changing brake pads - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 15 Old 06-24-2010, 09:11 PM Thread Starter
Sal2008
changing brake pads
I own a 2008 dodge grand caravan with four wheel disc brakes,I tried to change the brake pads on the rear but couldnt get the piston to go back in,is there a trick to do that or the calipers are bad ?
thanks
Sal2008 is offline
post #2 of 15 Old 06-24-2010, 11:18 PM
EddieHemi
Sport'in
EddieHemi's Avatar
I haven't seen the piston on a grand caravan, but it might have to screw in. If it does, it will have notches in the top of the piston instead of being hollow it will be solid. You can screw it in with a pair of needle nose pliers.
2009 Ram 1500 QC Sport w/ HEMI & 3.92s
4th Gen Truck Club Member #6
Twiggy HID Club Member #15
RIP, Shannon White, my friend, my brother. 837 you will never be forgotten...
Upgrades:
Rottie Security, Tint, Michelin LTX Tires, Air Lift 1000 Bags, Borla Exhaust, Airaid Cold Air Intake, Airaid Poweraid Throttle Body Spacer, 6000k Highs, Lows, and Fogs by Twiggy, Custom touches by Colin (Hurst Collision)
WHO DAT !!!
EddieHemi is offline
post #3 of 15 Old 06-24-2010, 11:21 PM
EddieHemi
Sport'in
EddieHemi's Avatar
I just searched for some pics of it and it looks like it is an average piston that is hollow in the middle. You should be able to push it back in using a C clamp and the old pad.
Upgrades:
WHO DAT !!!
post #4 of 15 Old 06-25-2010, 06:42 PM
Rick99
Open the bleeder so you don't send dirty fluid back into the system (it also makes it easier to push the piston back in. Just make sure there's enough fluid in your master and don't let it run dry.
2003 Durango SLT
AWD, 4.7l
Mods: Remote Start
Just got a new set of BFG All-Terrains
Planning retrofit to 4WABS
1999 Durango SLT+
4x4, 5.2l
Mods: B&M Supercooler, Ford OEM Remote Start/Keyless Entry/Alarm, Heated Seats
01 T&C Limited 3.8l
Rick99 is offline
post #5 of 15 Old 06-25-2010, 07:24 PM Thread Starter
Sal2008
brakes
Hello
Thanks for the response,I tried doing it the way you mentioned,thats the way Ford or Chevys are but It didnt work,must be bad calipers
Sal2008 is offline
post #6 of 15 Old 06-25-2010, 08:39 PM
EddieHemi
Sport'in
EddieHemi's Avatar
Originally Posted by Sal2008 View Post
Hello
Can you post a pic of your caliper?
Upgrades:
WHO DAT !!!
post #7 of 15 Old 06-28-2010, 08:57 PM Thread Starter
Sal2008
brakes
piston is not hollow,it is solid at the end but has two small notches across from each other,I believe it has to screw back in but havent been able to find any inf. yet to validate this
Sal2008 is offline
post #8 of 15 Old 06-29-2010, 10:54 AM
MickDodge
That is the norm for rear disc brakes. You can usually get a pair of needlenose pliers and turn the piston back into the caliper using those 2 notches. The C-clamp trick only works with front disc brakes which can be pressed back into the caliper. There is also a tool out there to use to screw the rear pistons back into the bore. I know I borrowed one once from Advance Auto Parts for my VW.
You might also check out this article which explains things a little better. Step 3 seems like your issue...
http://www.ehow.com/how_5556482_use-...ston-tool.html
MickDodge is offline
post #9 of 15 Old 06-29-2010, 11:30 AM Thread Starter
Sal2008
brakes
thanks for your help,I will borrow a tool from Advance
thanks again
Sal2008 is offline
post #10 of 15 Old 06-29-2010, 12:10 PM
MickDodge
If Advance doesn't have one laying around to borrwo, they may make you buy one and then return it for refund when you are done. That's what I had to do.
post #11 of 15 Old 06-29-2010, 12:15 PM
dougiepa
Check Harbor Freight Tools (if you have one close to you) if you can't get it from Advance. They have caliper tool sets for a 10 peice for 29.99 (online for 9.87) and an 18 peice 44.99 (online for 34.99). The store should give you the online price if you ask about it. I bought the 18 peice set for my volvo, just for more options on disk sizes. Worked well for me.
dougiepa is offline
post #12 of 15 Old 06-29-2010, 12:27 PM
MickDodge
Realistically, a large set of channel locks should be enough to rotate the pistons and get them seated on a Grand Caravan. I would really try that first before going through all the trouble with Advance or whomever.
post #13 of 15 Old 07-05-2010, 06:26 PM
52motorhead
The rear calipers have to be screwed back in as the regular brakes and e-brake work off the piston.
2012 Jeep Wrangler Sahara Unlimited
2009 Grand Caravan 25th Anniversy -sold
1990 Honda Civic
1952 Chev p/u
52motorhead is offline
post #14 of 15 Old 07-09-2010, 01:08 PM
caddylover
go to your local parts store and get a brake block. I picked up one for my cadillac sts when doing the rear brakes for $2.99.
caddylover is offline
post #15 of 15 Old 07-09-2010, 01:14 PM
EddieHemi
Sport'in
EddieHemi's Avatar
I would just screw it in with a pair of needle nose pliers
Upgrades:
WHO DAT !!!
    Changing Brake Pads - Special tools? MadScientist813 3G Dodge RAM - General Talk 10 11-04-2009 07:34 AM
    Changing my brake pads Help!!! hemisport25 3G Dodge RAM - General Talk 15 10-16-2007 09:58 PM
    changing front brake pads? smoke20 2G Dodge RAM - General Talk 9 10-27-2005 01:33 PM
    Changing out brake pads tommiwan 3G Dodge RAM - General Talk 11 07-11-2005 03:36 PM
    Changing brake pads? rxjay2play 2G Dodge Dakota - Tire/Wheel/Susp Talk 13 05-20-2005 01:19 PM
