1998 Truck Wont Start After Dead Battery - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 23 Old 05-23-2010, 07:27 PM Thread Starter
MonsoonMike
Site Administrator
MonsoonMike's Avatar
Quoted: 229 Post(s)
My nephew just got a beautiful 1998 1500 2nd gen. We think his alternator went bad cause as he was driving the truck just stopped. When trying to start it - completely dead. Jumping it works - but it won't fire up. Just tries and tries..
I just checked all fuses. They seem good.
Anyone experience anything like this?
Should I rest the computer (how do I do this)
Anything I can look for?
Thanks. Any help ASAP would be great. Trying to not take it in tomorrow..
::2014 Ram 2500 CTD Crew Cab Granite Crystal Metallic::
My Vehicle Build =
MonsoonMike is offline
post #2 of 23 Old 05-23-2010, 07:39 PM Thread Starter
MonsoonMike
Site Administrator
Quoted: 229 Post(s)
Here is the truck
My Vehicle Build =
post #3 of 23 Old 05-23-2010, 07:42 PM
MoparAndy04
MoparAndy04's Avatar
Quoted: 3 Post(s)
Mike, when you hit the key, and the truck has power, do you hear the fuel pump kick on? Have you confirmed there's spark?
I'd start there first.
2016 Ram 1500 Big Horn CC 4x4
5.7L Hemi, 8spd ZF Trans, Sunroof
Heated Seats & Steering Wheel, Center Console
Bone Stock
MoparAndy04 is offline
post #4 of 23 Old 05-23-2010, 07:55 PM Thread Starter
MonsoonMike
Site Administrator
Quoted: 229 Post(s)
I hear the pump when we turn the key on..
My Vehicle Build =
post #5 of 23 Old 05-23-2010, 08:04 PM Thread Starter
MonsoonMike
Site Administrator
Quoted: 229 Post(s)
I put a timin light on the thing - nothing happens....
I think my timing light works I haven't had to use it in years.. lol
coil pack or something else causing no spark?
My Vehicle Build =
post #6 of 23 Old 05-23-2010, 08:06 PM Thread Starter
MonsoonMike
Site Administrator
Quoted: 229 Post(s)
I unplugged the two wire plug on the bottom of the coil pack on the front of the engine on the passenger side.. and that wire didn't have juice to it at all..
My Vehicle Build =
post #7 of 23 Old 05-23-2010, 08:21 PM
MoparAndy04
Quoted: 3 Post(s)
Not sure exactly what that connector is your talking about. I went out to take a lot, and those wires just end up in the main harness. I don't have a '98 shop manual either.
Regardless, it sounds like that coil could be the culprit. I'd replace that and then see what happens. It's a fairly cheap part either way.
Bone Stock
post #8 of 23 Old 05-23-2010, 08:27 PM Thread Starter
MonsoonMike
Site Administrator
Quoted: 229 Post(s)
Here is the coil pack. Since there isn't any power to any of the two wires... makes me think something else is wrong.... Fuses are good...
testing the wires with a test light - I would assume that is all I would need to see power to these correct?
Anyone wanna jump out there unplug it and test it while cranking?
My Vehicle Build =
post #9 of 23 Old 05-23-2010, 08:29 PM
MoparAndy04
Quoted: 3 Post(s)
I actually found a Chiltons Manual for my Cherokee, which also contains info for the Grand Cherokee, which also uses the 5.2L and 5.9L Magnum motors.
To test the coil, connect an ohmeter between the + and - terminals (the ones at that connector you were talking about). Depending on the coil, it should be between .97 and 1.18ohms or .95 and 1.20ohms. Then, connect an ohmeter between the positive coil terminal (at that connector) and the high voltage cable terminal on the coil. This should be between 11,300 and 15,300ohms or 11,300 and 13,300ohms depending upon the manufacturer. Also, checking resistance between the positive coil terminal (at that connector) and the coil case should result in infinite resistance.
I hope you have a multimeter!
Bone Stock
post #10 of 23 Old 05-23-2010, 08:39 PM Thread Starter
MonsoonMike
Site Administrator
Quoted: 229 Post(s)
Ok,. the ohms is good at the wire plug.. testing terminal now..
My Vehicle Build =
post #11 of 23 Old 05-23-2010, 08:40 PM Thread Starter
MonsoonMike
Site Administrator
Quoted: 229 Post(s)
coil is reading 13.3K... so I take it is good?
My Vehicle Build =
post #12 of 23 Old 05-23-2010, 08:48 PM
MoparAndy04
Quoted: 3 Post(s)
Should be good then, even though that's borderline for a coil made by Toyodenso. Any manufacturer markings on the coil?
The only other thing I would do, is yank a plug wire, put an old plug or extension in the plug boot, and hold the wire about 1/4in away from the block while cranking the engine. If you get normal spark then the ignition system is most likely not the culprit.
Oh yea, did you check for that 3rd reading? Also, I'm assuming there no were CEL's?
Bone Stock
post #13 of 23 Old 05-23-2010, 09:09 PM Thread Starter
MonsoonMike
Site Administrator
Quoted: 229 Post(s)
OK, tried to do the spark plug trick... now it won't turn over. just tapped the starter... and it cranks... yikes...
My Vehicle Build =
post #14 of 23 Old 05-23-2010, 09:16 PM Thread Starter
MonsoonMike
Site Administrator
Quoted: 229 Post(s)
ok, going to Autozone to get a new coil. I think it is it.... no spark at plugs...
My Vehicle Build =
post #15 of 23 Old 05-23-2010, 09:42 PM Thread Starter
MonsoonMike
Site Administrator
Quoted: 229 Post(s)
Nope!
My Vehicle Build =
post #16 of 23 Old 05-23-2010, 09:50 PM Thread Starter
MonsoonMike
Site Administrator
Quoted: 229 Post(s)
would reseting the computer do anything? How do you do it on these 2nd gens?
My Vehicle Build =
post #17 of 23 Old 05-23-2010, 09:53 PM
Jmw132001
Jmw132001's Avatar
Quoted: 2 Post(s)
sounds like starter or solenoid is goin bad if you had to tap starter.
Justin
Resigned July 19th 2011
COIN HOLDERS ASSOCIATION MEMBER # 88
Beta tester for online games.
1998 Dodge Ram 1500 qc sport 360 4x4
208,300 original miles (as of 9-25-10)
new transfer case, brakes, shocks, radiator, water pump(twice cause of faulty parts), front balls joints, trak bar, front u-joints, tires, heater core.
Jmw132001 is offline
post #18 of 23 Old 05-23-2010, 10:26 PM
Ram15002ndgen
Don't Fear the Reaper
Ram15002ndgen's Avatar
Disconnect the battery for a couple of minutes and turn the key to release any residual charge. That will clear the computer, but I don't think the computer is your issue. The 2nd gen computer is less intrusive than the 3rd gen. I have heard people with faulty computers that could still run their trucks (with a CEL of coarse).
Ram15002ndgen is offline
post #19 of 23 Old 05-23-2010, 11:38 PM Thread Starter
MonsoonMike
Site Administrator
Quoted: 229 Post(s)
I don't know what it is. But he got it from a dealer a week ago. So he is going to take it back to them. Just odd. I'll let you know if I can what the issue was..
Thanks for everyones help!
My Vehicle Build =
post #20 of 23 Old 06-02-2010, 10:17 PM
MoparAndy04
Quoted: 3 Post(s)
Hey Mike, curious as to what the issue ended up being. Any idea?
Bone Stock
    Doh, Truck won't start. Dead battery? Kelemvor 1G Dodge Durango General Talk 3 04-02-2010 10:42 AM
    Week Old Truck, Dead Battery jtholder00 3G Dodge RAM - General Talk 18 07-11-2007 04:01 PM
    Truck Is Dead, Won't Start. rhinopatch 2G Dodge RAM - General Talk 2 09-27-2006 09:27 PM
    01 Dead Battery, won't jump start nicksorg 1G Dodge Durango General Talk 5 02-26-2006 09:10 PM
    1998 Dodge Ram 1500 wont start buicktv6 2G Dodge RAM - Drivetrain Talk 6 04-13-2005 10:42 PM
