46RE Rebuild, No Forward gears - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 15 Old 06-04-2010, 02:09 PM Thread Starter
renegadejr
I just completed the rebuild of my 46RE in 96 Ram 1500 Indy. Everything seemed to go okay with the rebuild/reinstall. However, I have no forward gears, reverse works great. Fluid levels are good. Any suggestions of what to check next?
renegadejr is offline
post #2 of 15 Old 06-04-2010, 02:12 PM
MeenGreen5.2
i'm blue :D
MeenGreen5.2's Avatar
Quoted: 1 Post(s)
damn bummer! mines getting rebuilt as we speak. lets see how it goes.
2010 dodge ram 5.7 sport
deep water blue pearl
BLUE
24"verde rims
stock
BLUE TRUCK CLUB MEMBER #249
Trucks and Guns member #164
MeenGreen5.2 is offline
post #3 of 15 Old 06-05-2010, 10:43 PM
tactransman
Transmission Man!
tactransman's Avatar
Drop the VB and air check the forward clutch. Also, make sure the VB manual valve is engaged to the" rooster comb" properly.
Terry aka tactransman
'99 Ram 1500 4X4 5.9 Automatic #110 in the White Truck Club
Aren't you tired of getting your parts for your Super Bee from a kid that thinks a Civic is a "hot rod"!
Mods:
MSD Blaster 3 Coil
Magna Flow Cat and "Y" pipe
46RE Built to the Hilt
Transgo TF OD JR Shift Kit (With Mods)
Billet Cover Converter
Upgraded to five direct clutch drum
Five Overdrive Brake Clutch pack
47RE STEEL front planetary
Sonnax Reverse servo parts
HD Kevlar Lined Rigid Int Band
Deep Pan w/cooling tubes
3.8 ratio Int lever
billet Int servo struts
tactransman is offline
post #4 of 15 Old 06-05-2010, 10:58 PM
madmikeismad
R.I.P Big Blue
madmikeismad's Avatar
Quoted: 109 Post(s)
Mine did that too, it was a sealing ring on the input shaft. I still hate my life for that mistake.
Mike Hill
Purple People Eater - 98 12v - Maybe 800whp on old block:
The Race Truck
01 Ram 1500 Sport 4x4 5.9 (RIP Big Blue
madmikeismad is offline
post #5 of 15 Old 06-06-2010, 01:11 PM Thread Starter
renegadejr
Thank you i will test and let you know what happens.
post #6 of 15 Old 06-10-2010, 11:27 AM Thread Starter
renegadejr
Sorry everybody i was out of town for a few days. I just got home dropped the valve body, checked the rooster cob, and air tested the front servo. The rooster cob is seated properly and the servo moved with the air pressure. Any suggustions would be appreciated.
post #7 of 15 Old 06-10-2010, 11:40 AM
tactransman
Transmission Man!
Your not air checking the servo,you need to check the FORWARD CLUTCH.
Mods:
MSD Blaster 3 Coil
3.8 ratio Int lever
post #8 of 15 Old 06-10-2010, 11:53 AM Thread Starter
renegadejr
I also tested the front and rear clutches i herd a soft thump and could feel some internal movement.
post #9 of 15 Old 06-10-2010, 11:56 AM
tactransman
Transmission Man!
Well,it definitely has to come back out.
Mods:
MSD Blaster 3 Coil
3.8 ratio Int lever
post #10 of 15 Old 06-10-2010, 11:56 AM Thread Starter
renegadejr
Thank you for the diagram it's very helpful.
post #11 of 15 Old 06-10-2010, 11:58 AM Thread Starter
renegadejr
Thats not grate news what do you think it is.
post #12 of 15 Old 06-10-2010, 12:09 PM
tactransman
Transmission Man!
It is hard to say,broken sealing ring,torn missing lip seal.
NO DRIVE RANGE (REVERSE OK)
1. Fluid Level Low. 1. Add fluid and check for leaks if drive is restored.
2. Gearshift Linkage/Cable Loose/Misadjusted. 2. Repair or replace linkage components.
3. Rear Clutch Burnt. 3. Remove and disassemble transmission and rear clutch and seals. Repair/replace worn or damaged parts as needed.
4. Valve Body Malfunction. 4. Remove and disassemble valve body. Replace assembly if any valves or bores are damaged.
5. Transmission Overrunning Clutch Broken. 5. Remove and disassemble transmission. Replace overrunning clutch.
6. Input Shaft Seal Rings Worn/Damaged. 6. Remove and disassemble transmission. Replace seal rings and any other worn or damaged parts.
7. Front Planetary Failed Broken. 7. Remove and repair.
Mods:
MSD Blaster 3 Coil
3.8 ratio Int lever
post #13 of 15 Old 06-10-2010, 02:27 PM Thread Starter
renegadejr
Thanks for all the help i really appreciate it. I am going out to the garage right now to pull the trans. I will let you know what i find.
post #14 of 15 Old 06-20-2010, 08:07 PM Thread Starter
renegadejr
I just wanted to let everyone know what i found. It turns out that i installed the front clutch piston backwards ( idiot move i know ) i thought when i was testing it i felt some movement in there but i guess not. However i was able to turn this negative into a positive. I took the opportunity to do several upgrades i installed a shift kit, aluminium accumulator piston, 3.8 kickdown lever, heavy duty band strut, 4 gear rear planetary, upgraded overdrive clutch pack, and replaced the overdrive piston spacer to accomodate the extra clutch pack. I reinstalled the transmission today and it works great! Thanks everybody for all the help.
post #15 of 15 Old 06-30-2010, 10:20 PM
RamThis
RamThis's Avatar
Quoted: 2 Post(s)
Good job most folks are scared of the trans!
2000 Dodge Ram 1500 Single Cab, 5.9 Auto, 4.10's, Auburn LSD, Edelbrock headers, 2.5" true duals with crossover, MSD Superconductors, APS Plenum Kit, Level10 Trans kit, Trans-Go shift kit, 2-4 BellTech Drop, SS/T rims, Toyo Proxes ST 285-60-17's, Sir Michaels Roll Pan and tailgate handle relocator, Keystone bumper cover with light openings, PIAA fogs, painted grille shell, painted Street Scene Speed Grille Inserts, SCT XCAL-2, Alpine head unit, Infinity Components front, Infinity Coaxials back, Infinity 500W 4 channel amp, Infinity Basslink, new dash, steering wheel, and guage bezel.
1996 Dodge Ram 1500 Club Cab, 5.9 Auto, 4.10's, Detroit Locker, Race Truck Trends Nascar Bumper, Painted SS/T Stripes, Alpine HU, Alpine Sound Field Processor, MTX Thunderform. 5.9L bored .030 over, Sealed Power coated pistons, balanced and polished crank, Comp 210 Cam, MP Timing Chain tensioner, Melling HV oil pump, 1.92 oversized valves and mild porting, Pacesetter Longtube Headers, FMS 24lb Injectors, Level10 Transmission kit, Trans-Go shift kit, 5 gear OD Planetary. Way more to come.
RamThis is offline
    46RE rebuild trucklover 2G Dodge RAM - Drivetrain Talk 11 06-02-2010 05:11 PM
    Terry I need you, No forward gears. madmikeismad 2G Dodge RAM - Drivetrain Talk 38 03-06-2010 11:13 PM
    No forward gears Motorpsycho 2G Dodge RAM - Drivetrain Talk 34 01-26-2010 05:18 PM
    46RE Self Rebuild?? hazmattnelson 1G Dodge Durango - Drivetrain Talk 5 10-28-2009 08:41 AM
    46RE Rebuild anderc1 2G Dodge RAM - Drivetrain Talk 11 06-26-2008 09:13 AM
