Transmission Pan Gasket .. - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 11 Old 07-06-2010, 06:16 PM Thread Starter
live4rut
live4rut's Avatar
Getting prepared to do a pan-drop this weekend.
I took back the "Pro-King" filters from advance auto to get the Mopar filters and noticed the Mopar pan filter didn't come with a rubber gasket to go around the pan. Do I need to buy this gasket separate or would ultra-black RTV sealant be just the same? My first time doing this and not really looking to screw anything up. Thanks!
live4rut is offline
post #2 of 11 Old 07-06-2010, 10:59 PM
KB112
KB112's Avatar
Quoted: 1 Post(s)
I have always used RTV, Ultra Copper Hi Temp. I believe the service manual states to use it. The truck comes stock with Mopar RTV on the oil and trans pans.
2004 5.7L Quad Cab
1/8: 9.113@70.814 --- 1/4: 14.365@95.470
Exterior: Blacked Out 06-20"s, 295/50-20 Falkens, 2/4 Drop - Hotchkis coils/DJM Flip, Sport Conversion, Mopar Air Dam, Good Hood, ARE Cover, Rollpan, Mopar fuel door, LED 3rd Brakelight, Black Headlights, HID Fogs, Powdercoated Black SS Grille, Homebrew Powdercoated bumper grill with smoked turn signals
Interior: Infinity pkg, Slammed1 Bezel, BedRug, SRT Pillar
Performance: Hotchkis F/R SwayBars, Bilsteins, MIT tube, AEM Wideband, Comp 260, 6.1L Pushrods, 6.1L Exhaust Springs, QTP Cutout, Super Chips, NGK 4306s, Taylor Wires, TransGo Shift Kit, AT3030, CalTracs.
Awaiting Install:Thorley Mid's
KB112 is offline
post #3 of 11 Old 07-06-2010, 11:18 PM
Mudchucker
If only I had more $$$
Mudchucker's Avatar
The transmission pan gaskets are usually reusable,.. it is on my 48re. You have no truck description so I am just throwing this out there.
SOLD and already forgotten 2006 1500 hemi
2006 2500 QCLB 4x4 5.9, built trans EFIlive/CSP5, 4" tbe, 4" lift, 35" Toyo Mt
Mudchucker is offline
post #4 of 11 Old 07-07-2010, 08:11 AM
weedahoe
Tricked out Ram
weedahoe's Avatar
Quoted: 21 Post(s)
yeah but there is no trans pan gasket on the rfe-545, just silicon on the pan.
Getting the old sealant off the pan and trans can be a pain (especially the pan). Go get a can of this Permatex Gasket Remover and it will take it off very easily
2004 2wd Dodge Ram QC w/a 5.7 with Royal Purple 5w-20 in the motor, RP Max ATF in the trans, 80-90w in the 4.56 Auburn LSD rolling on American Racing Dale Earnhart "Tank" 24s wrapped in Pirelli 325/45/24s (36" tires)
| Debadged | SRT-10 hood | Custom CAI | Fumoto oil valve | 12" of lift | Power Wire | 9007 Bi-Xenon 6k | 9006 Single Beam 6K | 2nd battery tray (2K CCA total) | Big 3 upgrade w/1ga wire | Altezza clear tails w/LEDs | Clear LED 3rd light | 26gal to 35gal fuel tank swap | Viair 380c air compressor | train horns | Ceramic pads (F&R) | Westin Nerfs | Chrome door/tailgate handles | Custom switch panel | Custom center console | B&M QuickSilver floor shifer | Xbox 360 | Audiobahn A8000V (1600w sub amp) | Audiobahn 2002V (400w mid/high amp) | 2 12" Kicker DVC CVRs in a FoxBox | 4 Kicker DS650s (front & rears) | 2 Kicker KS350s (dash) | 2 8" LCD screens in the sunvisors | 2 6" LCD screens in the headrest | Clifford 50.7x alarm | 20/15% tint | Diablo Trinity - custom and 93 tuned | Mopar 6.1 ignition conversion | Start ignition push button | KRC 210 cam | 6.1 springs & pushrods | 6.1 half covers | 180* T-stat | Taurus E-fan | Pacesetter ceramic LTs | dual DMH cutouts | (2) 4x14" round magnaflows | 4x24" tips | X pipe | Jimmy Jammers | Ported (85mm) TB | Innovate LC-1 wideband | Sonnax transmission pressure booster | Mopar slush mats | RBP grill | powder coated calipers | custom rim/grill lights |
Next projects:
- Custom center console
- B&M Quicksilver Floor shifter
- Custom CAI
weedahoe is offline
post #5 of 11 Old 07-07-2010, 08:29 AM Thread Starter
live4rut
live4rut's Avatar
Sorry about that, the truck is a 2005 Ram 1500 5.7L Hemi 4X4, 2DR 6Ft Bed.
I may have to pick up some of that gasket remover. Scraping the old gasket off of the rear diff was pretty time consuming. Thanks for the suggestion
live4rut is offline
post #6 of 11 Old 07-07-2010, 11:36 AM
flattire
I just spent at least an hour cleaning the gasket off my pan. I know someone wrote a new pan was $32. When I do it again I would buy new pan....install a drain plug in it. I used gasket remover but it didn't do a lot.They don't sell that type in the can shown in California any more (or at least I couldn't find it).New stuff doesn't work as well.
flattire is offline
post #7 of 11 Old 07-07-2010, 01:45 PM
weedahoe
Tricked out Ram
weedahoe's Avatar
Quoted: 21 Post(s)
That what i listed above works extremely well. But dont get it on your skin because it WILL burn.
Next projects:
- Custom CAI
weedahoe is offline
post #8 of 11 Old 07-07-2010, 06:13 PM Thread Starter
live4rut
live4rut's Avatar
Thanks for the reminder... I remember seeing a post about another type of gasket remover that would burn your skin if it makes contact. Nice to know that this stuff does the same before working bare handed. Looks like rubber gloves for this job
live4rut is offline
post #9 of 11 Old 07-09-2010, 01:10 PM
RobRamAZ
RobRamAZ's Avatar
I used a gasket it soo much easier when you have to drop it again. I also used the NAPA filters cause they where less then half the price of MOPAR and came with the gasket. I talked to a service guy at my dealer and he said that the NAPA filters are crap and not to use the gasket. I did it at 50k and I am at 70k now, i have a transtemp gauge and never had a problem, but if i had to do it again i would get the mopar filters and use RTV..and put in a drain plug!!
RobRamAZ is offline
post #10 of 11 Old 07-10-2010, 07:23 PM Thread Starter
live4rut
live4rut's Avatar
Thanks for everybodys input. Just did it today with Mopar filters and Castrol ATF+4 Fluid. RTV Ultra Black for the seal. I'll find out tomorrow how well the seal held up. I just put it on and let it cure for an hour and a half before adding any fluid.
live4rut is offline
post #11 of 11 Old 07-11-2010, 11:48 PM
KB112
KB112's Avatar
Quoted: 1 Post(s)
Tip I got from Chefred112, use a wire wheel to strip off the old gasket material. I just changed filters/fluid yesterday and the gasket came off so quick. I put the wheel in my Dewalt and stripped that old RTV off like nothing. I added a drain plug while I was at it. I RTV'd the hell out of that thing on the inside and outside. I am too scared of it leaking! lol
2004 5.7L Quad Cab
KB112 is offline
    Transmission pan leaks, buy new gasket or make your own? DIDYSIS Dodge Dakota 1st Gen (87 -96) Forum 3 03-10-2010 07:20 PM
    Transmission cooling lines and oil pan gasket mbehum 2G Dodge Stratus - Interior/Exterior Talk 0 01-27-2009 01:59 PM
    Best Pan Gasket? DodgeOkie 2G Dodge RAM - Drivetrain Talk 5 04-08-2008 04:25 PM
    Transmission fluid replacement (Pan Gasket vs Sealant) rtelles Dodge Caravan General Talk 32 05-24-2006 08:43 PM
