ESP/BAS Light & Error Code C121E - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 1 Old 07-08-2010, 05:30 PM Thread Starter
krazy.train
krazy.train's Avatar
Does anybody know where I can get more info on this code?
I know it is "Brake Pressure Sensor Comparitive Performance"
As well - I have this info - but I guess I'd be curious about what the service techs need to do to fix it... cause clearly they aren't doing much of anything besides waiting for a backorder TIPM (3+ weeks) which may not even be the problem??
TERMINAL/CONNECTOR/WIRING HARNESS DAMAGE
AIR IN BRAKE SYSTEM/WORN MECHANICAL COMPONENTS
(B83) BRAKE PRESSURE SENSOR SUPPLY CIRCUIT SHORTED TO VOLTAGE, GROUND, OR OPEN
(B986) BRAKE PRESSURE SENSOR RETURN CIRCUIT OPEN
(B84) BRAKE PRESSURE SENSOR SIGNAL CIRCUIT OPEN
(B84) BRAKE PRESSURE SENSOR SIGNAL AND (B83) BRAKE PRESSURE SENSOR SUPPLY CIRCUITS SHORTED TOGETHER
(B84) BRAKE PRESSURE SENSOR SIGNAL AND (B986) BRAKE PRESSURE SENSOR RETURN CIRCUITS SHORTED TOGETHER
(B45) STOP LAMP INHIBIT RELAY CONTROL CIRCUIT ANTI-LOCK BRAKE MODULE
krazy.train is offline
    ESP BAS help..... ThomasJ97 2G Dodge Durango - Tire/Wheel/Susp Talk 2 07-22-2010 12:57 PM
    ESP BAS light Joose Dodge Magnum - General Talk 3 01-02-2010 07:36 PM
    New 08 Caravan ESP/BAS Clock Spring ? ancamo Dodge Caravan General Talk 0 01-28-2009 01:54 PM
    Esp Bas severed67 Dodge Magnum - Performance Talk 21 12-14-2006 04:28 PM
    ABS Error Light & Brake Error Light 78RamCharger01D 1G Dodge Durango General Talk 7 09-11-2005 03:54 PM
