Firing order? - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 12 Old 08-03-2010, 10:03 PM Thread Starter
mo_440
mo_440's Avatar
Firing order?
Ok I have a 76 powerwagon with a factory 440. I did a tune up today... plugs wires cap and rotor. Go to start and now i have a miss. What is the firing order on the big block mopars and can anyone by chance post a pic of the distributor showing where number on is on it. I have found this order 18436572 and that it goes counter clockwise. Is this correct? I have number one starting at the front of the distributor spot to the passenger side of truck if anyone follows what I am saying. I am sure there is a thread bout this somewhere on here but hoping someone can point me that way. Thanks for any help!!
76 POWER WAGON
440/727 35'' COOPERS
01 Ram 1500 4x4 318 - 5''liftSOLD!
mo_440 is offline
post #2 of 12 Old 08-04-2010, 09:31 AM
Mopower79
Mopower79's Avatar
Hope this helps..
IF IT AINT A DODGE.... IT AINT RIGHT....
Mopower79 is offline
post #3 of 12 Old 08-04-2010, 11:09 AM
Mopower79
Mopower79's Avatar
WTF.. lets try this again..
post #4 of 12 Old 08-04-2010, 02:34 PM Thread Starter
mo_440
mo_440's Avatar
yeah i went off of that pic. according to that I have it wired up with number 1 being the next on in line. runs but like crap. If I wire it like the pic it will not fire. the distributor is tight. I s there a possibility it could have moed internally? thanks for the help.
76 POWER WAGON
mo_440 is offline
post #5 of 12 Old 08-04-2010, 02:55 PM
Mopower79
Mopower79's Avatar
is your rotor in line with the #1 position on your cap??
post #6 of 12 Old 08-04-2010, 03:00 PM
Mopower79
Mopower79's Avatar
Huh??
Find top dead center on #1 cylinder.. then make sure the rotor is in line with the #1 position on the rotor..
If that is true.. it didnt move internally..
post #7 of 12 Old 08-04-2010, 03:30 PM
Ram3500Dually
Ram3500Dually's Avatar
Quoted: 38 Post(s)
Are you top dead center on compression stroke? Distributor could be 180 out.
2013 Ram 3500 CTD 6.7L 6 Speed Aisin, 4:10 LSD
2005 Jeep Liberty Sport
1991 Shadow ES Turbo Convertible
1984 Mini-Ram Van (Show Van) **TOTM April 2007** In museum now
73 Pro Street Duster.**VOTM July 2008/ April 2011**
1951 Dodge 3 Window Business Coupe **VOTM Feb 2011**
1992 Custom Built Harley FXSTC Show Bike
2008 Harley FLHTCU Ultra Classic
DodgeTalk Administrator
Names Carl, if you cut me I bleed Mopar Blue
Past Trucks: 90 CC Dually CTD, 94 RC LB CTD, 95 CC SB 5.2L gas, 98 QC Dually CTD, 00 QC Dually CTD, 01 QC Off Road, 03 QC Dually CTD, 05 QC Dually CTD, 08 Dually CTD **ROTM April 2008**,10 CC Dually CTD,
Ram3500Dually is offline
post #8 of 12 Old 08-05-2010, 05:50 PM Thread Starter
mo_440
mo_440's Avatar
yeah we are going to put a timing light on it. The funny thing is it ran just fine before the tune up. I have the correct firing order down we have tried the old cap and rotor to. pulled all the plugs and checked for dirt on them. all were clean. question how could the distributor be 180 out and run right before then not after the tune up? Not saying anything against your comment RAM3500DUALLY
76 POWER WAGON
mo_440 is offline
post #9 of 12 Old 08-05-2010, 06:43 PM
Ram3500Dually
Quoted: 38 Post(s)
Ok, wasn't reading it right. I thought you had replaced the distributor
post #10 of 12 Old 08-07-2010, 12:21 PM
Oldblue1978
Oldblue1978's Avatar
did you get it running good yet? Align your harmonic dampener on the timing mark, however there is a point when mark is aligned with pointer and it will in effect be at TDC, but piston will be at the intake stroke, you don't want that. You want it to be at TDC when both valves are closed. An easy way to tell is to remove driver side valve cover and when mark is aligned with pointer, check both valves for #1 and make sure they are both closed. Easy enough, right? Once that is established, then take rotor off of dist and see where the rotor is pointing. Then take all wires off of cap, and do one by one starting with putting the #1 in cap where it aligns with rotor when installed. You must be very critical when doing this and not have blurry vision or crossed eyes
Oldblue1978 is offline
post #11 of 12 Old 08-07-2010, 08:57 PM
mikehopkinsjr
if it ran fine before you couldn't possibly f*** it up that bad check the wires one may be bad....
mikehopkinsjr is offline
post #12 of 12 Old 08-08-2010, 05:27 PM Thread Starter
mo_440
mo_440's Avatar
Well pulled each wire off one at a time and found the number three cylinder was the only one that didnt change tone. Put different wire on wasnt it and put an old plug in and took care of it. So just one new plug that was bad causes a big headache.
Thanks for all the suggestions.
76 POWER WAGON
mo_440 is offline
    Firing Order Alysse's Dad Dodge Caravan General Talk 4 10-30-2008 09:02 PM
    firing order help joker163 Dodge Ram Truck 1st Gen (88 - 93) Forum 8 12-31-2006 10:42 PM
    Firing order 85 v6 3.7 jbrown4011 Dodge B-Series Vans 1971 - 2003 3 03-02-2005 09:41 PM
    Firing order for 5.9 ram_noob 2G Dodge Ram Performance Talk 6 10-17-2004 03:36 PM
    Firing order??? TREP R/T 3G Dodge RAM - General Talk 1 08-20-2004 09:32 AM
