Expansion (Freeze) Plug Replacement - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 8 Old 07-02-2010, 02:34 PM Thread Starter
jborfair
jborfair's Avatar
Howdy all...once again I need some help from your banks of information lodged into your 2G Ram craniums.
99 Ram1500 4X4 66,800 original miles
5.9L
Automatic.
I recently replaced an easy to get to expansion plug on the front left side of the block. Low and behold, as expected another one springs a new, but slow leak. This one seems to be from the aft end of the block, where the transmission mounts to the block. I can see one that isn't leaking, but I cannot determine if there is an upper and a lower expansion plug on the left side, rear end of the block. I can only assume there is. I can trace the leak up to that vicinity, however cannot determine the origin. I have to assume there is a plug there.
My question is, is this a plug I can get to w/o having to pull the tranny from the block, or am I best suited to take it in and pay the exhorbitant labor to get it done?
Any of you grease monkey, wrench turning knowledgable guys got any clue(s) for me?
I appreciate the help guys. I have to go hunting in 2 months, a 5 hour drive one way and I don't want to run into any problems...especially on a 30 degree incline climbing a mountain.
JB
jborfair is offline
post #2 of 8 Old 07-02-2010, 03:49 PM
key99
Quoted: 312 Post(s)
IIRC there is an "allen type DRAIN PLUG" for water jacket on each SIDE of block, at the lower/rear of jackets.
99 1500 SLT QCSB 4x4 5.2 227k mi; SUN vac ga, tow hooks ... umpteenth 46re, LONG 28K lb tr cooler, HAYDEN temp ga ... 3.55 c/w broken clip, 255/70 MICH M+S ... RED HEAD, DSS, MOOG trac n adj BJ; AMS in motor n diffs; HUSKY flr mats ... New shocks, drums, EXTREME rotors, bat; rebuilt mas cyl, alt ... Recent windshield, rad, rr springs, frt axle joints n seals ... Hand vac pump to control recirc door
97 1500 SLT CCSB 4x4 5.2 auto 3.55 lsd, factory tr cooler, HD fan clutch; 140k mi
--Both have spray in box liners; need PS coolers, htr cores and better water pumps for htr/winter use
key99 is offline
post #3 of 8 Old 07-03-2010, 12:18 PM
Woodstock
Woodstock
Woodstock's Avatar
If I remember right, there is a large freeze plug between the allen type Drain Plugs that key99 mentioned. The freeze plug is straight up from the crank at the top of the block. Sorry, but you have to pull the engine or transmission to replace it.
2000 1500 Sport 5.9 4X4 QC 46re w/TFODjr
SCT by hemifever, 4.10 Gears, Stainless Steel Headers
HellBent Steel leveling kit, 33X12.50X16 Super Swamper TSL Radials
1985 350 Custom Dually 360ci 4barrel 727
1990 Jeep YJ 4.2 waiting for 5.9 swap
Woodstock is offline
post #4 of 8 Old 07-03-2010, 03:29 PM
key99
Quoted: 312 Post(s)
... Woodstock. I think that would be the CAMSHAFT plug, with LIFTER GALLERY plugs(allen type) on each side of it.
... There are 2 freeze plugs for water jackets ON BACK OF BLOCK; 1 on driver side(at 9:30), and 1 on pass side(at 1:30), when looking at crankshaft from rear..
.. Is intake mani to "head intake surface"(heads have rear coolant ports) leaking, and draining down btw block and trans?
... Check mani bolts for wet/corrosion.
key99 is offline
post #5 of 8 Old 07-03-2010, 03:43 PM
Woodstock
Woodstock
Woodstock's Avatar
Yep, you're right key99. I could only picture in my mind that plug (camshaft) in the top position on the back of the block. I usually have a small block laying around to go look at .
post #6 of 8 Old 07-04-2010, 02:17 AM
key99
Quoted: 312 Post(s)
Ya, all i got is a pic; havent a clue how to post it, so brokn english ul hav to do, lol.
key99 is offline
post #7 of 8 Old 07-04-2010, 11:40 AM
Moparite
Moparite's Avatar
Quoted: 322 Post(s)
Get the brass freeze plugs not the steel. You'll only have the same problem years down the road. My .02 worth.
Moparite is online now
post #8 of 8 Old 07-05-2010, 03:43 PM Thread Starter
jborfair
jborfair's Avatar
I will check the manifold for any leaks. It would be easy to find since the engine is all but showroom new.
jborfair is offline
    3.7 Litre Freeze Plug MikeSchroeder 3G Dodge RAM - Drivetrain Talk 1 01-20-2007 07:18 PM
    freeze plug 03redslt4x4 3G Dodge RAM - Drivetrain Talk 1 01-19-2007 08:35 AM
    Picture of a freeze plug? RandallGee 2G Dodge RAM - General Talk 0 12-10-2006 04:12 PM
    Freeze plug? TheMHC 2G Dodge RAM - General Talk 9 03-10-2005 08:48 PM
