Brake line fitting sizes? - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 2 Old 08-27-2010, 09:39 PM Thread Starter
mowerman1193
2000 Dodge Grand Caravan. I am going to be replacing some corroded brake lines soon. Not broke yet but it don't look like it would make it through the upcoming winter.
I hope to bend up and make my lines Before I unhook my old lines. So does anyone here know what size fitting goes into the Anti-Lock brake box that would be located on the drivers side front floorboard section? I know from doing a search here that this would be a bubble flare. Been told most likely metric threads. It is a metric hex head as my ase line wrench's do not fit it as 9/16" to big and 1/2" to small. Time for some new metric tools, LOL
Thanks in advance,
Kevin
mowerman1193
mowerman1193 is offline
post #2 of 2 Old 10-06-2010, 04:03 PM
MAP79Z28
I had to do this in Feb - one line was leaking but not broken. Feb in NY is not warm, plus I had to do the repair outside. I opted for getting the already bent front to back brake lines, which are only available from the dealer. Two words - not cheap. And yes, the fittings are different, they do that so that you do not mix up the ABS for the right or left side. Which could be diastrous if you mix them up. If I were doing this in fair weather, I would definitely bend them myself. And yes, you need metric flare nut wrenches. Good luck.
MAP79Z28 is offline
    Trans cooler line fitting size mattcribbs 2G Dodge RAM - Drivetrain Talk 3 10-19-2009 10:54 AM
    Help.............brake rotor sizes. LPGHemi 3G Dodge RAM - General Talk 3 07-01-2009 01:04 AM
    Brake Line question NoPavemntNoProb Dodge Ram Truck 1st Gen (88 - 93) Forum 3 08-22-2008 11:33 AM
    Brake line 99 ram centrum74 2G Dodge RAM - General Talk 7 07-21-2008 02:57 PM
    transmission line fitting size scott03slt 1972-1987 Dodge Ram Trucks (D, W-series) 3 02-21-2008 11:52 PM
