2000 1500 ABS and Brake light on? - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 9 Old 07-20-2010, 01:46 PM Thread Starter
Mr.jon
So my ABS and brake light are on all the time now. I read somewhere that it could be brake fluid, so i filled up the reservoir, but the lights are still on. Any ideas? The truck brakes fine, so if the problem is minor enough, i will probably just ignore it.
Also, i checked the obd2 to see if it's throwing any codes. Nada.
Mr.jon is offline
post #2 of 9 Old 07-20-2010, 03:00 PM
mini_squared
mini_squared's Avatar
For the brake light it could be that your parking/emergency brake pedal isn't all the way up.
And for the ABS light, check the sensor's on the back side of the front rotors. Could be a cut wire or the sensor itself is bad.
mini_squared is offline
post #3 of 9 Old 07-20-2010, 04:03 PM
DODGEPICKUP
DODGEPICKUP's Avatar
Quoted: 2 Post(s)
common cause's are the rwal sensor on top of the rear diff or brake pedal switch...if its the sensor on 98-up rams the speedo may act funny as mine did
1999 RAM 1500SPORT QC 4X4 5.9 3.55's grrrr
360 MAGNUM POWER 165,000 MILES DYNOED 230/290 ON 35'S
1.7 CRANE ROLLER ROCKERS
DIY CUT,PORTED,EPOXY FILLED KEGGER/ALUMINUM PLENUM PLATE,53MM THROTTLE BODY
JACOBS PRO STREET CD IGNITION
BOSCH DESIGN 3'S 24LBS VETTE INJECTORS
MOPAR P DOUG THORLEY TRI-Y'S
TAYLOR 8.2 THUNDERVOLT WIRE'S
EBC ROTORS N PADS,RUSSELL SS BRAKE HOSES
MARCH UNDERDRIVE CRANK PULLEY
1 TON X-OVER STEERING
DT PRO-FAB TRAC BAR
HELL BENT STEEL 2IN SPACER/SKJ LCA
WINNDEKAR/DSS STEERING BRACE
DODGEPICKUP is offline
post #4 of 9 Old 07-21-2010, 11:36 PM
Monte561
Monte561's Avatar
x2. I replaced my sensor not too long ago bc of the same issues, pretty cheap fix.
'99 Ram 1500 4X4 5.9L Quad Cab
Performance
Pacesetter Headers
4.10 gears
2" Suspension Lift
18" XD Spy wheels with 33" Treadwright Guard Dog's
SCT Tuned
Underdrive Pulley Kit
3" Cat-Back Exhaust side exit (No Muffler)
MSD Wires & Distributor Cap
K&N Intake
180 T-Stat
Sound
Pioneer DEHP6800MP Head Unit
Rockford Fosgate 1100W amp
2 10" Kicker Comp subs in custom box under rear seat
Behemouth Train Horn (I think this would fall under sound)
Black Truck Club Member #195
Military Club Member #134
Train Horn Club Member #39
Monte561 is offline
post #5 of 9 Old 07-22-2010, 09:23 AM
BigGreenV10
Big Green
BigGreenV10's Avatar
Ok on the speedo does it seam to act ok up to 35 mph then bounce around mine is doing that. My abs and brake light are on too.
POWDER COAT CLUB MEMBER #1
DON'T TOUCH OUR TRUCK CLUB #2
GREEN TRUCK CLUB MEMBER #31
V10 RAM CLUB MEMBER # 35
MILITARY TRUCK CLUB #147
CRACKED DASH CLUB # 32
2000 2500 V10 4x4 Ext. cab 6" suspension 37 x 12.5 x 16.5 with 4.88 gears.
SCT tuner, Cold air and custom exhaust.
Tail lights, fuel filler door and tail gate handle shaved. Body color fiberglass bed cover and fender flares. Custom all steel 4" cowl hood, custom front bumper.
100% Xtreme Kreations Club President looking for members
BigGreenV10 is offline
post #6 of 9 Old 07-22-2010, 10:01 AM
Dodge318
I would check to make sure you have brake lights. If you were to blow a stop light fuse, both of those will illuminate.
1995 Club Cab 1500 4x4 SLT laramie 5.2 Auto
297,000 miles and one theft under it's belt.
1997 Club Cab 1500 Sport 4x4 5.9L Auto
143,000 and doesn't run as good as the 1995
Dodge318 is offline
post #7 of 9 Old 07-22-2010, 09:20 PM
BigGreenV10
Big Green
I have brake lights already know that and it stops awesome.
post #8 of 9 Old 07-24-2010, 10:06 PM
moparhindsight
moparhindsight's Avatar
as far as the original poster talking about brake fluid being the cause. The only reason this would happen is that your brake pads are excessively worn causing the piston to be out farther and using up all the fluid. You arent actually supposed to have to add brake fluid unless your doing a brake job and bleeding and all that. WHen you compress the piston/s in the caliper back the fluid goes back up to the reservoir.
MURDERED
00 ram 318 5-speed
Fuel offroad hostage 17x8.5
Eclipse HU, 7" dayton rs 180 mids with vifa tweets run active off soundstream amp, Alpine type R 8" sub great little woofer
3" sky-crapper with 295/70/17 Nitto trails
3" high flow spun converter with Dynomax Ultraflow SS round case
RIP 00 burned this summer
New truck 01 shortie Off road stuff switched over to this truck. Except 3" lift because it rode like crap.
moparhindsight is offline
post #9 of 9 Old 08-11-2010, 08:23 AM
BFT318
BFT318's Avatar
i have a 99 ram 5.2 4x4 with the nv 3500 standard trans and I have the same ABS and brake like ans speedo not reading until 25 mph and up, but with one better my engine actually stalls occasionally when comming to stop(clutch in and shifter in second). Any thoughts on the sensor in the rear causing the engine to stall??
BFT318 is offline
    ABS not working - ABS & Brake light on Barknee 1G Dodge Durango General Talk 8 11-20-2009 11:28 AM
    1998 RAM 1500 ABS and Brake Light sometimes on. SSTGRUMPY 2G Dodge RAM - General Talk 8 04-17-2009 12:04 AM
    2000 Dodge Dakota 3.9 ABS, Brake, Emission Light nstasik 2G Dodge Dakota General Talk 1 05-01-2006 02:13 PM
    ABS & Brake Light on, ABS Pump/Motor running signs 2G Dodge RAM - General Talk 3 03-12-2005 09:19 AM
    99 Ram 1500 ABS & Brake light on hallcs 2G Dodge RAM - General Talk 6 10-14-2002 09:19 AM
