Need transmission advice... Truck wont shift from 2nd to 3rd... And I suck at this - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 8 Old 06-08-2010, 12:13 PM Thread Starter
myosinner
myosinner's Avatar
Ok... Im pretty handy, but if I have a weak point its definitely transmission work. I can remove and install them, and do clutches etc, but I know little about their internals. So bear with me.
Problem Im having is this:
Truck runs fine and moves, but will not shift from 2nd to third gear unless I rev the engine to 4k rpm or so, at which point it shifts and acts normally, but as soon as it downshifts again I cannot get it to upshift unless I rev it up again.
Now Ive searched around and come up with a few possible solutions:
- clogged up valve body, or broken off bolt on the valve body
- needs a fluid change to flush any bad fluid out
- new tranny time
I really dont have the money for a tranny rebuild right now, so any advice would be appreciated, and any links to a write up on doing the valve body would be appreciated. Thanks a ton guys
02 QC 4x4 5.9 360 Magnum.
5" rough country lift. 3 inch PA body, 2" rear shackle, 35 x 13.5 Mickeys on 20x10 Monsters, Superchips, straightpiped, 4.56 gears, detroit locker rear end, Volant intake, 06 front end conversion, , magnaflow stainless exhaust, uh.... Im sure Im forgetting a ton
myosinner is offline
post #2 of 8 Old 06-08-2010, 12:16 PM
hawks4x4ram
Start with the simple stuff first: tranny flush and filter, PCM reset, etc... Good luck!!!
'04 Dodge Ram QC 1500 4x4
285/70/17 BFG All Terrains
Everything else pretty much stock (As far as Dodge is concerned
"That's what I love about these high school girls, man. I get older, they stay the same age." Wooderson, Dazed and Confused
hawks4x4ram is offline
post #3 of 8 Old 06-08-2010, 12:26 PM
Ragnarok
I did a filter change on a friends Ram a number of years ago. The filter was dirty and the magnets had alot of debri on them (the ones they put in the pan)
As soon as the filter/fluid change and the magnets were cleaned off (as well as you can clean a magnet off with microscopic metal shavings clinging to it) they reported much smoother shifting. Since it was a service interval and I went by the book (they were 10k over the 50k service) the worst part was scraping the old gasket off.
In your caes there may be more going on, but this would be a good place to start, as dropping the pan can give you a good idea of how things are.
Good luck
03 Durango (Grey) Gibson Cat Back. K&N FIPK. Hunter Brush Guard and Nerf Bars - coated in Line-X Bedliner. Hella 500 Off Road Lights. Bumpers and rocker panel coated with Line-X Bedliner.
03 1500 Hemi 4x4 Ex. Cab (Atlantic Pearl Blue) Superchips FlashPack. K&N intake. Line-X bedliner. Bumpers & rocker panels colormatch bedlined (Line-X)
Ragnarok is offline
post #4 of 8 Old 06-08-2010, 12:30 PM Thread Starter
myosinner
myosinner's Avatar
If Im not mistaken my trans is completely mechanical right? So would a reset make any difference?
post #5 of 8 Old 06-08-2010, 03:03 PM
JackedDak03
JackedDak03's Avatar
Quoted: 1 Post(s)
You have the 46RE I believe, or else its the 47RE. Either way I'd start with new fluid and take a good look at the old to see if its burnt. It could be something as simple as a solenoid but you won't really know until you bring it somewhere- which is what I'd do if I were you. Go to a good tranny shop and have them check it out.
BMW X5 & Chevy 2500 HD POS
Gone:
2002 Ford F350 Crew Cab Diesel
1999 Dodge Ram 2500 Quad Cab 4x4 Sport V10
1998.5 Dodge Ram 2500 Quad Cab 4x4 24V Cummins
2004 Dodge Ram 2500 Quad Cab 4x4 HEMI
2003 Dodge Dakota Quad Cab 4x4 4.7
2002 Dodge Ram 1500 Quad Cab 4x4 4.7
2001 Dodge Ram 1500 Quad Cab 4x4 5.9 V8
1999 Dodge Ram 2500 Quad Cab 4x4 5.9 V8
1997 Dodge Ram 1500 RegCab ShortBed Sport 5.9 V8
Past -92 Daytona R/T, 94 3000GT, 91 TransAm, 88 RX7 TII, 89 YJ, 92 Bronco, 88 YJ, 94 F150, 96 Rodeo, 88,89,90,91 5.0 Mustang's, 03 Mustang GT, 04 SRT4
JackedDak03 is offline
post #6 of 8 Old 06-08-2010, 03:07 PM
JackedDak03
Quoted: 1 Post(s)
Here you go, just found this in the 2nd gen section since they use your tranny as well:
http://www.dodgetalk.com/forums/show...shift+from+2nd
Gone:
post #7 of 8 Old 06-08-2010, 03:38 PM Thread Starter
myosinner
myosinner's Avatar
I have a strong aversion to paying anyone to do something I can do myself, but in this case i might pay them to diagnose it at least. Seems like if this is the problem it would be simple enough, and a fluid change might even solve the problem.
post #8 of 8 Old 06-08-2010, 05:23 PM
Ragnarok
You can change the solenoid yourself, may take a bit to find one, but you could do it.
Ragnarok is offline
    Transmission wont shift by itself trujiland 1G Dodge Durango - Drivetrain Talk 0 09-30-2009 01:27 PM
    Wont Shift from 2nd to 3rd... buckeye90 1G Dodge Durango - Drivetrain Talk 3 10-27-2007 10:45 AM
    wont shift to 3rd Baseman72 2G Dodge RAM - Drivetrain Talk 1 05-07-2007 09:32 PM
    transmission wont shift landguy 2G Dodge RAM - Drivetrain Talk 1 12-15-2006 01:43 PM
    Transmission wont shift ram02 1G Dodge Durango General Talk 7 03-17-2005 07:35 AM
