Thread Tools |
Post #1
**Updated 06/01/2010**
Compilation of RRT/TSB IDs 08-007-10 -- (TSB) ECO/Fuel Saver light activation 08-018 -- Engine Controls - TIPM update for ECM PROM update issues 08-071 -- Flash cluster for odometer issue 08-077 -- SIRIUS inop due to initial subscription set to less than 1 yr. 08-081 -- Crew cabs w/ sunroof; sunroof drain tubes 08-093 -- Non-memory power pedals won't adjust. Restore vehicle configuration through TIPM 08-100 -- Replace muffler; only factory duals w/ "quiet" muffler 08-101 -- Inspect tailgate cap for warping or loose; replace if needed 09-004 -- PCM flash for spark knock 1800-2500 rpm and/or NVH improvements in MDS 09-010 -- Washer sensor weepage; replace washer harness w/ overlay 09-011 -- Inspect ram box lids for warping; replace if needed (come pre-painted) 09-018 -- Flash RER radio for update 09-020 -- Zip tie rear axle vent tube to frame for possible hanging down 09-023 -- Flash park assist module 09-024 -- Lube passenger seat rail or whatever (for creaking) 09-029 -- Inspect for hood squeak 09-035 -- Tailgate cover (taping) 09-041 -- 2009 DS flash ABS/ESP module 09-063 -- 2009 DS; rambox lock replacement 09-084 -- Replace hood ajar switch 09-095 -- Inspect window molding 09-096 -- Lens lamp, high mounted stop lamp; replaced lense 10-009 -- Replace exhaust manifold bolts 10-020 -- 10-022 -- 10-028 -- 10-029 -- Replace axle disconnect seal 10-061 -- 10-083 -- 11-019 -- 11-047 -- 11-057 -- 14-001 -- Fuel system - Difficult fuel fill/nozzle shuts off 18-019 -- Engine Controls - MIL on/multiple DTC's set 22-001 -- Wheel shake/tire flat spot 22-002 -- Wheels/Tires - Chrome clad wheel balancing information 26-001 -- Maintenance - Fluid flushing information RECALLS: J-10 -- Wiper Motor Replacement L-04 -- Outer Tie rod Ends Unidentified: none Please respond with any additional RRT/TSB IDs and Recalls not listed above. I will update as needed. Per Bubba_Hemi, this thread is informational only. Any discussions about a particular RRT/TSB shall be discussed here. Last edited by Bubba_Hemi : 05-13-2012 at 08:48 PM. |
| Sponsored Links | |
Advertisement |
Post #2
Also (for what it's worth) you can submit the last 8 of your VIN via the "I need RECALL OR CUSTOMER SATISFACTION NOTIFICATION INFORMATION" link on Dodge's site.
WCOG 2009 Dodge Ram |
Posted: 09-12-2010, 04:16 PM
Post #3
Very cool link bra. Thanks...None for my 2010 dodge ram 2500 4x4.
Wayne |
Posted: 09-16-2010, 10:41 AM
Post #4
09-084--Replace hood ajar switch
left off for some reason. thx Bubba |
Reprogram Hvac Control Head & Insp./repl. Actuator
- Posted: 09-19-2010, 12:43 PM
Post #5
Found on www.dodge.com - don't see a number, but description follows; note that link to download recall notice appears to be broken.
Recall and Customer Satisfaction Notification Information Listed below are details about the recall(s) on your specific vehicle. Click the link for an electronic copy of the official Recall Notice. Please contact your nearest dealership to perform the recall as soon as possible. Recall Description ........ REPROGRAM HVAC CONTROL HEAD & INSP./REPL. ACTUATOR Recall Notice .............. Download (PDF) Recall Type ................ CUSTOMER SATISFACTION Issue Date ................. Fri Sep 17 00:00:00 EDT 2010 Vehicle Recall Status ... INCOMPLETE
09 RCSB SLT 4X2, 5.7 HEMI, 3.92LS (yeah, it's Stone White...) |
Posted: 09-30-2010, 12:18 PM
Post #6
I just got the phone call on the HVAC as code K17
A quick google turned this up: 2009-2010 K17 Recall 2009-2010 (DS) Ram Truck (1500 series) 2010 (DJ) Ram Truck (2500 series) 2010 (D2) Ram Truck (3500 series) NOTE: This recall applies only to the above vehicles built through May 22, 2010 (MDH 052220) . The HVAC mode door actuator gears on about 225,000 of the above vehicles may break and result in the inability to fully control the HVAC functions. All involved vehicles must have updated HVAC control head software installed and the mode door actuators must be tested and replaced as required.
Posted: 10-01-2010, 01:41 PM
Post #7
I just picked my truck up for Service Bulletin K17 and boy does Dodge give them plenty of paid time for this one. Dodge is paying them for 6.8 hours of work. They only had the truck a total of 1 hour and 15 mins.
In that same amount of time they did two additional Rapid Response Transmittals that I wasnt aware of. RRT 09-095 Belt Molding Inspection and Replacement (2 hours) RRT 09-096 Center High Mounted Stop Lamp Reseal (.3 hours)
![]() Vehicle: 2009 Dodge Ram Crew Cab 4x4 Sport Powerplant: 5.7L Hemi OEM fully Loaded!!! University of Florida School of Building Construction Alumni GO GATORS!!! |
Posted: 10-04-2010, 11:25 PM
Post #8
Does the 09-096 pertain to 06s as well or do they have a different #?
06 Atlantic Blue 1500 Hemi Sport Bilstein 5100s, Nitto Terra Grapplers 295/60, 09 Factory 20s, Dual 2.5" exhaust w/ Super V Muffler & 4" tips, Pioneer Touch Screen DVD player 00 Intense Blue Dakota R/T AAR Cuda Hood, Crystal Clear Lights, HIDs, Roll pan, Fiberglass tonneau cover, Magna flow dual cat back exhaust, Clutch fan delete, K&N drop in, Alpine Head unit |
Posted: 02-11-2011, 12:13 PM
Post #10
cool deal
2011 ram 1500 big horn 4x4 qc 2010 journey stx |
Posted: 03-03-2011, 08:22 AM
Post #11
Dealer called a couple days ago and gave the wife a couple of codes that are not on your list. Any idea what they're for?
10-020 10-022 |
Posted: 03-17-2011, 02:35 PM
Post #12
I got a call. Couple weeks ago and was told that I didn't need to make a special trip but there was three issues, issue #1- is with front bumper corrosion and it referenced # 10-083, issue #2 was with the fuel filler housing # 10-061, and the last item was with the wireless key # 10-022, so the next day I called my dealer's service department and they said they had received what they called rapid response service bulletins on these items and they would take care off during the next service visit and they had never heard of any truck owner getting a call about items like this, so not sure why We have gotten calls from the 800 number but that was my experience, I will let everyone know how it goes when I take it to the dealership!!
Sorry about the book! LOL |
Posted: 03-23-2011, 05:55 PM
Post #13
Just had RRT 10-028 done. It is for a missing transfer case skid plate and cross member.
2010 Ram 2500 Hemi Crew Cab Big Horn 4x4 |
Posted: 03-24-2011, 10:02 AM
Post #14
Just got a call for this one:
11-019 Puddle Lamps
________________________________________________ 2009 Dodge Ram 1500 Laramie Hemi Crew Cab Black |
Posted: 07-12-2011, 11:07 PM
Post #15
RRT: 11-47 and 11-57. Does anyone know what these are?
2011 Ram 1500 CC Sport 4x4 Deep Water Blue Pearlcoat Mopar Molded Mud Flaps | WeatherTech Floor Mats | 2013 Sport Rims | 14" Magnaflow DIDO | Magnaflow 5" Tips | Y-Pipe Deleted | Tailgate Light Bar & LED Tails | BT Catch Can & Under Hood Kit | Tint Future Mods: Color Matched Tailgate Handle, Antenna Base, JBA Short Tubes, Roll-Bak Tonneau Cover |
Posted: 08-17-2011, 08:30 AM
Post #16
FYI.. New recall L-04. Outer Tie rod Ends. Launched 8-15-11 for 09-10 DS in "salt belt states"
Replaces outer tie rods and set toe.. |
Posted: 08-17-2011, 08:34 AM
Post #17
11-047 Flash: Intermittent No Start Or Intermittent RKE Function
11-057 - 2011 DD DJ DP DS D2 WINDNOISE AT FRONT Doors |
Post #18
Posted: 08-31-2011, 01:50 PM
Post #19
2006 Ram 2500 Sport QC 4x4 5.7 |
Posted: 11-20-2011, 07:17 AM
Post #20
Buddy of mine at another dealer found these for me. Told dealer I bought from and they said sorry we didn't catch them before we delivered to you, bring it in. All done. ![]()
2011 SLT Hemi Quad Cab 4x4 Big Horn, Rugged Brown Pearl Coat, TGC 1.5" front lift kit, Camowraps Realtree/Advantage Max 4 HD accent strips, Truxedo Soft Tonneau cover |
| Thread Tools | |
| What is a RRT??? | emsdad | 4G Dodge RAM - General Talk | 3 | 03-05-2010 12:31 PM |
| RRT or PCM reflash | JRam08 | 4G Dodge RAM - General Talk | 0 | 09-19-2009 01:48 PM |
| Good TSB or RRT bulletin on Radios | BULLRAM | 4G Dodge RAM - Interior/Exterior Talk | 1 | 09-01-2009 09:27 AM |
| RRT for wheel shake, they didnt tell us about... | BULLRAM | 4G Dodge RAM - General Talk | 5 | 08-23-2009 07:25 PM |
| 2004 Hemi Flash (5 spd Tranny)--Official Thread and TSB | hemi_power87 | 3G Dodge RAM - General Talk | 51 | 01-27-2005 05:51 AM |
Privacy Statement | |
