing this myself w/an older laptop of mine but funds were a little tight. May have to look into it again. Hope it helps.
