Front Driveshaft - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
Go Back   DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums > Dodge Truck, SUV and Van Forums > Dodge Ram Truck 3rd Gen (02 – 08) Forums > 3G Dodge RAM - Drivetrain Talk
bigblu78
  Front Driveshaft - Posted: 05-12-2010, 09:23 AM
bigblu78's Avatar
State: IL
Post #1
I was wondering if anyone could tell me the best place to buy a complete front driveshaft for an 04 2500 Dodge 4x4 4 door Cummins 6sp? I am working on one for a friend of mine and he "lost" his after the tried to install a new clutch himself. (Don't ask, I have no clue either!!!) I have found several online but I am not too sure who is the best buy out there. We are trying to steer clear of the stealership because they are in the $800 range here.... Thanks in advance for you info.
97 Ext Cab Short Box 5.2 w/auto 4x4
Custom Air Intake, Magnaflow Y-Pipe and CAT
3in Skyjacker Lift (Lift Originally Fit 2500 w/V10)
305's on ARE's
Green Truck Club Member #41
Truck and Gun Club Member #130
TwinStick
 Posted: 05-12-2010, 11:45 AM
Post #2
These guys are the best there is, & probably just as expensive as the dealer. http://www.4xshaft.com/index.html
08' PowerWagon w/6-speed manual G-56. 05' 30' toyhauler camper.(10,500lbs)
Hellwig LoadPro 35 bolt on 4 leaf helper springs.
No honey, I'm NOT done buying shit for the truck yet !!!
PurpleCrainium Diff Guards
K&N air filter --- WeatherGuard 20" black bed toolbox.
winch TPC bypass
Dual battery set up w/2 Sears DieHard Platinums-Gp 65 under hood-Gp 31 Marine deep cycle in bed toolbox w/plug-n-play set up. Custom 2000/4000w inverter set up w/quick connect. Triple bike mounts above the bed- custom made by me.
Crapload of recovery gear-always subject to adding more.
Fab Four rear bumper. Soon to be- a BuckStop Baja front bumper.--Temporarily on hold, see reason below.
Installed: Borgeson #000951 steering shaft. PSC steering brace(notched for PW by Rusty-thanks bud). Carli HD CroMo adjustable track bar. Carli CroMo control arms. Carli HD upper & lower balljoints x 2 sets (replaced under warrenty) & triple sealed u-joints in front axle shafts & rear driveshaft. Moog HD tierod ends x 4. Running total is now $4800. Yup, now i'm broke !!!
What, you ask, is the difference between a Dodge Ram and a PowerWagon ?? PW frame part # 55398868AC---Reg 2500 #55398813AC
About 2" taller, 12,000lb winch w/mounting brace between framerails,electronic disconnecting swaybar(for awsome articulation),electronic locking axles front & rear(for true 4-wheel drive),tow pkg, fully skidplated,forged one piece Alcoa rims w/internal beadlock lips,larger diameter(one ton) axleshaft in rear,160 amp alt,HD battery,4.56 gears,low range electronic recalibration of gas pedal sensitivity,more but thinner leafs in rear spring pack(for better articulation), 33" BFG All-Terrain tires. 78.016:1 crawl ratio. All for $6100.00 more! Oh yeah, almost forgot-Bilstein shocks. Gear ratios: 1st 6.29:1 2nd 3.48:1 3rd 2.10:1 4th 1.38:1 5th 1.0:1 6th .79:1.. Rev 5.74:1.
front driveshaft hwscowboy 2G Dodge RAM - Drivetrain Talk 3 12-14-2009 08:13 PM
front driveshaft toysoldier933 1G Dodge Durango General Talk 2 03-22-2009 08:38 PM
New front driveshaft KTS 3G Dodge RAM - Drivetrain Talk 3 03-18-2008 08:55 PM
where to get a new front driveshaft. KTS 3G Dodge RAM - Drivetrain Talk 3 12-05-2006 09:12 PM
front driveshaft SMBartlett 1G Dodge Durango - Drivetrain Talk 2 03-13-2006 06:44 PM
