Installing Rear Lift Blocks?? - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 9 Old 06-08-2010, 04:50 PM Thread Starter
jmhemi
I just did my front leveling kit on my 2008 ram 1500 and it sat a bit higher than i wanted so i picked up some 2 inch rear blocks and new u bolts. Im just curious as to how tight i wanna torque the U bolts. A mechanic told me to tighten them evenly as tight as they will go with an impack and give a couple tugs with the wrench because there should be no play in them at all, is this correct? also do i have to unbolt the shocks and take the wheels off or can i just do it with everything together and im asuming i should do one side at a time? Any help would be awsome!
Thanks!
jmhemi is offline
post #2 of 9 Old 06-08-2010, 06:01 PM
LJM9000
When I installed my blocks the instructions said to torque them to 100 - 120ft/lbs
LJM9000 is offline
post #3 of 9 Old 06-09-2010, 06:08 PM Thread Starter
jmhemi
Did you remove the wheels do put them in?
jmhemi is offline
post #4 of 9 Old 06-09-2010, 10:59 PM
jakenbake13
jakenbake13's Avatar
I did, I jacked it up with the pumpkin, and put the frame on stands, and then lowered the axle with the jack
2006 QC 1500 5.7 4x4
Motor: Bassani catback si/so, Diablosport predator, Custom CAI 3" with K&N drop in, pacesetter longtubes (ceramic), Pacesetter Y pipe, magnaflow cats
Exterior: Zone 3" body lift, Westin ss oval tube steps, Rock lights, Duplicolor bed armor bedliner
Suspension: Rough Country 2.5 level,Napa reflex struts
Tires and Wheels: Mickey Thompson baja ATZ's 35x12.50r20, 1.25" wheel adapters front and back
Interior: Sony cd player, 2 sony x plod 12, Profile ap 2000 amp, Weathertech Digitals
jakenbake13 is offline
post #5 of 9 Old 06-09-2010, 11:15 PM
LJM9000
I did the same thing. One thing I wish I would have done is had a friend there to help align the blocks, would have made it much easier.
LJM9000 is offline
post #6 of 9 Old 06-11-2010, 05:30 PM
montpelier
Be sure to post some pics when your done im getting mine leveled and putting blocks in the rear just cant decide if i want 1 or 2 inch blocks.
montpelier is offline
post #7 of 9 Old 06-11-2010, 07:50 PM Thread Starter
jmhemi
Is it fairly difficult to get the notch or pin and the hole on the other side ligned up or nothing to crazy?
Thanks for the help, and ill make sure I take pics!
jmhemi is offline
post #8 of 9 Old 06-11-2010, 08:50 PM
GeorgiaRam
WDE
GeorgiaRam's Avatar
Quoted: 1 Post(s)
Not extremely hard, but sometimes it is a pain when you are trying to push the axle back and forth to align it while lifting it up in position. With two people it should be very easy, but can be done by yourself.
2004 Dodge Ram 1500 5.7L Hemi Larime AWD
Air Ram PowerWire / Air Ram Jet Stream Scoop / 180* T-Stat / Superchips 3865 / K&N Cold Air Intake / True Duals / (2) 12 in Dynomax Race Bullet Mufflers / Flowtech X Pipe / Dumped with Turndowns Before The Axle / 6" Fabtech Lift / 35" Cooper Discoverer STT's / 17" Procomp 7031 Wheels / Bilstein 5100 Shocks / Moog Upper & Lower Ball Joints and Tie Rod Ends / Bushwacker Pocket Style Fender Flares / Rhino Dominator II Nerf Bars / Line X / (2) Hella 500's / Foglight Jumper Mod / Oil and Tranny Pan Heater / Panasonic CQVD7003U DVD Flipout Headunit / Fox Box / Rockford Fosgate P3 Subwoofer / Rockford Fosgate P325.1 Amp (For Sub) / (2) JL CR250 Speakers (Front Doors) / (2) JL TR600-CXI Speakers (Rear Doors) / (2) JL C2-350X Speakers (Dash) / Pioneer GM-5500T Amp (For Speakers) / Remote Start with Security / Stubby Antenna / Bully Billet Black Locking Fuel Door / MRK Group Interior Parts / Tinted Windows / Tow Mirrors / UWS Black Powder Coated ToolBox / Recon Smoked Cab Lights / Black Clear Corner Headlights / Tinted Tails and 3rd Brakelight / Badges, Bumpers, and Larime Grill Painted Black
1998 Dodge Ram 1500 on 37" Procomp Extreme MT's SOLD
GeorgiaRam is offline
post #9 of 9 Old 06-11-2010, 09:05 PM
RubberFrog
I RECOMMEND FUKKEN WAX
RubberFrog's Avatar
Thanks!
Your mechanic must be a complete retard if he told you that!
'07 QCSB, Flame Red 5.7 4x4 SLT
Performance:
Internal: Custom Cam, 180 T-Stat - Intake: Ported Throttle Body, K&N Filter - Exhaust: Edelbrock Shorties, Magnaflow Y Pipe, Raceland Cutout, Dumped Gibson Catback
Tuning & Monitoring: SuperChimps, Aeroforce Interceptor w/ afr
Suspension & Tires:
Lift: 6" Suspension, 3" Body Lift - Wheels: Custom Painted BMF S.O.T.A.s, 37" Trail Grapplers, Mopar Wheel Well Liners
Appearance:
Bed: Leer 100XQ Shell, Line-x XTRA, Defender Roof Rack - Other: SRT Hood, Bushwacker Pocket Flares,Tow Mirrors, Nerf Bars, 2500 Tow Hooks, Shorty Antenna, Tactical Grill
AV:
Tunes: Kenwood DDX512, Infinity Reference Speakers, Kicker 10" Sub, Kicker 400.1 Amp, FoxBox - Video: 10.4" TFT-LCD Flip-down Overhead Monitor, R Cam, Chuck Norris Kicked My Ass
Lighting:
Led Tails, Smoked Cab Lights, 4x VisionX 180w, Hella 500's
RubberFrog is offline
    Rear Lift ? Blocks vs. Shackles norcal_ram03 3G Dodge RAM - 4X4 Talk 0 03-12-2010 12:49 PM
    Rear lift blocks? moose51 3G Dodge RAM - 4X4 Talk 8 01-01-2009 08:26 PM
    Rear lift blocks? 07ramlover 3G Dodge RAM - 4X4 Talk 18 01-04-2008 11:55 AM
    Rear lift Blocks Awasos 3G Dodge Dakota - Tire/Wheel/Susp Talk 7 05-31-2007 12:46 PM
    Ram rear lift blocks? shooterschmidty 3G Dodge Dakota - Tire/Wheel/Susp Talk 3 01-03-2007 11:27 AM
