How do you check the transmission fluid? - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 14 Old 05-28-2010, 09:25 AM Thread Starter
rebus20
I read the book and it says to check it at operating temp in neutral. I changed the fluid and filters the other day, put 5 1/2 quarts back in (2 wd) drove it around town (about 30 miles)and checked it idling in neutral and it was at the top of the cold line. I put another quart in and it put it just over the full cold line. Well I decide to wait and check it cold, the truck has sat for 2 days and now its at the top of the hot line. I dont know if I have too much fluid in it or not enough.
rebus20 is offline
post #2 of 14 Old 05-28-2010, 09:28 AM
weedahoe
Tricked out Ram
weedahoe's Avatar
Quoted: 21 Post(s)
It sounds like you have just enough and should not add anymore
On a side note, are you coming to out GA get together??
http://www.dodgetalk.com/forums/show...24#post3668924
2004 2wd Dodge Ram QC w/a 5.7 with Royal Purple 5w-20 in the motor, RP Max ATF in the trans, 80-90w in the 4.56 Auburn LSD rolling on American Racing Dale Earnhart "Tank" 24s wrapped in Pirelli 325/45/24s (36" tires)
| Debadged | SRT-10 hood | Custom CAI | Fumoto oil valve | 12" of lift | Power Wire | 9007 Bi-Xenon 6k | 9006 Single Beam 6K | 2nd battery tray (2K CCA total) | Big 3 upgrade w/1ga wire | Altezza clear tails w/LEDs | Clear LED 3rd light | 26gal to 35gal fuel tank swap | Viair 380c air compressor | train horns | Ceramic pads (F&R) | Westin Nerfs | Chrome door/tailgate handles | Custom switch panel | Custom center console | B&M QuickSilver floor shifer | Xbox 360 | Audiobahn A8000V (1600w sub amp) | Audiobahn 2002V (400w mid/high amp) | 2 12" Kicker DVC CVRs in a FoxBox | 4 Kicker DS650s (front & rears) | 2 Kicker KS350s (dash) | 2 8" LCD screens in the sunvisors | 2 6" LCD screens in the headrest | Clifford 50.7x alarm | 20/15% tint | Diablo Trinity - custom and 93 tuned | Mopar 6.1 ignition conversion | Start ignition push button | KRC 210 cam | 6.1 springs & pushrods | 6.1 half covers | 180* T-stat | Taurus E-fan | Pacesetter ceramic LTs | dual DMH cutouts | (2) 4x14" round magnaflows | 4x24" tips | X pipe | Jimmy Jammers | Ported (85mm) TB | Innovate LC-1 wideband | Sonnax transmission pressure booster | Mopar slush mats | RBP grill | powder coated calipers | custom rim/grill lights |
Next projects:
- Custom center console
- B&M Quicksilver Floor shifter
- Custom CAI
weedahoe is offline
post #3 of 14 Old 05-28-2010, 09:45 AM Thread Starter
rebus20
I dont know. Thats the first I have heard of it. I am not to far from macon, maybe 2 1/2 hours south.
rebus20 is offline
post #4 of 14 Old 05-28-2010, 10:18 AM
weedahoe
Tricked out Ram
weedahoe's Avatar
Quoted: 21 Post(s)
2.5 south of Macon and you are past me because Im 1.5 in Albany. Where are you located? Also go add/update your profile info.
Next projects:
- Custom CAI
weedahoe is offline
post #5 of 14 Old 05-28-2010, 02:17 PM Thread Starter
rebus20
Im not very far from you then. I am in Moultrie.
rebus20 is offline
post #6 of 14 Old 05-29-2010, 11:38 AM
MikeHTally
Got 2 Hemis
MikeHTally's Avatar
Quoted: 53 Post(s)
We're still planning to go to Macon. We'll be passing through Moultrie on the way.
As for the tranny fluid, "full-hot" after sitting for two days is too much. My tranny took right at seven quarts after a drop 'n' drain. I let it drain a long time, though. Tranny fluid is supposed to be checked at operating temperature.
While stopped, put it in drive for two seconds, then reverse for two seconds (doubt if the timing is all that critical). You should use a StarScan tool, but only the dealers have those pretty much. Just be sure the tranny is hot. Put it in park (engine running) and check the level.
If you add fluid wait AT LEAST two minutes for it to drain from the fill tube.
'03 1500 QCSB Hemi
Vent shades/15% tint
A.R.E. Tonneau/Bed Rug
Nerf step bars
Rear LED light bar/LED frt. turn signals
LED tails & 3d brake light/White Night backup lamps & LED interior lights
Halos/projector headlights KC HiLites Titanium Driving lights
Tailgate Easy Lift & EZ Down
E&G Classics mesh grill
WeatherTech Floor Liners
Overhead console with HomeLink
JVC KD-AR780 Receiver & CH-X1500 Changer
Jensen 6x9 3-way up frt., 5 1/4" 2-way rear
GenTex auto-dimming mirror & Towing mirrors
Fender liners & Ram splash guards
Silver Truck Club Member #140
S.N.A.T.C.H. Club Member 666-666
2 1/2" level kit
Jetstream Scoop/Power Wire
MagnaFlow Stainless Cat-back SI/DO
TrueFlow intake kit
Hellwig 7651 sway bar
Flex-a-lite Black Magic Extr. 180 Elect. Fan
Dick Cepek Chrome DC-1s/Bridgestone Revo2 285/70
MikeHTally is offline
post #7 of 14 Old 05-29-2010, 02:09 PM
PWDurangoFam
PWDurangoFam's Avatar
It needs to be checked in NEUTRAL with the engine running.
2006 Dodge Power Wagon
2001 Dodge Durango SLT Plus 5.9L 3.92
1972 Dodge Charger SE 440
PWDurangoFam is offline
post #8 of 14 Old 05-29-2010, 03:20 PM
MikeHTally
Got 2 Hemis
MikeHTally's Avatar
Quoted: 53 Post(s)
That is straight out of the Ram Shop Manual.
'03 1500 QCSB Hemi
Nerf step bars
2 1/2" level kit
TrueFlow intake kit
post #9 of 14 Old 05-29-2010, 06:26 PM
PWDurangoFam
If that is what the shop manual says, it is a testament to poor quality control, because the dipstick on my transmission says to check while idling in neutral.
The dipstick says check in neutral. My owners manual says to check in park. Dealer said owners manual was incorrect, check in neutral. Now you say shop manual says check in park.
post #10 of 14 Old 05-29-2010, 09:10 PM Thread Starter
rebus20
My book says to check it in neutral at normal operating temp after app 15 miles of driving and it should be in the hot range. I filled it to the bottom line while hot in neutral. It took 7 quarts but I let it drain for about 2 hours. Its running fine and I stopped by the dealer and asked them. They said I should be fine where its at.
rebus20 is offline
post #11 of 14 Old 05-29-2010, 10:12 PM
PWDurangoFam
I just came back from driving awhile, so the transmission was hot and checked it both ways. Not a huge difference, but it reads higher in park than neutral.
post #12 of 14 Old 05-29-2010, 10:18 PM
dodge-2004
What I did is to drain out old fluids into bucket without any spill. After done with drain out then pour into quarts to found out how much quarts you need to put back in with new fluids. That is how I check it.
dodge-2004 is offline
post #13 of 14 Old 05-30-2010, 02:47 AM
wyat72
PAID OFF!!!
wyat72's Avatar
Quoted: 20 Post(s)
x2
Truck: 08, Ram, 1500, HEMI, QuadCab, Big Horn, 4x4, Inferno Red, Chrome Grill, Chrome Molding, Chrome 20s
Appearance Mods: Chrome Mopar Tubular Side Steps, Chrome Mopar Bug Guard, Mopar Tow Mirrors, Mopar Mud Flaps & Wheel Liners, Mopar Tow Hooks, Putco Chrome Door Handle Covers, AMI Chrome Fuel Door, Curt Customized Hitch Cover, Bully Locking Tailgate Handle, ACI Vanish Tonneau, Line-X Bed Liner, Autospring 2" Leveling Kit, Cooper Zeon LTZs.
Performance Mods: SuperChips FlashPaq, Volant CAI, 12589 Magnaflow Muffler and Y-Pipe.
Red Truck Club Member #289
wyat72 is offline
post #14 of 14 Old 05-30-2010, 04:16 AM
LPGHemi
LPG Hemi
LPGHemi's Avatar
Quoted: 11 Post(s)
I think the biggest thing with this check, is as MikeHTally says.
Wait at least 2 minutes for the fluid to drain from the fill tube.
I waited at least 5, before I could get a consistent reading on my auto fluid level.
Plus, all this check in Park and check in neutral, really is a pain.
Both the manual and on the stick say different things.........WTF???
I think the transmission pump is running when in park or drive, but not when in neutral.
I wonder if this is the reason why we should check the fluid levels, a certain way??
Al.
03 Dodge Ram 1500 Hemi SLT
5.7 ltr QC sb 4x4
Performance Mods
K&N air & oil filters.
NGK Iridiums. Detroit TruTrac. TMR delete.
Procomp ES9000 with torsion bar tweak.
EBC slotted rotors with Yellow stuff pads and Cooper Zeon LTZ275/60/R20.
3" T304 stainless steel custom exhaust with high flow cat side exit near rear tire with DMH Electric cutout and T304 custom muffler.
Prinz LPG VSI sequential gaseous injection system
with 2x70 litre siamesed fuel tanks.
Exterior Mods
Siege Engineering Kong Mk2 Train horns 200 psi Viair 480C compressor & 3 gallon tank.
6000K HID Twiggy hi/lo + fogs.
White front and red rear LED license plate bolt Skulls.
Rear view colour camera with infra red, hooked up to an LCD rear view mirror doubling up as a 7" monitor
Tints 20's & Westins.
Raider Low Rider solid tonneau.
Xenon wheel arches.
Billet Aluminium Rapid hitch.
EZ lift tailgate torsion bar.
Bug deflector.
Dodge valve caps.
Interior Mods
Black coin holder ha ha ha.
DVD head unit.
2xRockford Fosgate Punch 12" subs.
2 Kenwood 6x9's & 2 5.25's.
2x9inch DVD screens built into custom headrests.
Full custom black leather interior with red piping & custom stitched red Ram logo into front seat backs .
Toad Thatcham cat 1 alarm
LPGHemi is offline
    Proper way to check transmission fluid level lrning Dodge Caravan General Talk 3 12-29-2009 04:49 PM
    Transmission Fluid Change Or Transmission Flush? AmericanRobster 3G Dodge RAM - Drivetrain Talk 21 12-07-2009 11:12 AM
    How to check transmission fluid pressure? mmmchickenboy2 1G Dodge Durango - Drivetrain Talk 4 05-23-2007 04:18 PM
    Transmission fluid level does not go up when adding fluid Hemixav 3G Dodge RAM - Drivetrain Talk 17 02-23-2007 08:03 AM
