Voltage Regulator Problem (I think) - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 8 Old 07-07-2010, 12:23 PM Thread Starter
Anglinfool
Driving home from holidays last week, the voltage gauge in my 01 24v went to nothing and the CHECK GAUGES light came on. Figured it had to be the alternator as it was only showing 12.3v on each battery idling. Made it home (6hours) and threw in a new alternator. Same problem. The truck is not telling the alternator to charge.
I'm pretty sure its the voltage regulator, but I thought I'd ask here before trying to figure out a fix. Anyone else have this problem?
Thanks!
2008 RAM 1500 TRX4 QC SB, with the HEMI. Pioneer Premiere System, Firestone Airbags, Prodigy Brake Controller, Superchips Flashpaq, Flowmaster 50 SI/DO, K and N drop in filter.
2001 RAM 2500 24v Cummins HO, 6 speed 4x4 LB Superchip, Magnaflow exhaust, BD exhaust brake. The hauler.
Anglinfool is offline
post #2 of 8 Old 07-07-2010, 12:48 PM
ringnalda506
ringnalda506's Avatar
Correct me if i'm wrong but isn't the voltage regulator a part of the alternator?
Or at least screwed onto the alternator.
If you replaced the alternator probably you changed the voltage regulator too.
Did you check the wiring(grounding cable for the alternator to see if it is in good condition(maybe it,s corroded and therefore not making contact or bad contact preventing the charge
ringnalda506 is offline
post #3 of 8 Old 07-07-2010, 12:54 PM Thread Starter
Anglinfool
Thanks for the reply ringnalda, but I'm pretty sure I found it up against the driver side firewall, but I'm not 100%. One wire going into the new alternator had no power going to it, so I assumed voltage regulator wasn't telling it to charge.
I really hate dealing with electrical, so I could be totally wrong here....
post #4 of 8 Old 07-08-2010, 08:20 PM
jerry cole
probably the crank sensor I had 4 or 5 that did that when I was working
jerry cole is offline
post #5 of 8 Old 07-16-2010, 04:11 PM Thread Starter
Anglinfool
Correct me if I'm wrong, but isn't the crank sensor only on gas motors?
Turns out the computer tells the alternator when to charge....
So far we've completely bypassed the computer with a voltage regulator and it still will not charge with the old and new alternator. Getting a little pissed off. I'm picking up another voltage regulator this afternoon and if that doesn't work, I'm stumped.
post #6 of 8 Old 07-17-2010, 08:41 PM
jerry cole
NO CRANK SENSOR IS ALSO ON A DIESEL. it tell the computer engine is running, around crank damper or above starter
post #7 of 8 Old 07-27-2010, 12:05 PM Thread Starter
Anglinfool
UPDATE
It was simply the alternator. Originally, I suspected the new alternator was faulty, but the shop in town tested it and said it was fine. After installing a volt regulator and pulling out most of my hair, I sent the alternator and the voltage regulator into the city to get them tested at a more reputable shop. Sure enough, the new alternator was junk. Installed a different one bought in the city and all is good.
After ripping a strip off the mechanic at the shop in town, they gave me my money back plus $50 for my troubles.
Off to the lake we go!!
post #8 of 8 Old 07-27-2010, 06:55 PM
Red Sleeper
Blowin n' Goin
Red Sleeper's Avatar
Sadly your not the only one in that boat man. My car had the same problem.
Glad your up and running!
Nick J
05 Cummins QCSB. TransGo Smarty H2O/CH4O
13 Jetta TDI 6spd auto
91 Cummins Dedicated water hauling vehicle
94 Z28 LT1 355ci 6spd Lots of Tubing
RockCrawling Dakota
Red Sleeper is offline
    voltage regulator bigdogscott 1972-1987 Dodge Ram Trucks (D, W-series) 38 11-08-2009 10:45 PM
    not the voltage regulator again.... Megunticook 1972-1987 Dodge Ram Trucks (D, W-series) 34 03-01-2009 04:40 AM
    92 voltage regulator thbatj Dodge Dakota 1st Gen (87 -96) Forum 1 08-11-2007 06:19 AM
    voltage regulator rotor20 Dodge Dakota 1st Gen (87 -96) Forum 5 07-27-2007 12:34 PM
    voltage regulator spydermat 2G Dodge Dakota - Drivetrain Talk 0 02-22-2006 01:34 AM
