cruise control wont work - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 15 Old 05-25-2010, 12:48 AM Thread Starter
pudge_slugfest
Pudge
Got 2 problems here.. I have a 1997 dodge ram 1500 and cruise control won't work, light comes on but it won't set....another problem is my automatic windows, I can't role the passenger side window down from the driver side anymore...if you could help with these problems that would be great! Thank you
1997 DODGE RAM 1500 4x4 Sport package
3.55 gears
K&N FILTER
DUEL CATBACK EXHAUST
2- 4foot Whips
CHROME BUG DEFLECTOR
PUSH BAR
Alpine Deck[/COLOR]
*DodgeTalk.com 318 Enthusiast Member # 25
pudge_slugfest is offline
post #2 of 15 Old 05-26-2010, 10:17 AM
Wetherdad
Wetherdad
Wetherdad's Avatar
The first thing I would check is to see if you have a vaccuum problem since our cruise control runs off of vaccuum, see if your truck will go into 4wd...not just the light coming on, but actually gooing into 4wd....if not then I would say it is a vaccuum issue. As for the p/s window, maybe a bad wire or switch, try using a test lamp on the switch and wire on the d/s.
2002 Durango blown up
2000 Ram 1500 Quad Cab 4x4 with a 5.2 traded
2010 Ram 1500 ST Quad Cab 4x4 with a 4.7 traded
2013 Ram 1500 express quad cab 4x4 with a HEMI! current
Wetherdad is offline
post #3 of 15 Old 05-26-2010, 01:06 PM
key99
Quoted: 312 Post(s)
HVAC, 4X4 and cruise share a vac system. If 4x4 light comes on CAD "should" be at least 80% ENGAGED. Plastic vac lines under hood may leak anywhere, often line for cruise by batt box or by source(middle of mani, pass side). HVAC going too defrost on its own is a sign of vac/checkvalve problems. Theres a vac resevoir under cowl, pass side.
99 1500 SLT QCSB 4x4 5.2 227k mi; SUN vac ga, tow hooks ... umpteenth 46re, LONG 28K lb tr cooler, HAYDEN temp ga ... 3.55 c/w broken clip, 255/70 MICH M+S ... RED HEAD, DSS, MOOG trac n adj BJ; AMS in motor n diffs; HUSKY flr mats ... New shocks, drums, EXTREME rotors, bat; rebuilt mas cyl, alt ... Recent windshield, rad, rr springs, frt axle joints n seals ... Hand vac pump to control recirc door
97 1500 SLT CCSB 4x4 5.2 auto 3.55 lsd, factory tr cooler, HD fan clutch; 140k mi
--Both have spray in box liners; need PS coolers, htr cores and better water pumps for htr/winter use
key99 is offline
post #4 of 15 Old 05-26-2010, 04:36 PM
BigGreenV10
Big Green
BigGreenV10's Avatar
Thanks awesome post my truck goes to defrost and the cruise stopped working please is there any way to get a pic of what you are talking about and explain what I need to look for to fix.
POWDER COAT CLUB MEMBER #1
DON'T TOUCH OUR TRUCK CLUB #2
GREEN TRUCK CLUB MEMBER #31
V10 RAM CLUB MEMBER # 35
MILITARY TRUCK CLUB #147
CRACKED DASH CLUB # 32
2000 2500 V10 4x4 Ext. cab 6" suspension 37 x 12.5 x 16.5 with 4.88 gears.
SCT tuner, Cold air and custom exhaust.
Tail lights, fuel filler door and tail gate handle shaved. Body color fiberglass bed cover and fender flares. Custom all steel 4" cowl hood, custom front bumper.
100% Xtreme Kreations Club President looking for members
BigGreenV10 is offline
post #5 of 15 Old 05-26-2010, 06:24 PM
Wetherdad
Wetherdad
Wetherdad's Avatar
elliott,
there is a good thread/sticky at the very top of this forum, You should check it out...
post #6 of 15 Old 05-26-2010, 06:41 PM
BigGreenV10
Big Green
Did and fixed both the heater and cruise work because one hose fell off on back on intake.
post #7 of 15 Old 05-26-2010, 08:45 PM
key99
Quoted: 312 Post(s)
Geez elliot, thought an oldtime 2Ger like you would have crossed that bridge years ago, lol. But I hear ya, trans issues seem to eat up a lot of time(15 mo autotragic plague also). Anyway, big thanks to DT and Jmw13201 ??? for that sticky; saved me cash and headaches.
key99 is offline
post #8 of 15 Old 05-27-2010, 01:01 AM Thread Starter
pudge_slugfest
Pudge
My VAC lines for 4 wheel are fine just fixed those actually. Could someone give me a diagram on what vaccume lines I should check for cruise
3.55 gears
K&N FILTER
2- 4foot Whips
PUSH BAR
Alpine Deck[/COLOR]
post #9 of 15 Old 05-27-2010, 09:21 AM
BigGreenV10
Big Green
I just have never had any problems with big green and heater actually that truck has been perfect never broke down or failed to start 85,000. It is just the 96 V10 247,000 that has started to give me problems maybe time to put her down.
The vacuum lines come out of the firewall on passenger side and plug into two little plastic pieces. You will see them they look like it is spliced together start with those and try to blow through the little valves and see if air goes through.
post #10 of 15 Old 05-27-2010, 09:51 PM
key99
Quoted: 312 Post(s)
Follow vac lines from cruise, its under batt box. ... Check out, "goes to defrost *FIXED*"; its the first thread in 2G general talk, or top thread on this page. It may have a pic for ya, and will help with leaks and checkvalves. ... A vac pump/tester might be real handy.
key99 is offline
post #11 of 15 Old 05-28-2010, 12:08 PM
BigGreenV10
Big Green
Can't believe how common this problem is on our trucks.
post #12 of 15 Old 05-28-2010, 01:52 PM
key99
Quoted: 312 Post(s)
That sticky is a "MUST READ' for 2G owners. Stealers, shops, etc told me it was computer(NON refundable electric part); my minor "goes to defrost" issue(on big hills or during HARD prolonged accel) was caused by a weak checkvalve(5 bucks) and wee tiny crack by batt box.
key99 is offline
post #13 of 15 Old 05-28-2010, 03:01 PM
BigGreenV10
Big Green
Well that's crazy and exactly why I research stuff on here first before the dealership.
post #14 of 15 Old 05-31-2010, 12:32 PM
98rampower
98rampower's Avatar
i have that same problem but my vaccum line is dissconected on top of the tranny and i dont know where it goes 2 go to the axle 1 goes to the ac lines and i cant find where this one goes anyone know???
1998 ram 5.9 4x4 QCab
flowtech shorty headers
shift kit
spectre cai
dual pipes
Twin flowmasters
3''body lift
SCT
180 tstat
Rancho shocks all around
FI airgap. Fastman 52 mm toyo 33x13.50 mt
98rampower is offline
post #15 of 15 Old 05-31-2010, 12:40 PM
98rampower
98rampower's Avatar
i have the same problem the cruise control doesnt work i found 1 of the lines on the t case disconnected on top of the tranny cant find where it goes anyone know???
shift kit
spectre cai
dual pipes
Twin flowmasters
3''body lift
SCT
180 tstat
    Cruise Control doesn't work halter91 3G Dodge RAM - General Talk 6 09-09-2010 03:56 PM
    Cruise control wont work GTUP 3G Dodge RAM - General Talk 6 06-10-2009 02:18 PM
    295/45/20s now cruise control wont work. mezei 3G Dodge RAM - Tire and Wheel Talk 0 09-25-2008 08:43 PM
    Cruise Control comes on but does not work (98 Ram 1500) frankh911 2G Dodge RAM - General Talk 6 01-08-2006 05:46 PM
    Cruise Control doesn't work t_boys 2G Dodge RAM - General Talk 2 10-28-2004 04:00 PM
