Ball Joints..2 wheel drive 1500 - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 7 Old 08-16-2010, 05:04 PM Thread Starter
Rgut3
I have to replace all four ball joints on my 2001 ram 1500...I read up and asked questions and it seemed like it should be to difficult.....but....It took me 6.5 hour just to change 1 lower ball joint...It was almost like the rivets were welded or something...I ground the heads off the top and proceeded to beat the rivets down and out with 4lb sledge and punch...didnt budge any of them, I beat and beat and beat...finally I drilled a small hole all the way through and followed with a bigger drill until I could punch the remaining rivets out....WTF??? How can they be that hard to remove? Is there any tricks or secrets or was this a fluke to be that difficult...gonna try to replace the others next weekend...Thanks for any info on this
Rgut3 is offline
post #2 of 7 Old 08-16-2010, 05:33 PM
jmsteelers11
jmsteelers11's Avatar
Dont bother with a ball joint press, you need lots of heat and a pitman arm puller and a Big hammer
01 Ram 1500 4x4
Regular Cab Short bed
Off Road Package
Silver
5.9
Stock
jmsteelers11 is offline
post #3 of 7 Old 08-16-2010, 06:23 PM
mad 1
mad 1's Avatar
old school ,,,, floor jack and hammer,,,, sounds like you learn what to do and what not
forget the press tool,,,,rivits,, air hammer or drill them out,,,,,
mad 1 is offline
post #4 of 7 Old 08-17-2010, 09:28 AM
chazman05
chazman05's Avatar
I did exactly what you did and it took forever. I went and got some cobalt drill bits with some tap magic and it cut the drilling time significantly. I ground off the top of the rivets then drilled down to the lower rivet then beat them out. Took about 10 mins per rivet.
Goodluck!
2001 Ram 1500 short bed club cab 5.9
2008 Black Quad cab 4.7, 2wd.
chazman05 is offline
post #5 of 7 Old 08-17-2010, 11:40 AM
OleTomCat
Bridal Veil Falls
OleTomCat's Avatar
Quoted: 1 Post(s)
I had it done at a shop and it cost me over a grand I should have done it myself.....
My name is Al from Summerville, SC and I am a
Me: '14 Ram 1500 EcoDiesel
'01 Ram 1500 5.2L Sport
Rhino Liner, Pioneer sound, new ball joints
I am not just a member I am the President
Wife: '05 Durango 4.7L
OleTomCat is offline
post #6 of 7 Old 08-17-2010, 01:13 PM
Ram Pwnage
Ram Pwnage
Ram Pwnage's Avatar
Air Hammer is your friend, and I'm talking a long barrel one, not those crappy 20 dollar back massagers most places sell. Done plenty of riveted ball joints at the shop where i work, chop the head in half or into 4 with a cut off tool (vertical cuts into the rivet not horizontal across the head), use and air hammer with a chisel bit to knock the head off, then a punch bit to knock it through. every now and then a small amount of drilling is needed to get it to pop through.
2007 Dodge Ram 1500 Quad Cab Big Horn 4x4
Yeah, it's got a HEMI!
Pretty much stock for now, still way better than my 98
Ram Pwnage is offline
post #7 of 7 Old 08-17-2010, 07:18 PM
Ram15002ndgen
Don't Fear the Reaper
Ram15002ndgen's Avatar
Sounds like fun. Hope I never have to enjoy myself that much!
Ram15002ndgen is offline
    2000 1500 van upper ball joints Mr.Goodbar Dodge B-Series Vans 1971 - 2003 3 06-26-2010 03:22 PM
    06-08 1500 front upper ball joints ego 3G Dodge RAM - 4X4 Talk 5 06-21-2010 09:13 PM
    Some Q's(ball joints and steering wheel alignment) reddot 2G Dodge RAM - 4X4 Talk 4 04-11-2010 10:07 PM
    Ball Joints For Dodge Ram 1500 armywife99 For Sale - Truck Parts 2 04-03-2007 02:37 AM
    Replacing ball joints...98 1500 ram 4x4 ronryben 2G Dodge RAM - 4X4 Talk 5 05-22-2006 10:02 AM
