how to install a cabin air filter in a 2010 ram - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 29 Old 08-07-2010, 04:26 PM Thread Starter
llklein
i worked on a 2010 2500 ranch truck with 16k with a plugged up a/c evaporator,all the air from the blower motor passes through the evap before entering the rest of the hvac box.this one was plugged with dirt and with the moister from the evap it turned to mud causing very little air to come out the vents.there is wire mesh on the inlet of the hvac box to keep the big stuff out,but dodge does not offer a cabin air filter for the trucks.the box how ever does have the punch out location for a cabin filter.drop the glove box out and you can see the area of the hvac box were it would go,next youll need to cut the opening out,drill a couple holes and use a air saw or sharp utility knife,you can drop the blower motor out to clean out any plastic shavings,its pretty easy to see were the opening should be and cut inside the raised line.next youll need a cabin air filter #5058693AA and a lid #68052292,they fit 2010 compass,avenger,caliber ect,and are a exact fit for the ram box....took me awhile to figure this out,i think they will fit the 1500 also,but havent confirmed this.slide the filter in and pop the lid on.iits a big job,aprox 7-8 hours book time to r&r the hvac housing and clean the evaporator out,so for about $35 in parts and a hour of time youll save hundred of dollars if you run your truck in dusty conditions
sorry no pics
llklein is offline
post #2 of 29 Old 08-07-2010, 07:42 PM
ten6
Sounds like a good mod! I have also heard of guys getting an hvac filter for a house, trimming that down and using that as a cabin filter.
Good find!
2009 Silver Dodge Ram 1500 Hemi. Laramie CC 4x4. Every option, except Rambox, ventilated seats and skid plates!
Mods: 180* thermostat. Limo tint fronts windows, Double limo-rear windows. K&N Drop-in. LEDs in the License plate, Reverse, and interior lights. Morimoto Mini Projectors in the headlights and Retro-Solutions 6000k HIDs that I cannot get to work properly.
ten6 is offline
post #3 of 29 Old 08-08-2010, 01:39 PM
aggieRam
SRTs wanna b like me
aggieRam's Avatar
Quoted: 1 Post(s)
ill have to do this to my dads. he works out in the oil field
Bryan McGee
2003 Dodge Ram 2011 A&M Edition w/ 4.7L
287 Enthusiast Club member #227
Blue Truck Club Member #146
mods:
engine - 08 intake manifold, 4.10 gear w/ LSD, flowtech headers, 3950 superchips cortex, custom built dual ram air intake, high flow magnaflow cat, 40" glasspack, tmr mod, Ignition Solutions Plasma Booster, dual jet stream scoops, 69mm TB, power wire
exterior - 1/3 drop, fiberglass cowl hood, 20" boyd coddington smoothie 2s, speed grille, window tint, rancho 5000 shocks, airlift bags in rear, SRT10 front bumper, aTm Edition graphics and badges, custom grille shell, blacked out LED tails, blacked out 3rd brake light, fiberglass roll pan, color matched mirrors and handles
interior - smoothed and painted interior panels, sony xplod head unit, 1000W insignia amp, 5.25 kickers, 6.5" kickers, 6x9 fosgates, handmade sub box, 15" audiobahn, interior neons in kickpanels and ac vents, vacuum/boost gauge, oil pressure gauge, voltmeter gauge, A/F ratio gauge, triple pillar pod, steering wheel column pod, molded 2 din with GPS, relocated A/C controls
Ride #2: 1965 Mustang GT
aggieRam is offline
post #4 of 29 Old 08-08-2010, 10:35 PM
waynebyrom
waynebyrom's Avatar
Dern bro, I want to do this but without a few pics it would be a guessing game for me. Help us out bro
Wayne
waynebyrom is offline
post #5 of 29 Old 08-09-2010, 02:36 AM
ten6
Also, a search for part #68052292 came up with negative results...
ten6 is offline
post #6 of 29 Old 08-09-2010, 01:58 PM
Scotrod65
FWIW, google 'cab fresh filter company'.
They make a filter housing with media that attachs over the air intake 'grill' on the firewall located just under the trailing edge of your hood.
3rd Gen dodge part available online, 4th gen 1500 part available from cab fresh.
I paid about 60 bucks w/shipping and was done installing in about 10 minutes.
Replacement media is another 17 bucks. 2 layers of polyester 'filter' and 1 of charcoal.
The 'poly' media is not effective as paper when it comes to pollen, fine dust, etc, but it's a lot better than NOTHING,,,,
I REALLY like the idea listed above, but I'd want the parts 'in hand' before I cut up the system!
Scotrod65 is offline
post #7 of 29 Old 08-09-2010, 11:18 PM
King
You can check mine out after I do it. Parts are on order.. Its simple, I did this to my 09 1500. I used a exact-o knife and 2 screws, no shavings or mess.
His 2011 2500 4x4 Cummins crew ....Hers 2011 Ford Eco Boost Crew... Daughter 09 Inferno Red SLT Crew Cab loaded.
King is offline
post #8 of 29 Old 08-09-2010, 11:24 PM
waynebyrom
waynebyrom's Avatar
Hey King, will do. Please post pics. Waiting...
Wayne
post #9 of 29 Old 08-10-2010, 10:55 PM
sizemic1
sizemic1's Avatar
Can you give us all of the valid part numbers please?
09 Stone White QC, with 3.92's, 17's, Magnaflow exhaust, and a San Diego Chargers sticker.
sizemic1 is offline
post #10 of 29 Old 08-10-2010, 11:11 PM
Scotrod65
Does the area in question look kinda like this? Finding the lid somewhere looks like it will be the tough part,,,,
post #11 of 29 Old 08-11-2010, 09:00 AM
Scotrod65
Try 68052292AA for the lid,,,,
Called my dealer, none in Houston, on backorder as well,,,,
post #12 of 29 Old 08-11-2010, 06:59 PM
mopowa
mopowa's Avatar
cabin air
Yes I would love to do this to mine also. My charger was easy to add cabin filter.
mopowa is offline
post #13 of 29 Old 08-11-2010, 07:39 PM
waynebyrom
waynebyrom's Avatar
I am sure that is where but exactly where to cut and the adaptor or whatever it takes to complete the install is what pics I am waiting for.
Wayne
post #14 of 29 Old 08-11-2010, 08:10 PM Thread Starter
llklein
yeah the part number has "AA" on the end,and the pic is were to cut,just cut it straight on the bottom just like the pic,its really easy and the plastic is thin in that area,the parts fit 2010 avengers,compass,ect.
llklein is offline
post #15 of 29 Old 08-11-2010, 08:17 PM
Scotrod65
The lid was under 11 bucks when I priced it at the dealer this AM,,,
I was hoping to get one elsewhere quicker, but no luck,,,, I guess I'll 'wait in line'.
Once I get the lid, I'm sure I can figure it out from there,,, I assume the cut out is basically just big enough to insert/remove filter.
post #16 of 29 Old 08-11-2010, 08:27 PM
waynebyrom
waynebyrom's Avatar
I take it the filter sits in a pocket of some type so it dont fall in? And if you go to the dealership you can ask for the lid and filter for a 2010 Dodge Avenger?
Wayne
post #17 of 29 Old 08-11-2010, 08:34 PM
Scotrod65
Sure hope so! =)
Kinda got this feelin' that's the case! If a tray or something else was needed, I'd assume the OP would have mentioned it.
post #18 of 29 Old 08-12-2010, 01:30 AM Thread Starter
llklein
its all made for the filter they just didnt cut out the hole,more than likely it would have been cheaper to make one recirc box with the cut out for everything and just run the lid rather then making two different parts but im no chrysler bean counter
llklein is offline
post #19 of 29 Old 08-12-2010, 02:33 AM
renos09
Do you have to remove the glove box to view the area? If so is it the upper or lower glove box?
2009 Dodge Ram 1500 SLT Quad cab 4x4 Mineral Gray/Luxury group/protection group/remote start and security/popular equipment group/5.7 vvt/32 gallon fuel tank/u connect and Navigation w/ back up camera/power adjustable pedals/class iv receiver hitch/under rail box liner/ 20" powder coated flat black rims
renos09 is offline
post #20 of 29 Old 08-14-2010, 10:29 PM
mopowa
mopowa's Avatar
cabin air filter
you need to remove lower glove box. cut mine out today,need to order parts monday from dealer. very easy!!!!!
mopowa is offline
    Cabin air filter? azracer 3G Ram Power Wagon Talk 19 09-02-2009 10:26 AM
    Cabin air filter COREYATMN 2G Dodge Avenger - General Talk 11 07-31-2009 11:48 AM
    Cabin air filter 98dodgewv 2G Dodge RAM - General Talk 8 06-27-2009 12:08 PM
    Cabin air filter Barry J Dodge Caravan General Talk 5 02-27-2008 09:12 AM
    cabin air filter xombie Dodge Magnum - General Talk 5 10-15-2007 02:31 PM
