Looking for a winch to mount to a car hauler (trailer)... - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 2 Old 06-04-2010, 01:30 AM Thread Starter
D-train
Quoted: 3 Post(s)
Question Looking for a winch to mount to a car hauler (trailer)...
I'm looking for a winch to mount to the deck of my car hauler. ...to pull up disabled cars. There are many different types out there. I'm not sure exactly what I should look for. ...starting with size? I'm only pulling a car up 30 degree incline over four feet. Then on the flat deck for 18 feet? Any help?
Thanks,
Mark
D-train is offline
post #2 of 2 Old 06-06-2010, 12:27 AM
TwinStick
IMO, I would go with a Warn winch for sure. They make quality stuff. You have lots of choices. Depends how much coin you got/want to spend. I would go NO LOWER rating than this one: http://www.warn.com/atv/winches/XT40.shtml & I would only use it with one of these: http://www.warn.com/atv/accessories/...tchBlock.shtml
Or this one: http://www.warn.com/truck/winches/src/tabor_9k.shtml
Or this one: http://www.warn.com/works/acwinches/3000ACI.shtml if you just want to plug it in to 120v.
08' PowerWagon w/6-speed manual G-56. 05' 30' toyhauler camper.(10,500lbs)
Hellwig LoadPro 35 bolt on 4 leaf helper springs.
No honey, I'm NOT done buying shit for the truck yet !!!
PurpleCrainium Diff Guards
K&N air filter --- WeatherGuard 20" black bed toolbox.
winch TPC bypass
Dual battery set up w/2 Sears DieHard Platinums-Gp 65 under hood-Gp 31 Marine deep cycle in bed toolbox w/plug-n-play set up. Custom 2000/4000w inverter set up w/quick connect. Triple bike mounts above the bed- custom made by me.
Crapload of recovery gear-always subject to adding more.
Fab Four rear bumper. Soon to be- a BuckStop Baja front bumper.--Temporarily on hold, see reason below.
Installed: Borgeson #000951 steering shaft. PSC steering brace(notched for PW by Rusty-thanks bud). Carli HD CroMo adjustable track bar. Carli CroMo control arms. Carli HD upper & lower balljoints x 2 sets (replaced under warrenty) & triple sealed u-joints in front axle shafts & rear driveshaft. Moog HD tierod ends x 4. Running total is now $4800. Yup, now i'm broke !!!
What, you ask, is the difference between a Dodge Ram and a PowerWagon ?? PW frame part # 55398868AC---Reg 2500 #55398813AC
About 2" taller, 12,000lb winch w/mounting brace between framerails,electronic disconnecting swaybar(for awsome articulation),electronic locking axles front & rear(for true 4-wheel drive),tow pkg, fully skidplated,forged one piece Alcoa rims w/internal beadlock lips,larger diameter(one ton) axleshaft in rear,160 amp alt,HD battery,4.56 gears,low range electronic recalibration of gas pedal sensitivity,more but thinner leafs in rear spring pack(for better articulation), 33" BFG All-Terrain tires. 78.016:1 crawl ratio. All for $6100.00 more! Oh yeah, almost forgot-Bilstein shocks. Gear ratios: 1st 6.29:1 2nd 3.48:1 3rd 2.10:1 4th 1.38:1 5th 1.0:1 6th .79:1.. Rev 5.74:1.
TwinStick is offline
    Enclosed Car Trailer/Hauler threetwos For Sale - Dodge Trucks 3 12-21-2009 10:35 AM
    weight of two car hauler phreakboy 3G Dodge RAM - Towing Talk 16 03-16-2008 10:13 PM
    need help with winch and winch mount pbssouthland 2G Dodge RAM - General Talk 1 03-07-2007 11:44 AM
    28' United Exp. Car Hauler strand_71 For Sale - Truck Parts 0 01-17-2007 03:56 PM
    Where to rent a car hauler? wombie 3G Dodge RAM - Drivetrain Talk 11 10-15-2004 06:52 PM
