2001 v10 broken rocker arm bolt PLEASE HELP - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 8 Old 08-14-2010, 11:18 PM Thread Starter
dzklrz
I recently had my v10 rebuilt, after getting it stuffed back in the engine bay I had my #8 intake rocker arm bolt break 5 different times. This all happened within 3,000 miles. The last attempt was tapping the 5/16 hole to a 3/8". I thought I had it but it snapped with 633 miles on it. The 5/16 bolts lasted about 250-280 miles. I am pulling my hair out on this. Any ideas? Also the heads are rebuilt. My original set had cracks.
Thanks
dzklrz is offline
post #2 of 8 Old 08-15-2010, 08:57 AM
sgillett
Love my 66 monaco 500
sgillett's Avatar
Quoted: 1 Post(s)
Wrong valve spring on that valve going to coil bind (or the rebuilder didn't put the right thickness spring shim). Or he put the piston in backwards and it is hitting the valve (If these motors have valve notches, I've never had my heads off).
I'm sure you will get more ideas but those are what come to mind.
My $.02
V10 Ram truck club member #3
Toys:
'96 Ram 2500 V10 4X4 extended cab, long bed for towing my 28-foot 5th wheel Alfa toy house.
1966 Monaco 500 with a 365 horse power 440 and almost all options, my project car.
'07 Nitro R/T
My son has a '69 Dodge Coronet 440 with a warmed up 318 4bbl
Economy vehicle: Yamaha FJ1200
sgillett is offline
post #3 of 8 Old 08-15-2010, 09:27 AM
sgillett
sgillett's Avatar
Quoted: 1 Post(s)
I thought of another thing, could the pushrod be too long?
Toys:
'07 Nitro R/T
sgillett is offline
post #4 of 8 Old 08-15-2010, 09:58 AM Thread Starter
dzklrz
The pushrod is the same as the rest. I am ready to drive it up the mechanics arse! Under warranty, yet I have been the one fixing it. The worse part is that the #8 piston is on the passenger side and I have to take the engine half way apart to get to the problem. That dam elephant head air plenum.
dzklrz is offline
post #5 of 8 Old 08-15-2010, 10:00 AM Thread Starter
dzklrz
I should have a problem on both valves is they put the piston it backwards, correct?
dzklrz is offline
post #6 of 8 Old 08-16-2010, 06:57 PM
Moparite
Moparite's Avatar
Quoted: 318 Post(s)
I'm not familiar with diesels but i would imagine the rocker bolts are grade 8's. Are you replacing it with a grade 8? Grade 8 bolts have 6 lines on the head .
Moparite is offline
post #7 of 8 Old 08-21-2010, 03:34 PM Thread Starter
dzklrz
The motor is a v10 gas, and yes the replacement has been grade 8 each time.
dzklrz is offline
post #8 of 8 Old 08-22-2010, 01:46 PM
Woodstock
Woodstock
Woodstock's Avatar
Although I have never seen it happen on a V10, I have seen the valve guide drop enough to cause the rocker arm bolt break or get pulled out on several different vehicles. Unfortunately the only real way to tell is to pull the head.
If the valve spring is installed correctly it sounds like something is causing the valve to stick or bind up.
2000 1500 Sport 5.9 4X4 QC 46re w/TFODjr
SCT by hemifever, 4.10 Gears, Stainless Steel Headers
HellBent Steel leveling kit, 33X12.50X16 Super Swamper TSL Radials
1985 350 Custom Dually 360ci 4barrel 727
1990 Jeep YJ 4.2 waiting for 5.9 swap
Woodstock is offline
    v10 rocker arm bolts hurt2 2G Dodge RAM - General Talk 1 02-03-2011 01:37 PM
    Rocker arm clatter? TiaraRamVan Dodge B-Series Vans 1971 - 2003 28 05-03-2009 04:10 PM
    rocker arm the same? a303smoker 1972-1987 Dodge Ram Trucks (D, W-series) 4 12-27-2007 02:05 PM
    rocker arm asm. help!! mafosa 3G Dodge Ram Performance Talk 10 03-01-2007 08:33 AM
    Tips for removing broken bolt with broken extractor in it? Jimal Temus 1972-1987 Dodge Ram Trucks (D, W-series) 6 04-15-2006 08:18 AM
