How do i get front brake rotor off - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 8 Old 09-08-2004, 08:44 PM Thread Starter
cumminsman24
i cant figure out how to get the rotor off i dont see any snaprings that need to come off please help 1998 dodge 2500 cummins24valve diesel 4x4
cumminsman24 is offline
post #2 of 8 Old 09-09-2004, 07:23 AM
Hamr26
Hamr26's Avatar
rotor removal
I've heard on the 3/4 ton models that the front hub/bearing assembly must be removed first to take off the rotor.
Hamr26 is offline
post #3 of 8 Old 09-09-2004, 09:46 AM
MSCH2112
Bushwacker!
MSCH2112's Avatar
this isn't specifically related to your rotor removal but does cover the diesel axle removal... http://dieselpowerman.tripod.com/Fro...xle%20Tech.htm
mike
2012 Power Wagon LARAMIE Pkg. w/ 12k Warn winch, Nav, Sunroof, Leer Topper, AMP boards, Spray on-bedliner-rockers-flares
Support Search and Rescue-GET LOST
High-Lift Jack w/ lots of tow ropes and winch tools
2009 Victory Jackpot Cory Ness Edition!
SOLD 2005 Power Wagon Quad w/ 12k Warn winch, loaded incl. leather, rockrails, nav, sunroof, 9.5 ti Warn winch in the rear, Gibson Headers and catback, Pace-Edwards full metal elec. bed cover and elec. tailgate lock, PIAA driving lights behind grill.
MSCH2112 is offline
post #4 of 8 Old 09-09-2004, 06:55 PM
jerseyboy
my buddy is a mechnic and he did my brakes for me a long time ago and said that the rotors are wierd. they have to be cut while they are on the truck on 4wd models. whether or not this is true i dont know
"Eatin ford's, shittin' chevy's"
jerseyboy is offline
post #5 of 8 Old 09-09-2004, 08:49 PM
hotrod_06010
on my truck I pulled caliper off and two little clips on the studs and the rotor came right of.
hotrod_06010 is offline
post #6 of 8 Old 09-09-2004, 09:19 PM Thread Starter
cumminsman24
thanks mike that helps alot!
post #7 of 8 Old 09-10-2004, 09:29 AM
v10sport
Built Not Bought
v10sport's Avatar
ON 94 to 99 2500/3500's you must pull the hub assembly and the knock the rotor off from behind the hub. On 2000 up the 2500/3500 went to a slip on rotor like a 1500.
2000 Dodge 2500 Quad Cab LB V10 with many many mods.
7500 pounds
1/8th 10.193
67MPH
1/4 16.024
84.01 MPH
05 610 CTD QC 4x4 Needs some mods
02 Jeep Grand Cherokee 4x4
v10sport is offline
post #8 of 8 Old 03-11-2005, 10:48 AM
MIKE AINSCOW
mike ainscow
Your post from V10 sport ( #7 post) is exactly correct. The Rotors will hammer off once the hub/bearing(one unit) is removed. You will probably destroy the rotor doing this,they do not come off willingly.Your area dealer or specialty 4x4 shop may have the specialty puller available for rent(there is a specific tool for this) if you intend to do this work yourself.If your installing new rotors, don't worry about it.Beat them till the jump ship.If your replacing, Buy Wagner rotors...very superior in quality, are about 60 thou thicker than oem, and can be turned two or even three times in the future with tons of metel left above minimum spec...Mike
MIKE AINSCOW is offline
