Thermostat housing bolts. - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 10 Old 09-13-2010, 09:31 PM Thread Starter
comingapart
'87 D150 w/318.
Some how I've lost the bolts for the thermostat housing and none of my "magic bucket" bolts seem to fit.
Does anybody know the size of these bolts so I could grab some from the hardware store? Or, where can i get an aftermarket housing and bolts that fit? The ones I've found all say for pre '78 Dodges. Will these not work on an '87 engine?
Minor little issue, but it's holding me up.
comingapart is offline
post #2 of 10 Old 09-14-2010, 01:39 AM
74PWpit
Hi, Older engines used a larger thermostat, and the bolts you need are 3/8-16 x 1 ". You can get these at any hardware store.
74PWpit is offline
post #3 of 10 Old 09-14-2010, 07:25 AM
Delray Dude
440 and a 4 speed
Delray Dude's Avatar
pretty sure this is the correct size, as 99% of them are but really depends upon the intake manifold - rare cases I have seen other sizes - but i know that my '87 stock 2bbl intake was the same as above.
Delray Dude is offline
post #4 of 10 Old 09-14-2010, 08:10 PM Thread Starter
comingapart
after numerous hardware store trips, they turned out to be M8 1.25.
post #5 of 10 Old 09-14-2010, 08:35 PM Thread Starter
comingapart
Also, now that I've gotten everything bolted back up after the water pump replacement, there's a pretty good leak that has developed, it seems to be coming from the timing cover mating to the block. Is this possible that removing the waterpump caused that seal to break?
Resealing that will involve dropping the oil pan and pulling the dampener won't it?
post #6 of 10 Old 09-14-2010, 08:52 PM
Warlock's Dad
Quoted: 17 Post(s)
Metric ... what are Dodges coming to?
Oh, that's right, Fiats
<grin>... but a TRUCK????
Sorry, Grady
Warlock's Dad is offline
post #7 of 10 Old 09-15-2010, 07:13 AM
Delray Dude
440 and a 4 speed
damn... shoot - i forgot - i put a '70 318 in mine.
post #8 of 10 Old 09-15-2010, 07:26 AM
Delray Dude
440 and a 4 speed
it is very possible to break the seal on the chain cover. depends upon where you are leaking. if it is near the top, you might be able to get some permatex in there to stop it, but highly unlikely, but to do it properly, you will have to pull the balancer, water pump, and drop the oil pan (atleast lower it via almost undoing the bolts - but chances are you'll break the oil pan seal doing this.
Sounds like a great opportunity to drop the pan, clean out the pan and see how the bottom end is holding out! (remember to pull the dipstick before you drop the pan).
drop the pan. remove the front (water pump and cover). reseal the front - then do the pan
post #9 of 10 Old 09-15-2010, 08:43 PM Thread Starter
comingapart
This is my first time doing any real work to a Dodge, I've mostly dealt with Chevy's, so thats what i'm used to.
It's dark now, so I don't feel like crawling around underneath it. How much room is there to remove the oil pan with the engine in the truck? I'm not as keen on rolling around on my back as I used to be, wouldn't I be better off just pulling the engine and doing it on a stand?
post #10 of 10 Old 09-16-2010, 07:20 AM
Delray Dude
440 and a 4 speed
you'll find that the small block Chrysler is very similiar to the chevy - with certain differences obviously.
As to the oil pan - well, depends upon your clearance on the truck. plenty of room, but you will spend some decent time on your back. if you have the crane and the time, it's always easier to pull the motor/trans and set the seals on a stand.
    Thermostat Housing cover- where to get abacus Dodge Caravan General Talk 2 07-16-2010 04:20 PM
    thermostat housing flh79 2G Dodge RAM - General Talk 6 11-13-2008 09:17 AM
    thermostat housing flh79 2G Dodge Ram Performance Talk 1 10-08-2008 02:56 PM
    Leaking thermostat housing... ChrisFred 3G Dodge RAM - General Talk 0 12-10-2006 07:24 PM
    '91 thermostat housing help. buckyxj Dodge Dakota 1st Gen (87 -96) Forum 1 02-21-2005 09:08 PM
